do pytrack-2 and pycoproc 0.0.4 work (wake on accel interrupt)
Hi gang,
I've got a GPy and a pytrack v2, and I can't get them to wake on accelerometer interrupt. Does anyone have this working?
I'm on GPY 1.20.2.r1, with a freshly-formatted littlefs filesystem and freshly-erased nvram. Libraries are from https://github.com/pycom/pycom-libraries/tree/master/pytrack-2/lib
I'm trying
from pytrack import Pytrack from LIS2HH12 import LIS2HH12 py = Pytrack() acc = LIS2HH12(py) py.read_hw_version() # 6 py.read_fw_version() # 15 py.read_product_id() # 61459 os.uname() # (sysname='GPy', nodename='GPy', release='1.20.2.r1', version='v1.11-a5aa0b8 on 2020-09-09', machine='GPy with ESP32', pybytes='1.6.0') acc.enable_activity_interrupt(200, 200) # this works before I go_to_sleep py.setup_int_wake_up(rising=True, falling=False) # attempt to wake on activity py.setup_sleep(300) py.go_to_sleep()Once asleep, the pytrack button wakes it instantly, or RTC wakes it eventually, but no amount of shaking will cause the accelerometer to wake it. In related news, it seems pycoproc 0.0.4 has removed get_wake_reason() and get_sleep_remaining(). Does this library actually work?
Henry
We hope to publish something soon!
In the meantime, I can give you a sneak preview here:
https://github.com/pycom/pycom-libraries/issues/132#issuecomment-748895114
I've also got the GPy and a Pytrack V2, and I experience the same issue. I also tried to add the get_wake_reason and get_sleep_remaining from an older version of pycoproc, but they both return zero. (While there should be some value in it). It only wakes on the timer, not on the accelerometer.
@Gijs Is there already some news about this issue?
We are working on fixing this issue!
@hgoldwire I am having a similar issue with my external interrupt using a sensor. I paid money for a 1 hour consultation with pycom and they stopped responding. Very unprofessional in my opinion.
https://forum.pycom.io/topic/6370/pytrack2-external-pic-interrupt
