Pygate - ethernet reliability issues
Good to hear the issue got solved!
I believe there are still people out there that do have problems with the PyEthernet dropping the connection, so thanks for your take on the situation!
Also good to hear the TTN configuration works better for you. I will work on putting this in the docs!
Gijs -
@Gijs Dear Pycom,
I have got a new Pygate, Wipy & POE module connected and fully updated to the latest (stable) firmware as of this evening.
I am using a 5V 2.5A USB power supply connected to the USB-C port of the PyGate.
There is an ethernet connection to a 1Gbps switch on my desk which works perfectly fine with other devices.
I am having this code in my device:[jaap@jaap ~ ]$ curl ftp://micro:python@10.0.0.99/flash/boot.py # boot.py -- run on boot-up from network import ETH e = ETH() e.ifconfig(config=('10.0.0.99', '255.255.0.0', '10.0.0.1', '10.0.0.1'))[jaap@jaap ~ ]$ curl ftp://micro:python@10.0.0.99/flash/main.py # main.py -- put your code here!No more. No gateway yet.
Now I am seeing this erratic behaviour:
[jaap@jaap ~ ]$ ping 10.0.0.99 PING 10.0.0.99 (10.0.0.99) 56(84) bytes of data. 64 bytes from 10.0.0.99: icmp_seq=6 ttl=255 time=1.94 ms 64 bytes from 10.0.0.99: icmp_seq=7 ttl=255 time=1.88 ms 64 bytes from 10.0.0.99: icmp_seq=20 ttl=255 time=35.6 ms 64 bytes from 10.0.0.99: icmp_seq=21 ttl=255 time=2.23 ms 64 bytes from 10.0.0.99: icmp_seq=22 ttl=255 time=1.94 ms 64 bytes from 10.0.0.99: icmp_seq=23 ttl=255 time=1.94 ms 64 bytes from 10.0.0.99: icmp_seq=24 ttl=255 time=1.90 ms 64 bytes from 10.0.0.99: icmp_seq=25 ttl=255 time=1.96 ms 64 bytes from 10.0.0.99: icmp_seq=26 ttl=255 time=1.77 ms 64 bytes from 10.0.0.99: icmp_seq=27 ttl=255 time=1.94 ms 64 bytes from 10.0.0.99: icmp_seq=28 ttl=255 time=1.92 ms 64 bytes from 10.0.0.99: icmp_seq=29 ttl=255 time=1.95 ms 64 bytes from 10.0.0.99: icmp_seq=30 ttl=255 time=1.90 ms 64 bytes from 10.0.0.99: icmp_seq=31 ttl=255 time=1.94 ms 64 bytes from 10.0.0.99: icmp_seq=32 ttl=255 time=1.94 ms 64 bytes from 10.0.0.99: icmp_seq=33 ttl=255 time=1.94 ms 64 bytes from 10.0.0.99: icmp_seq=34 ttl=255 time=1.94 ms 64 bytes from 10.0.0.99: icmp_seq=35 ttl=255 time=1.90 ms 64 bytes from 10.0.0.99: icmp_seq=36 ttl=255 time=1.92 ms 64 bytes from 10.0.0.99: icmp_seq=37 ttl=255 time=12.0 ms 64 bytes from 10.0.0.99: icmp_seq=38 ttl=255 time=34.9 ms 64 bytes from 10.0.0.99: icmp_seq=39 ttl=255 time=57.0 ms 64 bytes from 10.0.0.99: icmp_seq=40 ttl=255 time=80.0 ms 64 bytes from 10.0.0.99: icmp_seq=41 ttl=255 time=7.20 ms 64 bytes from 10.0.0.99: icmp_seq=42 ttl=255 time=5.80 ms 64 bytes from 10.0.0.99: icmp_seq=44 ttl=255 time=142 ms 64 bytes from 10.0.0.99: icmp_seq=45 ttl=255 time=6.89 ms 64 bytes from 10.0.0.99: icmp_seq=46 ttl=255 time=188 ms 64 bytes from 10.0.0.99: icmp_seq=47 ttl=255 time=7378 ms 64 bytes from 10.0.0.99: icmp_seq=48 ttl=255 time=7243 ms 64 bytes from 10.0.0.99: icmp_seq=49 ttl=255 time=7204 ms 64 bytes from 10.0.0.99: icmp_seq=55 ttl=255 time=7971 ms 64 bytes from 10.0.0.99: icmp_seq=59 ttl=255 time=7729 ms 64 bytes from 10.0.0.99: icmp_seq=60 ttl=255 time=7906 ms 64 bytes from 10.0.0.99: icmp_seq=62 ttl=255 time=7935 ms 64 bytes from 10.0.0.99: icmp_seq=72 ttl=255 time=7772 ms 64 bytes from 10.0.0.99: icmp_seq=73 ttl=255 time=8232 ms 64 bytes from 10.0.0.99: icmp_seq=74 ttl=255 time=8203 ms 64 bytes from 10.0.0.99: