    No more local connection after Pybytes
    Scheduled Pinned Locked Moved Pybytes IoT platform
    4 Posts 3 Posters 64 Views 3 Watching
      Bastock
      Hello, after a successful connection with Pybytes i can't reconnect my Wipy 3 to my local PC via VScode with Pymakr ?
      thanks
      Bart
        Bastock
        Found a solution.
        After removing file pybytes_config.json and reflash with latest firmware, i can connect again with Pymakr.
          robert-hh @Bastock
          @Bastock There is a also the pybytes_on_boot() method of the pycom module.
          pycom.pybytes_on_boot(False)
          Will disable pybytes. That one is in the code, but not documented. But that may not help if you have no access to the REPL at all.
            In the meantime, it has been documented ;) http://docs.pycom.io/firmwareapi/pycom/pycom/#pycompybytes_on_boot
            Soon, it will be in the Pybytes section as well
