Upload failed: timeout. Please reboot your device manually.
I am using a lopy4 on a Pysense v1.1. When I try to upload the RGB blink tutorial code to the board, I got this error. The firmware on both the LoPy4 and Pysense is updated, and it seems that the device is connected to the PC correctly. And the address in pymakr.conf is changed to the correct port (COM11)
Press CTRL+C 2 times
Get console
and Update -
Took about 3 hours to figure out, but I found this solution online here: https://docs-mk2.readthedocs.io/en/latest/gettingstarted/programming/safeboot/#safe-boot-1
We have the same page here: https://docs.pycom.io/gettingstarted/programming/safeboot/
If you can perhaps recommend a better location, let me know!