icmp_seq=75 ttl=255 time=8165 ms 64 bytes from 10.0.0.99: icmp_seq=76 ttl=255 time=8636 ms 64 bytes from 10.0.0.99: icmp_seq=77 ttl=255 time=8595 ms 64 bytes from 10.0.0.99: icmp_seq=78 ttl=255 time=8449 ms 64 bytes from 10.0.0.99: icmp_seq=82 ttl=255 time=8755 ms 64 bytes from 10.0.0.99: icmp_seq=89 ttl=255 time=8752 ms 64 bytes from 10.0.0.99: icmp_seq=90 ttl=255 time=8712 ms 64 bytes from 10.0.0.99: icmp_seq=92 ttl=255 time=8642 ms 64 bytes from 10.0.0.99: icmp_seq=95 ttl=255 time=8353 ms 64 bytes from 10.0.0.99: icmp_seq=96 ttl=255 time=8306 ms 64 bytes from 10.0.0.99: icmp_seq=97 ttl=255 time=8159 ms 64 bytes from 10.0.0.99: icmp_seq=100 ttl=255 time=8235 ms 64 bytes from 10.0.0.99: icmp_seq=101 ttl=255 time=8275 ms From 10.0.1.3 icmp_seq=109 Destination Host Unreachable From 10.0.1.3 icmp_seq=110 Destination Host Unreachable From 10.0.1.3 icmp_seq=111 Destination Host Unreachable 64 bytes from 10.0.0.99: icmp_seq=105 ttl=255 time=8333 ms 64 bytes from 10.0.0.99: icmp_seq=106 ttl=255 time=8304 ms 64 bytes from 10.0.0.99: icmp_seq=107 ttl=255 time=8254 ms 64 bytes from 10.0.0.99: icmp_seq=112 ttl=255 time=10331 ms 64 bytes from 10.0.0.99: icmp_seq=113 ttl=255 time=9633 ms ^C --- 10.0.0.99 ping statistics --- 122 packets transmitted, 56 received, +3 errors, 54.0984% packet loss, time 123939ms rtt min/avg/max/mdev = 1.770/4161.969/10331.318/4164.290 ms, pipe 11 [jaap@jaap ~ ]$How to debug this?
@Jaap-Crezee Have you tried setting
wifi_on_boot(false)? Though this could possibly explain the initial packet loss, but probably not the 8 second latency and later packet loss!Also I believe Pygate builds don't include Pybytes, but if they do,
pybytes_on_boot(false)would be a good idea.It would probably be interesting to run a simple UDP client+server to check in which direction the packet loss/latency occurs.
Is the Ethernet switch managed? Do you see any errors or link bounces on that?
@Jaap-Crezee We are (sort of) aware of this issue and we can reproduce it, but we have not been able to ' trigger' slow ping times on demand. My colleague @peterp looked into this for a long time, but we could not pinpoint the cause of it. In our case, it takes hours or even days before it gets into this state when pinging the device. It seems yours gets in this state of slow ping responses relatively quickly. Now the only difference between your setup and ours, is in the network infrastructure (I believe), making me believe the issue can be found there.
The suggestions of @jcaron sound like a good place to start (I think we evaluated that as well, but I dont remember the outcome exactly). We tried a whole assortment of solutions but none have resulted in a proper triggered reproduction.
Note that we are not able to reproduce it when using the product as it was meant to be (A LoRa gateway connected through wired internet / PoE), only when we are throwing pings at it.
Let me know if you have any suggestions!
Gijs -
Thank you for your inputs. I will try the two disable commands. Could it also be related to receiving a lot of UDP broadcast messages?
I am on a noisy network. I could also try moving to a less noisy network (although I would argue that a device should not get slower by receiving some broadcasts; we are talking about 0.5-1kbyte/s here.). And we are not always in control of the networks we should be connecting to.
