Lopy4 : lora callback issue
the codefrom network import LoRa def onReceive(interface): print("LoRa RX Event") lora_Interface = LoRa(LoRa.LORA, region=LoRa.EU868, frequency = 868100000,bandwidth=LoRa.BW_125KHZ, sf=7, coding_rate=LoRa.CODING_4_5, preamble=8, power_mode=LoRa.ALWAYS_ON, public=False) lora_Interface.callback(trigger=LoRa.RX_PACKET_EVENT, handler=onReceive)
works well.
But if I add at the endwhile True: pass
the callback is no longer run.
If I stop using ctrl-c, the callback is called.
Is this normal?
Is the callback not an interrupt?Thanks
Thierry
I think @d-alvrzx is correct here. You need some 'idle' time on the CPU for the callback to be registered. I believe its not a hardware routine that is used for the callback, but merely on top of the RTOS.
@Thierry Something similar happened to me awhile back, but not with Lora callbacks, but with threads. I remember what I ended up doing was adding a short sleep (something like
sleep_ms(10)
) to the main loop. That way the loop would yield occasionally, and threads would execute correctly. Maybe try doing this?This is the thread where this was discussed: https://forum.pycom.io/topic/5805/main-thread-blocks-auxiliary-threads-thread-module/6?=1600903682512
