    Pygate - ethernet reliability issues
    41 Posts 9 Posters 635 Views 10 Watching
    • schmelpeS Offline
      schmelpe @schmelpe
      I'm using the WiPy 3.0 with PyGate.
        thinginnovations
        Lopy4 here buy got a wipy 3 on order as I need the lopy4 elsewhere
          tronto @thinginnovations
          @thinginnovations I'm having a similar issue that you describe. Unit powers up fine, and after a period of time (30 min~) the latency from a ping increases dramatically (1ms to 1000ms) and the unit loses connectivity fully and has to be power cycled to respond again.
            peterp @tronto
            @tronto said in Pygate - ethernet reliability issues:
            Is this with or without lora gateway? Can you reproduce it without gateway? Is it happening once, sometimes, always? Is it with POE or just Ethernet?
              thinginnovations @peterp
              @peterp Pygate is the lora gateway!
                thinginnovations
                I've changed the LoPy4 for a WiPy3, still using POE Ethernet for backhaul to The Things Network. It barely lasts overnight.
                  peterp @thinginnovations
                  @thinginnovations said in Pygate - ethernet reliability issues:
                  Sure. I was trying to suggest steps to narrow down the problem.
                  I.e., establish an eth connection and use it continuously for some up/downloads, but do NOT use the gateway functionality. Is the connection stable? If yes, then the counter test could be gateway over WiFi.
                  • schmelpeS Offline
                    schmelpe
                    ok. I can confirm that the PyGate with WiPy3 stops responding to PING requests a few minutes after startup with PoE.
                    But I can't confirm that the PyGate didn't work anymore. The Gateways status within the TTN Console is updated every 30 Seconds or so for the last 15 days.
                    Hope this helps
                    Peter
                      jcaron @schmelpe
                      @schmelpe given the timeframes announced by several people (hours or days) I was wondering if maybe there was a link with DHCP lease times or something similar. But if you see issues after a few minutes, unless your DHCP leases are extremely short, that’s probably not the culprit.
                      Is the “stops pinging after a few minutes” repeatable? Is it always the same time/number of pings? Are you pinging from a box on the same network or a different one?
                      schmelpeS 1 Reply Last reply Reply Quote 0
                      • schmelpeS Offline
                        schmelpe @jcaron
                        @jcaron I found an interesting thing.....
                        DHCP Lease is set to 8 hours on my router.
                        • During my tests yesterday, my Pygate stops answering to a PING after 1 or 2 minutes after powering up the device (remember, it runs 15 days or so 24/7 and was really hot). Yesterday afternoon I disconnected the Pygate because one of my Sensors didn't Join via OTAA (a known PyGate problem).
                        • This morning I powerded up the PyGate again (ca. 29°C room temperature) and the PyGate always answers to a PING.
                        ### PyGate powerded up in "cold" condition
                        PS C:\WINDOWS\system32> date
                        Wednesday, August 12, 2020 12:05:15 PM
                        PS C:\WINDOWS\system32> ping 192.168.1.5
                        Pinging 192.168.1.5 with 32 bytes of data:
                        Reply from 192.168.1.5: bytes=32 time=6ms TTL=255
                        Reply from 192.168.1.5: bytes=32 time=2ms TTL=255
                        Ping statistics for 192.168.1.5:
                            Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
                        Approximate round trip times in milli-seconds:
                            Minimum = 2ms, Maximum = 6ms, Average = 3ms
                        ### PyGate is in "warm/hot" condition
                        Wednesday, August 12, 2020 12:21:35 PM
                        Reply from 192.168.1.5: bytes=32 time=76ms TTL=255
                        Request timed out.
                        Request timed out.
                        Request timed out.
                            Packets: Sent = 4, Received = 1, Lost = 3 (75% loss),
                            Minimum = 76ms, Maximum = 76ms, Average = 76ms
                        Wednesday, August 12, 2020 12:26:08 PM
                        Reply from 192.168.1.5: bytes=32 time=843ms TTL=255
                        Request timed out.
                        Reply from 192.168.1.5: bytes=32 time=421ms TTL=255
                        Request timed out.
                            Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
                            Minimum = 421ms, Maximum = 843ms, Average = 632ms
                        As you can see, the PyGate starts stop responding to a PING request when it becomes warm/hot...
                        But, the connection to TTN is working and refreshes every 30 seconds. Only PING is no longer working.