I will get back once I have some results. -
We had some good experiences with that, but it did not resolve the issue completely. We also tried simulating a noisy network here, but that did not 'improve' our slow-ping time starting delay unfortunately
Let me know of your results!
Gijs -
@Gijs @peterp @jcaron I tried both wifi_on_boot & pybytes_on_boot without any difference, unfortunately.
I am not only seeing ICMP "slowness", FTP is also very slow as is telnet which makes me suspicious about the network functionality in general:[jaap@jaap /data/work/gateway ]$ wget ftp://micro:python@10.0.0.99/flash/boot.py --2020-11-20 22:12:43-- ftp://micro:*password*@10.0.0.99/flash/boot.py => 'boot.py.1' Connecting to 10.0.0.99:21... connected. Logging in as micro ... Logged in! ==> SYST ... done. ==> PWD ... done. ==> TYPE I ... done. ==> CWD (1) /flash ... done. ==> SIZE boot.py ... 233 ==> PASV ... done. ==> RETR boot.py ... done. Length: 233 (unauthoritative) boot.py.1 100%[=================================================================================================================================================================================================>] 233 --.-KB/s in 0.02s 2020-11-20 22:14:24 (14.2 KB/s) - 'boot.py.1' saved [233] [jaap@jaap /data/work/gateway ]$Almost 2 minutes fetching a file of 233 bytes (!?!).
64 bytes from 10.0.0.99: icmp_seq=176 ttl=255 time=696 ms 64 bytes from 10.0.0.99: icmp_seq=177 ttl=255 time=849 ms 64 bytes from 10.0.0.99: icmp_seq=178 ttl=255 time=872 ms 64 bytes from 10.0.0.99: icmp_seq=181 ttl=255 time=1681 ms 64 bytes from 10.0.0.99: icmp_seq=183 ttl=255 time=1630 ms 64 bytes from 10.0.0.99: icmp_seq=185 ttl=255 time=1208 ms 64 bytes from 10.0.0.99: icmp_seq=186 ttl=255 time=1004 ms 64 bytes from 10.0.0.99: icmp_seq=187 ttl=255 time=1301 ms 64 bytes from 10.0.0.99: icmp_seq=190 ttl=255 time=1541 ms 64 bytes from 10.0.0.99: icmp_seq=191 ttl=255 time=1478 ms 64 bytes from 10.0.0.99: icmp_seq=192 ttl=255 time=1310 ms 64 bytes from 10.0.0.99: icmp_seq=194 ttl=255 time=1319 ms 64 bytes from 10.0.0.99: icmp_seq=195 ttl=255 time=2241 ms 64 bytes from 10.0.0.99: icmp_seq=196 ttl=255 time=2537 ms 64 bytes from 10.0.0.99: icmp_seq=198 ttl=255 time=1766 ms 64 bytes from 10.0.0.99: icmp_seq=199 ttl=255 time=1489 ms 64 bytes from 10.0.0.99: icmp_seq=200 ttl=255 time=1457 ms 64 bytes from 10.0.0.99: icmp_seq=205 ttl=255 time=1785 ms 64 bytes from 10.0.0.99: icmp_seq=206 ttl=255 time=2072 ms 64 bytes from 10.0.0.99: icmp_seq=207 ttl=255 time=1369 ms 64 bytes from 10.0.0.99: icmp_seq=208 ttl=255 time=1272 ms 64 bytes from 10.0.0.99: icmp_seq=209 ttl=255 time=1272 ms 64 bytes from 10.0.0.99: icmp_seq=210 ttl=255 time=1273 ms 64 bytes from 10.0.0.99: icmp_seq=211 ttl=255 time=2153 ms 64 bytes from 10.0.0.99: icmp_seq=212 ttl=255 time=2333 ms 64 bytes from 10.0.0.99: icmp_seq=213 ttl=255 time=1342 ms 64 bytes from 10.0.0.99: icmp_seq=214 ttl=255 time=1342 ms 64 bytes from 10.0.0.99: icmp_seq=215 ttl=255 time=1342 ms 64 bytes from 10.0.0.99: icmp_seq=216 ttl=255 time=1289 ms 64 bytes from 10.0.0.99: icmp_seq=217 ttl=255 time=1289 ms 64 bytes from 10.0.0.99: icmp_seq=218 ttl=255 time=1288 ms 64 bytes from 10.0.0.99: icmp_seq=219 ttl=255 time=2212 ms 64 bytes from 10.0.0.99: icmp_seq=220 ttl=255 time=2378 ms 64 bytes from 10.0.0.99: icmp_seq=221 ttl=255 time=1406 ms 64 bytes from 10.0.0.99: icmp_seq=222 ttl=255 time=1401 ms 64 bytes from 10.0.0.99: icmp_seq=223 ttl=255 time=1410 ms 64 bytes from 10.0.0.99: icmp_seq=224 ttl=255 time=1305 