Pybytes pymesh integration issues
I have 3 devices that I performed firmware updates and added to pybytes, the firmware loaded was
Pycom MicroPython 1.20.2.r1 [v1.11-a5aa0b8] on 2020-09-09; LoPy4 with ESP32
Pybytes Version: 1.6.0They showed up successfully on Pybytes.
I've then tried to setup a pymesh based on the instructions in the documentation https://docs.pycom.io/pybytes/pymeshintegration/
When I select Deploy Mesh I see the following error on two of the devices, the third is looks to be ok.
>>> Pymesh configuration written to /flash/pymesh_config.json Requesting: manifest.json?current_ver=1.20.2.r1&sysname=LoPy4&token=xxxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx&ota_slot=0x210000&wmac=3C71BFxxxxxx&fwtype=pymesh¤t_fwtype=pybytes to software.pycom.io:443 with SSL? True Wrapping socket Sending request Error reading the manifest, aborting: syntax error in JSONOn the third device that has the firmware, I then see the error:
rst:0x7 (TG0WDT_SYS_RESET),boot:0x16 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8020,len:8 load:0x3fff8028,len:2140 ho 0 tail 12 room 4 load:0x4009fa00,len:19760 entry 0x400a05bc WMAC: 30AEA477A8E8 Firmware: 1.20.2.rc11 Pybytes: 1.5.2 Initialized watchdog for WiFi and LTE connection with timeout 1260000 ms WiFi connection established Connected to MQTT mqtt.pybytes.pycom.io Pybytes connected successfully (using the built-in pybytes library) Pybytes configuration read from /flash/pybytes_config.json Traceback (most recent call last): File "main.py", line 35, in <module> File "/flash/lib/pymesh.py", line 57, in __init__ File "/flash/lib/mesh_interface.py", line 56, in __init__ File "/flash/lib/mesh_internal.py", line 123, in __init__ File "/flash/lib/loramesh.py", line 73, in __init__ File "/flash/lib/loramesh.py", line 122, in _lora_init AttributeError: 'Loramesh' object has no attribute 'mesh' Pycom MicroPython 1.20.2.rc11 [v1.11-f4d850b] on 2020-07-08; LoPy4 with ESP32 Pybytes Version: 1.5.2 Pymesh Version: 1.0.1 Type "help()" for more information. >>>It also looks like the firmware on this third device has been downgraded as part of the mesh deployment.
Any answers as to what is going on here and why it seems to downgrade one of the devices and not find the pymesh firmware?
Andrew
@alipsilc That seemed to work in getting all the nodes on the same downgraded firmware.
Working through other issues and which example to use for each node before making them do something more interesting.
Andrew
@thinginnovations said in Pybytes pymesh integration issues:
aded as part
Hi!
The Pymesh firmware was created using the Pybytes version 1.5.2 and not updated yet.
To workaround the deployment issue, at the Pymesh tab, can you please select the devices, remove devices, and add devices again, then deploy Pymesh one more time?
Thank you!