                        Don't know how to figure out the problem.
                        Hope this helps
                        Peter
                          tronto @schmelpe
                          @peterp Using a pygate lora gateway. Attached is a photo of ping results from local network using dhcp and POE+ ethernet. Happens every time. Disabled lora gateway and trying with WIFI (powered via POE) to narrow it down. Will follow up.
                            I believe the issue is not heat related (I just tested the Pygate (with the lora concentrator disabled)) and PyEthernet. Applied heat with a heatgun and checked the ping times. I was not able to find any differences, with heat applied of about 100*C.
                            Now I did some further testing, and sometimes pings are not getting through with the Gateway enabled or disabled. I cannot seem to reproduce the case of @tronto Where the ping times significantly increase after a few timeouts.
                            Pings are generally <10ms on our network, with few going above that..
                            Also, I see no relation in the lost pings compared to the Pygate dropping any lora packets, but please do let us know of your findings!
                            Btw @schmelpe, you mention OTAA not joining being a known Pygate problem, could you elaborate? I believe the issue you are referring to has to do with frequency plan settings not being in sync..
                            Best,
                              tronto @Gijs
                              @Gijs My issue seems to be related to ethernet communication. I don't seem to have the same issue using wifi for communication (and power from POE). Have tried two different brands of switch (ubnt + cisco) with same results with eventual ethernet drop out.
                              I believe both switches saw the POE module as 10FDX if that makes any difference.
                              • schmelpeS Offline
                                schmelpe
                                Hi @Gijs ,
                                no, I don't think so.
                                Please look at this Thread: https://forum.pycom.io/topic/6206/cannot-make-join-otaa-timely-with-pygate-and-lopy4.
                                I'm using a WiPy3 with firmware 1.20.2rc10 and have exact the same problem.
                                OTAA JOIN request over Pygate do not work for me (EU868), OTAA JOIN requests with my other TTN Gateway are working fine within two or three attempts.
                                You'll find my code in the this thread.
                                config.json:
                                	"SX1301_conf": {
                                		"lorawan_public": true,
                                		"clksrc": 1,
                                		"antenna_gain": 0,
                                		"radio_0": {
                                			"enable": true,
                                			"type": "SX1257",
                                			"freq": 867500000,
                                			"rssi_offset": -164.0,
                                			"tx_enable": true,
                                			"tx_freq_min": 863000000,
                                			"tx_freq_max": 870000000
                                		"radio_1": {
                                			"enable": true,
                                			"type": "SX1257",
                                			"freq": 868500000,
                                			"tx_enable": false
                                		"chan_multiSF_0": {
                                			"enable": true,
                                			"radio": 1,
                                			"if": -400000
                                		"chan_multiSF_1": {
                                			"enable": true,
                                			"radio": 1,
                                			"if": -200000
                                		"chan_multiSF_2": {
                                			"enable": true,
                                			"radio": 1,
                                			"if": 0
                                		"chan_multiSF_3": {
                                			"enable": true,
                                			"radio": 0,
                                			"if": -400000
                                		"chan_multiSF_4": {
                                			"enable": true,
                                			"radio": 0,
                                			"if": -200000
                                		"chan_multiSF_5": {
                                			"enable": true,
                                			"radio": 0,
                                			"if": 0
                                		"chan_multiSF_6": {
                                			"enable": true,
                                			"radio": 0,
                                			"if": 200000
                                		"chan_multiSF_7": {
                                			"enable": true,
                                			"radio": 0,
                                			"if": 400000
                                		"chan_Lora_std": {
                                			"enable": true,
                                			"radio": 1,
                                			"if": -200000,
                                			"bandwidth": 250000,
                                			"spread_factor": 7
                                		"chan_FSK": {
                                			"enable": true,
                                			"radio": 1,
                                			"if": 300000,
                                			"bandwidth": 125000,
                                			"datarate": 50000
                                		"tx_lut_0": {
                                			"pa_gain": 0,
                                			"mix_gain": 5,
                                			"rf_power": 9,
                                			"dig_gain": 3
                                		"tx_lut_1": {
                                			"pa_gain": 0,
                                			"mix_gain": 5,
                                			"rf_power": 9,
                                			"dig_gain": 3
                                		"tx_lut_2": {
                                			"pa_gain": 0,