ms 64 bytes from 10.0.0.99: icmp_seq=225 ttl=255 time=1229 ms 64 bytes from 10.0.0.99: icmp_seq=226 ttl=255 time=1240 ms 64 bytes from 10.0.0.99: icmp_seq=227 ttl=255 time=2055 ms 64 bytes from 10.0.0.99: icmp_seq=228 ttl=255 time=2113 ms 64 bytes from 10.0.0.99: icmp_seq=231 ttl=255 time=1369 ms 64 bytes from 10.0.0.99: icmp_seq=232 ttl=255 time=1248 ms 64 bytes from 10.0.0.99: icmp_seq=233 ttl=255 time=1246 ms 64 bytes from 10.0.0.99: icmp_seq=234 ttl=255 time=1245 ms 64 bytes from 10.0.0.99: icmp_seq=235 ttl=255 time=2209 ms 64 bytes from 10.0.0.99: icmp_seq=239 ttl=255 time=1232 ms 64 bytes from 10.0.0.99: icmp_seq=241 ttl=255 time=1216 ms 64 bytes from 10.0.0.99: icmp_seq=242 ttl=255 time=1211 ms 64 bytes from 10.0.0.99: icmp_seq=247 ttl=255 time=1991 ms 64 bytes from 10.0.0.99: icmp_seq=248 ttl=255 time=1860 ms 64 bytes from 10.0.0.99: icmp_seq=249 ttl=255 time=1487 ms ^C --- 10.0.0.99 ping statistics --- 251 packets transmitted, 149 received, +1 duplicates, 40.6375% packet loss, time 255131ms rtt min/avg/max/mdev = 1.551/941.478/2536.884/553.739 ms, pipe 3 [jaap@jaap ~ ]$Here is my new boot.py
# boot.py -- run on boot-up import pycom import machine from network import ETH pycom.wifi_on_boot(False) pycom.pybytes_on_boot(False) e = ETH() e.ifconfig(config=('10.0.0.99', '255.255.0.0', '10.0.0.1', '10.0.0.1'))I can hardly believe this problem could be solved by adding more code, like a fully configured LoraWan gateway.
Having said that, if that does help anyway, we are seeing some kind of race- or timing-condition issue.
Either one should probably be investigated in more detail, identified, and fixed somehow. Because currently, this prevents me from determining if the Pycom hardware (& software) would be a viable solution for us; it should provide stable LoraWan gateway functionality.PS the switch is a "normal" unmanaged TP-Link TL-SG103 8 port 10/100/1000Mbps switch which has proven to be stable for any device which I connected to it the last two years until I connected this pygate + pycom + poe module.
I have tried multiple cables which are known to be okay.
PS2 I somewhat recognize this behavior from previous projects involving an Arduino & ENC28J60 SPI ethernet Module... -
@Jaap-Crezee you may want to try a direct connection to your computer to see what happens if there’s no (or little, some computers can be quite chatty) other traffic. You would also probably get information about Ethernet issues via ifconfig stats. I would also run a tcpdump during the ping tests to see if there’s anything else going on.
Mmmmmhhh just wondering if we’re not faced with a good old duplex negotiation issue. Haven’t seen one in nearly two decades, but a mixup between half and full duplex can lead to similar terrible performance. Not quite sure it would lead to that weird latency, though.
Otherwise it could be quite a long debug. As stated above, I would start by trying to determine if the issue is on the RX or TX side, by either switching on Ethernet on the WiPy or using a simple UDP echo sever with logging, to see if the delay (and loss) happens on one side or the other.
After that... there are quite a few places where there could be issues so it’s going to be quite some work to pinpoint it. I’m really puzzled by the recurring 7-8 second latency though. I have a hard time trying to guess where that could possibly come from.
@jcaron @gijs @peterp
I tried another network on an (much) older sitecom 10/100mbps switch connected to my computer on a different ethernet port.
