    Atom difficulties
    2 Posts 2 Posters 110 Views 2 Watching
    • K Offline
      kjm
      Having problems with Atom & my GPYs again. Only thing I can think of as a possible cause was a recent obligatory Windows10 update?
      1. After I run a program from Atom I have to Disconnect then reconnect the Pymakr package. If I don't attempting to run a program produces output like this
      >>> Running C:\Users\Kris\Google Drive\My Documents\Pycom\main\flash\boot.py
      �ets Jun  8 2016 00:22:57
      configsip: 0, SPIWP:0xee
      mode:DIO, clock div:1
      load:0x3fff8020,len:8
      load:0x3fff8028,len:2136
      load:0x4009fa00,len:19944
      entry 0x400a05e8
      Pycom MicroPython 1.20.1.r1 [15b6d69] on 2019-11-02; GPy with ESP32
      >>> red); return 0,0,0        # multi returns can't have Nones
        File "<stdin>", line 1
      SyntaxError: invalid syntax
      >>> sah=_nvs_get('sah')                                  # sah sample and hold
      NameError: name '_nvs_get' isn't defined
      >>> print(); print(' pressure probe off'); probepwr=Pin('P8', Pin.OPEN_DRAIN); probepwr.value(1)                                  # probe OFFd at each powerup in case _pwrup_reason does deepsleep
       pressure probe off
      NameError: name 'Pin' isn't defined
      >>> def _getdepth():
      ...       try:
      ...             global sah
      ...                 print (' pressure probe on', end=2L for a 2m dia tank
      ...                     if dt>4*3600: NetFlow=0                                                  # dot every 4 hr, 20mm/4h=5mm/h (~16L/h) min detectable flow
      ...                         if d>dh>19 and t2>t1>999999: print(' store', t2, h2); NetFlow=int(3600*dv/dt); pycom.nvs_set('epoch', t2); pycom.nvs_set('depth', h2)             # depth>depth>difference, valid epochs
      ...                             res='t' if d>dh>19 else 'f'; print('', d, h2-h1, res, end='  '); res='t' if t2>t1>999 else 'f'; print(t2, t1, res)
      ...                                 if dh>sah and cycle>2: sah=dh; pycom.nvs_set('sah', dh); msg=' level change '+str(h2-h1); print(msg); _mkpyld(0, msg)
      1. Since Disconnecting from the GPY then convincing the Pymakr plugin to work generally takes several attempts I thought it might be quicker to upload programs rather than try to run then from Atom. In this case I get
      Uploading project (flash)...
      Not safe booting, disabled in settings
      Reading file status
      Creating dir lib
      [1/2] Writing file boot.py (73kb)
      Failed to write file, trying again...
      Failed to write file: name 'f' isn't defined
      [2/2] Writing file lib/onewire.py (8kb)
      Upload failed: Failed to write file: invalid sy. Please reboot your device manually.
      >>> machine.reset()
      Having to make several attempts to reload Pymakr after each code improvement is misery, it's like swimming through molasses! Does anyone have any suggestions? I'm running pymakr 1.4.16 on Atom 1.40.1
      • stephen.ugwuanyiS Offline
        stephen.ugwuanyi
        I am having the same issue and error messages with Fipy and Gpy.
        OKets Jun 8 2016 00:22:57
        rst:0x7 (TG0WDT_SYS_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
        load:0x3fff9028,len:8
        load:0x3fff9030,len:1060
        load:0x4009fa00,len:0
        ho 12 tail 0 room 4
        load:0x4009fa00,len:14084
        entry 0x400a05d4
        Start program? (y/n)