                                			"mix_gain": 5,
                                			"rf_power": 9,
                                			"dig_gain": 3
                                		"tx_lut_3": {
                                			"pa_gain": 0,
                                			"mix_gain": 5,
                                			"rf_power": 9,
                                			"dig_gain": 3
                                		"tx_lut_4": {
                                			"pa_gain": 0,
                                			"mix_gain": 5,
                                			"rf_power": 9,
                                			"dig_gain": 3
                                		"tx_lut_5": {
                                			"pa_gain": 0,
                                			"mix_gain": 5,
                                			"rf_power": 9,
                                			"dig_gain": 3
                                		"tx_lut_6": {
                                			"pa_gain": 0,
                                			"mix_gain": 5,
                                			"rf_power": 9,
                                			"dig_gain": 3
                                		"tx_lut_7": {
                                			"pa_gain": 0,
                                			"mix_gain": 6,
                                			"rf_power": 11,
                                			"dig_gain": 3
                                		"tx_lut_8": {
                                			"pa_gain": 0,
                                			"mix_gain": 5,
                                			"rf_power": 13,
                                			"dig_gain": 2
                                		"tx_lut_9": {
                                			"pa_gain": 0,
                                			"mix_gain": 8,
                                			"rf_power": 14,
                                			"dig_gain": 3
                                		"tx_lut_10": {
                                			"pa_gain": 0,
                                			"mix_gain": 6,
                                			"rf_power": 15,
                                			"dig_gain": 2
                                		"tx_lut_11": {
                                			"pa_gain": 0,
                                			"mix_gain": 6,
                                			"rf_power": 16,
                                			"dig_gain": 1
                                		"tx_lut_12": {
                                			"pa_gain": 0,
                                			"mix_gain": 9,
                                			"rf_power": 17,
                                			"dig_gain": 3
                                		"tx_lut_13": {
                                			"pa_gain": 0,
                                			"mix_gain": 10,
                                			"rf_power": 18,
                                			"dig_gain": 3
                                		"tx_lut_14": {
                                			"pa_gain": 0,
                                			"mix_gain": 11,
                                			"rf_power": 19,
                                			"dig_gain": 3
                                		"tx_lut_15": {
                                			"pa_gain": 0,
                                			"mix_gain": 12,
                                			"rf_power": 20,
                                			"dig_gain": 3
                                	"gateway_conf": {
                                		"gateway_ID": "myID",
                                		"server_address": "router.eu.thethings.network",
                                		"serv_port_up": 1700,
                                		"serv_port_down": 1700,
                                		"keepalive_interval": 10,
                                		"stat_interval": 30,
                                		"push_timeout_ms": 100,
                                		"forward_crc_valid": true,
                                		"forward_crc_error": false,
                                		"forward_crc_disabled": false
                                I'll reflash the actual firmware 1.20.2 today, but I think it won't help because it's the same as 1.20.2rc10.
                                There is no new firmware for the PyGate available. 1.20.2rc10 seems to be the last one.
                                Best regards
                                Peter
                                  @tronto The PyEthernet has a 10/100 Mbps ethernet (in 10 mode) controller that talks over an SPI bus at 8MHz. In that datalink, it is probable some incoming packets will get dropped. Ive had mine run over the weekend and it is still connected to TTN (on a netgear gigabit switch). I have heard of the possibility that using a 10 Mbps device on a switch could drop all the traffic through the switch to 10 Mbps (I have yet to see a reproduction with the PyEthernet though). Another issue can be related to the single jumper on the PyEthernet (close to the Ethernet port). Some (older) PoE adapters require a minimum amount of current to be drawn or they will switch off. The Pygate is generallly below the minimum, causing the PoE to dropout for a second, inserting the jumper will connect a default resistor load.
                                  @schmelpe, I looked into the OTAA issue myself as well, and could only reproduce it (as the original problem states) by bodging of frequency settings.. Moreover, the OTAA join accept is still send out when the logs mention 'Ignored not rejected'. If you are experiencing LoRa OTAA issues at EU868MHz, with the frequency settings set correctly on all devices, please do let us know! (nb. Ill take up the firmware versioning with the firmware team, seems they missed to upload it!)
                                  I am currently working on testing different frequency settings using the configuration files from here: https://github.com/TheThingsNetwork/gateway-conf and adding
                                  		"gateway_ID": "XXXX",
                                  at the bottom of the config file, within the closing brackets. Let me know if that works better for you! (ill add it to the other thread as well)
                                  • schmelpeS Offline
                                    schmelpe @Gijs
                                    @Gijs: I'm confused now... :-)
                                    Which config.json should I use?