That network does not have the noise which is present on my "normal" office lan.I am now seeing this:
64 bytes from 192.168.0.2: icmp_seq=386 ttl=255 time=1.93 ms 64 bytes from 192.168.0.2: icmp_seq=387 ttl=255 time=1.93 ms 64 bytes from 192.168.0.2: icmp_seq=388 ttl=255 time=1.90 ms 64 bytes from 192.168.0.2: icmp_seq=389 ttl=255 time=1.93 ms 64 bytes from 192.168.0.2: icmp_seq=390 ttl=255 time=1.93 ms 64 bytes from 192.168.0.2: icmp_seq=391 ttl=255 time=1.93 ms 64 bytes from 192.168.0.2: icmp_seq=392 ttl=255 time=1.92 ms 64 bytes from 192.168.0.2: icmp_seq=393 ttl=255 time=1.96 ms 64 bytes from 192.168.0.2: icmp_seq=394 ttl=255 time=1.92 ms # <== until here it worked without any of the previous problems; 64 bytes from 192.168.0.2: icmp_seq=395 ttl=255 time=1.92 ms # <== at this point in time I attach my other LAN to the sitecom switch 64 bytes from 192.168.0.2: icmp_seq=413 ttl=255 time=1.29 ms # <== here I disconnect that cable 64 bytes from 192.168.0.2: icmp_seq=414 ttl=255 time=1.90 ms 64 bytes from 192.168.0.2: icmp_seq=415 ttl=255 time=1.90 ms 64 bytes from 192.168.0.2: icmp_seq=416 ttl=255 time=2.14 ms 64 bytes from 192.168.0.2: icmp_seq=417 ttl=255 time=1.69 ms 64 bytes from 192.168.0.2: icmp_seq=418 ttl=255 time=1.91 ms 64 bytes from 192.168.0.2: icmp_seq=419 ttl=255 time=1.91 ms 64 bytes from 192.168.0.2: icmp_seq=420 ttl=255 time=1.93 ms 64 bytes from 192.168.0.2: icmp_seq=421 ttl=255 time=1.91 ms 64 bytes from 192.168.0.2: icmp_seq=422 ttl=255 time=1.92 ms 64 bytes from 192.168.0.2: icmp_seq=423 ttl=255 time=1.91 ms 64 bytes from 192.168.0.2: icmp_seq=424 ttl=255 time=1.30 ms 64 bytes from 192.168.0.2: icmp_seq=425 ttl=255 time=1.94 ms # <== at this point in time I attach my other LAN to the sitecom switch again 64 bytes from 192.168.0.2: icmp_seq=434 ttl=255 time=1.31 ms # <== here I disconnect that cable again 64 bytes from 192.168.0.2: icmp_seq=435 ttl=255 time=2.10 ms 64 bytes from 192.168.0.2: icmp_seq=436 ttl=255 time=1.93 ms ^C --- 192.168.0.2 ping statistics --- 436 packets transmitted, 372 received, +36 errors, 14.6789% packet loss, time 438231ms rtt min/avg/max/mdev = 1.186/3.154/419.886/21.812 ms, pipe 3 [jaap@jaap ~ ]$This makes me believe for at least 90% this is actually a software issue somewhere in the pygate/pycom module related to incoming network traffic.
