Simpoint CAT-M1 through KPN in Germany
  • Hello together,
    I got a simcard from Simpoint and wanted to try, If I can get LTE-M connectivity with that one too in Germany, so that there is an alternative to 1nce.
    Simpoint offering CAT-M1 through KPN
    I got the following firmware for my GPy:
    >>> import sqnsupgrade
    >>> sqnsupgrade.info()
    <<< Welcome to the SQN3330 firmware updater [1.2.6] >>>
    >>> GPy with firmware version 1.20.2.r3
    UE5.0.0.0d
    LR5.1.1.0-47510
    The APN is simpoint.m2m. I've tried both methods with only lte.attach() and using the actual APN, but no success with a connection while I have a really great signal.
    try:
        #lte.attach()
        lte.attach(apn="simpoint.m2m")
        while not lte.isattached():
            time.sleep(1)
            print('.', end='') # indicates new loop iteration in Terminal output
            print(lte.send_at_cmd('AT!="fsm"'))
            print(lte.send_at_cmd("AT+CSQ"))
        print("[LTE] attached")
    except:
        print("[LTE] attach() (except). Reset board ...")
        machine.reset()
    I don't know, where the issue is. Does anybody have some advice?
    SYSTEM FSM
        | RRC TOP FSM              |CAMPED              |
        | RRC SEARCH FSM           |CAMPED              |
        | RRC ACTIVE FSM           |IDLE                |
        | PMM PLMN FSM             |NORM_CAMPED         |
    OK
    +CSQ: 10,99
    OK
    SYSTEM FSM
    OK
    +CSQ: 10,99
    OK
    SYSTEM FSM
    OK
    +CSQ: 10,99
    OK
    SYSTEM FSM
    OK
    +CSQ: 11,99
    OK
1 out of 1