                                    The one mentioned in your last reply with the additions or this one from your documentation?
                                    Thanks, Peter
                                      Sorry for the confusion!
                                      The configuration files are very similar in the end, but I feel like the configuration provided by TTN is slightly better than the one we created ourselves, but let me know of your experiences! They also have examples for more regions than we do currently ;)
                                      Best,
                                      schmelpeS 1 Reply Last reply Reply Quote 1
                                      • schmelpeS Offline
                                        schmelpe @Gijs
                                        @Gijs: Ok, understood. I'll update my PyGate in a few minutes and see the what's going on. :-)
                                        Thanks, Peter
                                        1 Reply Last reply Reply Quote -1
                                        • schmelpeS Offline
                                          schmelpe
                                          Hi @gijs,
                                          Please excuse the late response, but I wanted to make sure everything works now.
                                          As you recommended, I used the config.json for EU868 from the TTN for my PyGate. So it seems to work perfectly so far. The devices I tested need about 5-10 seconds to join the TTN via OTAA.
                                          Thank you very much for your support.
                                          Best wishes
                                          Peter
                                          	"SX1301_conf": {
                                          		"clksrc": 1,
                                          		"clksrc_desc": "radio_1 provides clock to concentrator for most devices except MultiTech. For MultiTech set to 0.",
                                          		"antenna_gain": 2,
                                          		"antenna_gain_desc": "antenna gain, in dBi",
                                          		"radio_0": {
                                          			"enable": true,
                                          			"type": "SX1257",
                                          			"freq": 867500000,
                                          			"rssi_offset": -166.0,
                                          			"tx_enable": true,
                                          		"radio_1": {
                                          			"enable": true,
                                          			"type": "SX1257",
                                          			"freq": 868500000,
                                          			"tx_enable": false
                                          		"chan_multiSF_0": {
                                          			"desc": "Lora MAC, 125kHz, all SF, 868.1 MHz",
                                          			"enable": true,
                                          			"radio": 1,
                                          			"if": -400000
                                          		"chan_multiSF_1": {
                                          			"desc": "Lora MAC, 125kHz, all SF, 868.3 MHz",
                                          			"enable": true,
                                          			"radio": 1,
                                          			"if": -200000
                                          		"chan_multiSF_2": {
                                          			"desc": "Lora MAC, 125kHz, all SF, 868.5 MHz",
                                          			"enable": true,
                                          			"radio": 1,
                                          			"if": 0
                                          		"chan_multiSF_3": {
                                          			"desc": "Lora MAC, 125kHz, all SF, 867.1 MHz",
                                          			"enable": true,
                                          			"radio": 0,
                                          			"if": -400000
                                          		"chan_multiSF_4": {
                                          			"desc": "Lora MAC, 125kHz, all SF, 867.3 MHz",
                                          			"enable": true,
                                          			"radio": 0,
                                          			"if": -200000
                                          		"chan_multiSF_5": {
                                          			"desc": "Lora MAC, 125kHz, all SF, 867.5 MHz",
                                          			"enable": true,
                                          			"radio": 0,
                                          			"if": 0
                                          		"chan_multiSF_6": {
                                          			"desc": "Lora MAC, 125kHz, all SF, 867.7 MHz",
                                          			"enable": true,
                                          			"radio": 0,
                                          			"if": 200000
                                          		"chan_multiSF_7": {
                                          			"desc": "Lora MAC, 125kHz, all SF, 867.9 MHz",
                                          			"enable": true,
                                          			"radio": 0,
                                          			"if": 400000
                                          		"chan_Lora_std": {
                                          			"desc": "Lora MAC, 250kHz, SF7, 868.3 MHz",
                                          			"enable": true,
                                          			"radio": 1,
                                          			"if": -200000,
                                          			"spread_factor": 7
                                          		"chan_FSK": {
                                          			"desc": "FSK 50kbps, 868.8 MHz",
                                          			"enable": true,
                                          			"radio": 1,
                                          			"if": 300000,
                                          			"datarate": 50000
                                          		"tx_lut_0": {
                                          			"desc": "TX gain table, index 0",
                                          			"pa_gain": 0,
                                          			"mix_gain": 8,
                                          			"rf_power": -6,
                                          			"dig_gain": 0
                                          		"tx_lut_1": {
                                          			"desc": "TX gain table, index 1",
                                          			"pa_gain": 0,
