OTA firmware update not working for 1.20.2.rc7
  • Note this is only an issue for updating to 1.20.2.rc7 (1.20.2.rc6 is okay)
    I'm trying to do an OTA firmware update to 1.20.2.rc7 from 1.20.1.r2, and I get the following error:
    E (56) esp_image: image at 0x210000 has invalid magic byte
    Cannot load Firmware img in the active partition! .. Defaulting back to previous partition
    Here is the full log:
    Pycom MicroPython 1.20.1.r2 [v1.11-06dfad0] on 2019-11-30; WiPy with ESP32
    Pybytes Version: 1.3.0
    >>> Requesting: downloads/appimg/firmware_WiPy_1.20.2.rc7.bin to software.pycom.io:443 with SSL? True
    Wrapping socket
    Sending request
    start
    ets Jun  8 2016 00:22:57
    rst:0x7 (TG0WDT_SYS_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    mode:DIO, clock div:1
    load:0x3fff8020,len:8
    load:0x3fff8028,len:2136
    load:0x4009fa00,len:19880
    entry 0x400a05d0
    Cannot load Firmware img in the active partition! .. Defaulting back to previous partition```
    It then resets into the original firmware.
    Any ideas?
  • Hi @troy-salt
    I tried the OTA firmware update on WiPy from 1.20.1.r2 to 1.20.2.r7 using OTA firmware update example and the update worked fine. Please refer to this example (https://docs.pycom.io/tutorials/all/ota/) for the exact steps to perform an OTA update.
    The image file that you have in the flash seems to be corrupt. Make sure that the file is written correctly.
  • hi @troy-salt, we are looking into this issue.
