    FiPy without pymakr
    2 Posts 2 Posters 21 Views 2 Watching
      paul_tanner
      Have a simple program running on FiPy loaded via atom/ prymakr
      I can disconnect from there and re-connect via MacOS/screen ay 115200
      It works until disconnected or reset pressed.
      However, on reset I get:
        File "main.py", line 35
      SyntaxError: invalid syntax
      The simple program only has 21 lines so this is strange. Obviously the device when in real life will need to operate without a connection to pymakr.
        The python code should work the same with or without Pymakr. Are you clicking the 'play' button or the 'upload' button in Pymakr when running the program? (The first will only send the lines, while the latter will save it to a file on the device, allowing it to run after reset)
        Let me know!
