pycom.nvs_get() returns an exception
 When i run the nvs_get() with a key that does not exist i get a valueError exception. While the documentation states that it should return None. Is there unexpected behavior on my side or is the documentation outdated?
 I believe the documentation is outdated. To circumvent it, you can use a try-except statement like here: (You can also specify the exception in more detail)try: counter = pycom.nvs_get('count') except Exception: counter = 0Best,
