Pinging a second device on the LAN - how to?
I have a pair of WiPys that I have been able to install on a common network with static IP addresses. This is a private network, I have no need to access the Internet. I would like to use ping to verify that I can "see" one WiPy from the other (and vice versa). Ultimately these devices will be sharing information between themselves (and other WiPys on the network). Although I have read that uping is the ping equivalent in Micropython I don't seem to be able to load it onto my WiPys. When I attempt to import uping the system complains that no such module exists. I guess I need to add this to /flash but where do I get the necessary file(s)?
Some help would be much appreciated!
@nigelwattrus The original uping.py code is here: https://gist.github.com/shawwwn/91cc8979e33e82af6d99ec34c38195fb
I had to adapt it for the pycom microypthon variant. Code below:# µPing (MicroPing) for MicroPython # copyright (c) 2018 Shawwwn <shawwwn1@gmail.com> # License: MIT # Internet Checksum Algorithm # Author: Olav Morken # https://github.com/olavmrk/python-ping/blob/master/ping.py # @data: bytes def checksum(data): if len(data) & 0x1: # Odd number of bytes data += b'\0' cs = 0 for pos in range(0, len(data), 2): b1 = data[pos] b2 = data[pos + 1] cs += (b1 << 8) + b2 while cs >= 0x10000: cs = (cs & 0xffff) + (cs >> 16) cs = ~cs & 0xffff return cs def ping(host, count=4, timeout=5000, interval=500, quiet=False, size=64): import utime import uselect import uctypes import usocket import ustruct import uos # prepare packet assert size >= 16, "pkt size too small" pkt = b'Q'*size pkt_desc = { "type": uctypes.UINT8 | 0, "code": uctypes.UINT8 | 1, "checksum": uctypes.UINT16 | 2, "id": (uctypes.ARRAY | 4, 2 | uctypes.UINT8), "seq": uctypes.INT16 | 6, "timestamp": uctypes.UINT64 | 8, } # packet header descriptor h = uctypes.struct(uctypes.addressof(pkt), pkt_desc, uctypes.BIG_ENDIAN) h.type = 8 # ICMP_ECHO_REQUEST h.code = 0 h.checksum = 0 h.id[0:2] = uos.urandom(2) h.seq = 1 # init socket sock = usocket.socket(usocket.AF_INET, usocket.SOCK_RAW, 1) sock.setblocking(0) sock.settimeout(timeout/1000) addr = usocket.getaddrinfo(host, 1)[0][-1][0] # ip address sock.connect((addr, 1)) not quiet and print("PING %s (%s): %u data bytes" % (host, addr, len(pkt))) seqs = list(range(1, count+1)) # [1,2,...,count] c = 1 t = 0 n_trans = 0 n_recv = 0 finish = False while t < timeout: if t==interval and c<=count: # send packet h.checksum = 0 h.seq = c h.timestamp = utime.ticks_us() h.checksum = checksum(pkt) if sock.send(pkt) == size: n_trans += 1 t = 0 # reset timeout else: seqs.remove(c) c += 1 # recv packet while 1: socks, _, _ = uselect.select([sock], [], [], 0) if socks: resp = socks[0].recv(4096) resp_mv = memoryview(resp) h2 = uctypes.struct(uctypes.addressof(resp_mv[20:]), pkt_desc, uctypes.BIG_ENDIAN) # TODO: validate checksum (optional) seq = h2.seq if h2.type==0 and h2.id==h.id and (seq in seqs): # 0: ICMP_ECHO_REPLY t_elasped = (utime.ticks_us()-h2.timestamp) / 1000 ttl = ustruct.unpack('!B', resp_mv[8:9])[0] # time-to-live n_recv += 1 not quiet and print("%u bytes from %s: icmp_seq=%u, ttl=%u, time=%f ms" % (len(resp), addr, seq, ttl, t_elasped)) seqs.remove(seq) if len(seqs) == 0: finish = True break else: break if finish: break utime.sleep_ms(1) t += 1 # close sock.close() ret = (n_trans, n_recv) not quiet and print("%u packets transmitted, %u packets received" % (n_trans, n_recv)) return (n_trans, n_recv)Call it for instance with:
from uping import ping
ping("www.google.com")