                                          			"mix_gain": 10,
                                          			"rf_power": -3,
                                          			"dig_gain": 0
                                          		"tx_lut_2": {
                                          			"desc": "TX gain table, index 2",
                                          			"pa_gain": 0,
                                          			"mix_gain": 12,
                                          			"rf_power": 0,
                                          			"dig_gain": 0
                                          		"tx_lut_3": {
                                          			"desc": "TX gain table, index 3",
                                          			"pa_gain": 1,
                                          			"mix_gain": 8,
                                          			"rf_power": 3,
                                          			"dig_gain": 0
                                          		"tx_lut_4": {
                                          			"desc": "TX gain table, index 4",
                                          			"pa_gain": 1,
                                          			"mix_gain": 10,
                                          			"rf_power": 6,
                                          			"dig_gain": 0
                                          		"tx_lut_5": {
                                          			"desc": "TX gain table, index 5",
                                          			"pa_gain": 1,
                                          			"mix_gain": 12,
                                          			"rf_power": 10,
                                          			"dig_gain": 0
                                          		"tx_lut_6": {
                                          			"desc": "TX gain table, index 6",
                                          			"pa_gain": 1,
                                          			"mix_gain": 13,
                                          			"rf_power": 11,
                                          			"dig_gain": 0
                                          		"tx_lut_7": {
                                          			"desc": "TX gain table, index 7",
                                          			"pa_gain": 2,
                                          			"mix_gain": 9,
                                          			"rf_power": 12,
                                          			"dig_gain": 0
                                          		"tx_lut_8": {
                                          			"desc": "TX gain table, index 8",
                                          			"pa_gain": 1,
                                          			"mix_gain": 15,
                                          			"rf_power": 13,
                                          			"dig_gain": 0
                                          		"tx_lut_9": {
                                          			"desc": "TX gain table, index 9",
                                          			"pa_gain": 2,
                                          			"mix_gain": 10,
                                          			"rf_power": 14,
                                          			"dig_gain": 0
                                          		"tx_lut_10": {
                                          			"desc": "TX gain table, index 10",
                                          			"pa_gain": 2,
                                          			"mix_gain": 11,
                                          			"rf_power": 16,
                                          			"dig_gain": 0
                                          		"tx_lut_11": {
                                          			"desc": "TX gain table, index 11",
                                          			"pa_gain": 3,
                                          			"mix_gain": 9,
                                          			"rf_power": 20,
                                          			"dig_gain": 0
                                          		"tx_lut_12": {
                                          			"desc": "TX gain table, index 12",
                                          			"pa_gain": 3,
                                          			"mix_gain": 10,
                                          			"rf_power": 23,
                                          			"dig_gain": 0
                                          		"tx_lut_13": {
                                          			"desc": "TX gain table, index 13",
                                          			"pa_gain": 3,
                                          			"mix_gain": 11,
                                          			"rf_power": 25,
                                          			"dig_gain": 0
                                          		"tx_lut_14": {
                                          			"desc": "TX gain table, index 14",
                                          			"pa_gain": 3,
                                          			"mix_gain": 12,
                                          			"rf_power": 26,
                                          			"dig_gain": 0
                                          		"tx_lut_15": {
                                          			"desc": "TX gain table, index 15",
                                          			"pa_gain": 3,
                                          			"mix_gain": 14,
                                          			"rf_power": 27,
                                          			"dig_gain": 0
                                          	"gateway_conf": {
                                          		"gateway_ID": "<FILL ME IN>",
                                          		"forward_crc_disabled": false,
                                          		"servers": [ {
                                          			"serv_enabled": true
                                          • schmelpeS Offline
                                            schmelpe
                                            Hi @Gijs,
                                            I have now also found the solution for the Ethernet reliability problem.
                                            It's because of the WiFi that I use to ping. I suspect the Ubiquiti Nano HD AccessPoint as the cause. If I send a ping via Ethernet, this is always answered 100% by the PyGate. Even after several days of continuous operation. At first I was not aware of the problem with the access point, because the ping losses occurred from several computers, all of which were connected via WLAN. Only after I ran the ping tests from a stationary computer did I no longer have any problems.
                                            So sorry for the noises ...
                                            Best wishes
                                            Peter
                                            • 1 / 3
