pymakr.anything command not found in VS Code
Hi All,
I installed the pymakr extension for VS Code, but none of the commands work. If I try any of them (and they are all displayed when I do ctrl+shift+P) I get a dialog box (bottom right of the window) saying "pymakr.anything command not found". What have I done wrong?I also don't see the pycom commands on the status bar at the bottom of the window.
I use Linux Mint 19.3, VS Code V1.41.1, pymakr V1.1.6.
Possibly check if node.js is installed?
