Erasing flash via pycom-fwtool-cli with barebones LoPy4
Hello all:
I am attempting to erase the flash (and ultimately flash new firmware) to a LoPy4 that is barebones, connected to a breadboard, via the
pycom-fwtool-clitool. I currently have nothing else connected to the LoPy4 other than:- 5V power from external power supply
- GND from external power supply
- TX, RX and GND to an FTDI USB to Serial converter
- GPIO0 (P2) connected to GND on boot (to enter bootloader mode)
When entering bootloader mode, I get the following message:
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2)) waiting for downloadHowever, when I run
pycom-fwtool-cli.exe -p COM7 erase_all, I get the following output:Running in FTDI mode Erasing the board can take up to 40 seconds. Exception: Failed to connect to ESP32: Timed out waiting for packet headerIs it possible to do these sort of commands without an Expansion board? I am testing this on a breadboard because I want to be able to do this on a PCB I am working on.
I have already tested lowering the baud rate, but no luck!
Maybe, @Gijs, could you help me out?
Best,
Dan
If you are able to connect to the device and run code, you can run
import os os.fsformat("/flash")If fsformat() doesn't work, it's because Pycom has changed the function name several times. Also try with
makefsandmkfs(with the same arguments) in case you have a lower version.
@d-alvrzx Yes, you can do that without an expansion board. Did you close all other software connected to the LoPy4 before starting pycom-fwtool-cli?
You may also try to use esptool.py itself, which is the heart of pycom-fwtool-cli.py. -
@robert-hh Thank you! So I uncovered what might be the problem: the commands coming from
pycom-fwtool-clionly work once. Say, following this procedure:- Connect P2 to GND while LoPy4 powered off
- Power on LoPy4
- Send
pycom-fwtool-cli -p COM7 erase_allcommand- This command works, flash is erased in 15.98 seconds
- Send
pycom-fwtool-cli -p COM7 flash -t LoPy4-1.20.2.rc6.tar.gzto flash new firmware- This command does not work, throws
- Restart LoPy4 with P2 to GND
- Try
pycom-fwtool-cli -p COM7 flash -t LoPy4-1.20.2.rc6.tar.gzagain- This command works, firmware is flashed correctly.
So it seems I need a reset between each command? Is this how it should work?
EDIT: And yes, I did close all other software before opening the pycom fwtool.
@d-alvrzx You do not have to erase flash everytime you upload new firmware. Only if you think the flash is corrupted.
Besides that there is the -c option which you could try. -
@robert-hh Thanks for the mention of the
-coption! I did not know this, but it works! No more resets needed between commands.And yes, I understand that I do not need to erase the flash every time I load a new firmware. But my example was trying to show that any 2 commands in a row had the same behaviour, for example:
- Run
pycom-fwtool-cli -p COM7 lpwan- The correct output is shown, with the
SMAC,SID,PACandLORA REGION
- Run
pycom-fwtool-cli -p COM7 lpwanonce again, without resetting LoPy- The same error occurs:
Now, with the
-coption enabled, the procedure above works! Thanks so much! - Run
