Don't know why is giving an error
Hi all
I have this code to read some sensors (could be a goor guide for newbies like me)
Now is working perfecte, but when I triying to add Sigfox the code returns an error:Code without Sigfox:
import machine import bme280_float as bme280 import time from machine import Pin from machine import ADC from ds18x20 import DS18X20 from onewire import OneWire import pycom # from network import Sigfox # import socket def read_bme280(): # this script assumes the default connection of the I2C bus # On pycom devuces that is P9 = SDA, P10 = scl # print('**************Reading BME280**************') # i2c = machine.I2C() # bme = bme280.BME280(i2c=i2c) # print(bme.read_compensated_data()) # print(bme.dew_point) i2c = machine.I2C() bme = bme280.BME280(i2c=i2c) Values= bme.values tempbme=res = ''.join(filter(lambda i: i.isdigit(), Values[0])) tempbme280=int(tempbme)/100 print(tempbme280) pressbme=res = ''.join(filter(lambda i: i.isdigit(), Values[1])) pressbme280=int(pressbme)/100 print(pressbme280) humbme=res = ''.join(filter(lambda i: i.isdigit(), Values[2])) humbme280=int(humbme)/100 print(humbme280) print('**************End of Reading BME280**************') def read_analogs(): print('**************Reading moisture **************') adc = machine.ADC() # create an ADC object adc.init(bits=12) soilmoisture = adc.channel(pin='P13', attn = machine.ADC.ATTN_11DB) # create an analog pin on P13, range 0..3.3V print('moisture raw: ') print (soilmoisture()) print('**************End of Reading moisture **************') print('**************Reading Battery **************') adc = ADC() # Set calibration - see note above adc.vref(1100) # Check calibration by reading a known voltage adc_c = adc.channel(pin='P16', attn=ADC.ATTN_11DB) print('Battery raw: ') print(adc_c.voltage()) print('**************End of Reading Battery **************') def read_ds18X20(): print('**************Reading DS18X20 **************') #DS18B20 data line connected to pin P10 ow = OneWire(Pin('P10')) temp = DS18X20(ow) print("Powermode = ", temp.powermode(Pin('P11'))) roms = temp.scan() temp.resolution(roms[0], 9) print("Resolution", temp.resolution(roms[0])) temp.convert_temp() contador_DS18X20 = 0 temp_Acc=0 temp_moisture=0 while contador_DS18X20 <5: time.sleep(1.5) for rom in roms: print(temp.read_temp(rom), end=" ") print() temp.convert_temp() temp_Acc =(temp.read_temp(rom) + temp_Acc) temp_moisture=temp_Acc/5 contador_DS18X20 +=1 print (contador_DS18X20) print (temp_Acc) print (temp_moisture) print ('---------') print('**************End of Reading DS18X20 **************') time.sleep(1) read_bme280() time.sleep(1) read_analogs() time.sleep(1) read_ds18X20()
And now when I want to import the libraries to activate Sigfox returns an error:
from network import Sigfox import socket import machine import bme280_float as bme280 import time from machine import Pin from machine import ADC from ds18x20 import DS18X20 from onewire import OneWire # import pycom # from network import Sigfox # import socket def read_bme280(): # this script assumes the default connection of the I2C bus # On pycom devuces that is P9 = SDA, P10 = scl # print('**************Reading BME280**************') # i2c = machine.I2C() # bme = bme280.BME280(i2c=i2c) # print(bme.read_compensated_data()) # print(bme.dew_point) i2c = machine.I2C() bme = bme280.BME280(i2c=i2c) Values= bme.values tempbme=res = ''.join(filter(lambda i: i.isdigit(), Values[0])) tempbme280=int(tempbme)/100 print(tempbme280) pressbme=res = ''.join(filter(lambda i: i.isdigit(), Values[1])) pressbme280=int(pressbme)/100 print(pressbme280) humbme=res = ''.join(filter(lambda i: i.isdigit(), Values[2])) humbme280=int(humbme)/100 print(humbme280) print('**************End of Reading BME280**************') def read_analogs(): print('**************Reading moisture **************') adc = machine.ADC() # create an ADC object adc.init(bits=12) soilmoisture = adc.channel(pin='P13', attn = machine.ADC.ATTN_11DB) # create an analog pin on P13, range 0..3.3V print('moisture raw: ') print (soilmoisture()) print('**************End of Reading moisture **************') print('**************Reading Battery **************') adc = ADC() # Set calibration - see note above adc.vref(1100) # Check calibration by reading a known voltage adc_c = adc.channel(pin='P16', attn=ADC.ATTN_11DB) print('Battery raw: ') print(adc_c.voltage()) print('**************End of Reading Battery **************') def read_ds18X20(): print('**************Reading DS18X20 **************') #DS18B20 data line connected to pin P10 ow = OneWire(Pin('P10')) temp = DS18X20(ow) print("Powermode = ", temp.powermode(Pin('P11'))) roms = temp.scan() temp.resolution(roms[0], 9) print("Resolution", temp.resolution(roms[0])) temp.convert_temp() contador_DS18X20 = 0 temp_Acc=0 temp_moisture=0 while contador_DS18X20 <5: time.sleep(1.5) for rom in roms: print(temp.read_temp(rom), end=" ") print() temp.convert_temp() temp_Acc =(temp.read_temp(rom) + temp_Acc) temp_moisture=temp_Acc/5 contador_DS18X20 +=1 print (contador_DS18X20) print (temp_Acc) print (temp_moisture) print ('---------') print('**************End of Reading DS18X20 **************') time.sleep(1) read_bme280() time.sleep(1) read_analogs() time.sleep(1) read_ds18X20() # time.sleep(1)
It crashes, any idea why? thank very very much
**************End of Reading Battery ************** **************Reading DS18X20 ************** Powermode = 0 Traceback (most recent call last): File "main.py", line 101, in <module> File "main.py", line 68, in read_ds18X20 IndexError: list index out of range Pycom MicroPython 1.20.2.r1 [v1.11-a5aa0b8] on 2020-09-09; SiPy with ESP32 Pybytes Version: 1.6.0 Type "help()" for more information. >>>
@ecabanas Python almost tells you where the problem is. Check line 68, looks like your array "roms" is empty. Go back from there. Also, always try to reduce your example to a minimum example that fails (just a few lines of code), this increases the probability for someone to help you.