Doesn't this still ring a bell? I could potentially debug this, but there is currently not enough datasheet information available about components used, especially the POE module. I couldn't even find information regarding the required POE voltage and typical current usages. But that's a bit offtopic for now.PS 15 minutes later without the other lan:
[jaap@jaap ~ ]$ ping 192.168.0.2 PING 192.168.0.2 (192.168.0.2) 56(84) bytes of data. 64 bytes from 192.168.0.2: icmp_seq=1 ttl=255 time=129 ms 64 bytes from 192.168.0.2: icmp_seq=2 ttl=255 time=1.22 ms 64 bytes from 192.168.0.2: icmp_seq=3 ttl=255 time=1.88 ms 64 bytes from 192.168.0.2: icmp_seq=4 ttl=255 time=1.92 ms 64 bytes from 192.168.0.2: icmp_seq=5 ttl=255 time=1.93 ms 64 bytes from 192.168.0.2: icmp_seq=6 ttl=255 time=1.95 ms 64 bytes from 192.168.0.2: icmp_seq=7 ttl=255 time=1.93 ms 64 bytes from 192.168.0.2: icmp_seq=8 ttl=255 time=1.93 ms 64 bytes from 192.168.0.2: icmp_seq=9 ttl=255 time=1.91 ms 64 bytes from 192.168.0.2: icmp_seq=10 ttl=255 time=1.96 ms 64 bytes from 192.168.0.2: icmp_seq=11 ttl=255 time=1.92 ms 64 bytes from 192.168.0.2: icmp_seq=12 ttl=255 time=1.92 ms 64 bytes from 192.168.0.2: icmp_seq=13 ttl=255 time=1.91 ms 64 bytes from 192.168.0.2: icmp_seq=14 ttl=255 time=1.91 ms 64 bytes from 192.168.0.2: icmp_seq=15 ttl=255 time=1.92 ms 64 bytes from 192.168.0.2: icmp_seq=16 ttl=255 time=1.92 ms 64 bytes from 192.168.0.2: icmp_seq=17 ttl=255 time=1.91 ms 64 bytes from 192.168.0.2: icmp_seq=18 ttl=255 time=1.92 ms 64 bytes from 192.168.0.2: icmp_seq=19 ttl=255 time=1.93 ms 64 bytes from 192.168.0.2: icmp_seq=20 ttl=255 time=1.62 ms 64 bytes from 192.168.0.2: icmp_seq=21 ttl=255 time=1.93 ms 64 bytes from 192.168.0.2: icmp_seq=22 ttl=255 time=1.94 ms 64 bytes from 192.168.0.2: icmp_seq=23 ttl=255 time=1.94 ms 64 bytes from 192.168.0.2: icmp_seq=24 ttl=255 time=1.94 ms ^C --- 192.168.0.2 ping statistics --- 24 packets transmitted, 24 received, 0% packet loss, time 23043ms rtt min/avg/max/mdev = 1.219/7.172/128.881/25.378 ms [jaap@jaap ~ ]$@jcaron said in Pygate - ethernet reliability issues:
Do we have some Pycom/python examples at hand to try within 30 seconds?
@Jaap-Crezee This looks like a good starting point. You probably want to add a loop and send a counter in the client, and print the counter on both client (TX and RX) and on the server, with timestamps.
It's regular Python but I don't think there's much to change.
Meanwhile, I investigated a bit further:
It seems RX related.
I come to this conclusion because of the following:
I have a few Lora devices. They can only join the LoraWAN network just after a reset of the Pygate. For joining a LoraWAN network it seems the Lora device should be able to receive a packet back. That stops functioning after a while.
This correlates with ICMP pings getting slower and slower until they timeout and no longer work (and will never work again).
It seems packets no longer arrive at the Pygate, but it can still send data from a (wireless) Lora device to the LoraWAN (TTN) backend. So TX remains operational. I also see this (packet wise) behavior while sniffing the network. I also notice the >>> console getting very slow if this problem is present.With this in mind, I understand people state that the Pygate will remain operational because Lora packets keep arriving at the LoraWAN backbend (TTN for example), but I think this claim is not true in some noisy networks because packets from the backend are not getting back through the Pygate gateway to wireless LoraWAN devices.
Unfortunately, I do not have time to investigate myself in more detail at the moment, but - if desirable - I could produce some excerpts of the broadcast packets which are normally present on my network and which could trigger this problem. -
@schmelpe said in Pygate - ethernet reliability issues:
ok. I can confirm that the PyGate with WiPy3 stops responding to PING requests a few minutes after startup with PoE.
But I can't confirm that the PyGate didn't work anymore. The Gateways status within the TTN Console is updated every 30 Seconds or so for the last 15 days.Hi,
But I can't confirm that the PyGate didn't work anymore. The Gateways status within the TTN Console is updated every 30 Seconds or so for the last 15 days. -
my 2 cents concerning this issue...
I was using an Ethernet cable with the POE adapter, without providing power(POE), and also using a USB cable to power up the PYGATE, .... I had all kind of problems.
Since I removed the USB cable, and replaced it with a POE injector over the Ethernet cable only, .... storm is over.
Regards.
Richard.
Interesting... I'll have to try that for myself, thanks! (also tagging @peterp in this)
@Richard-Martineau said in Pygate - ethernet reliability issues:
Since I removed the USB cable, and replaced it with a POE injector over the Ethernet cable only, .... storm is over.If this helps, I still think it should be fixed without the Po. I do not want to use PoE I just need the E from it..
The only issue I can think of here right now, is that the USB 'communication' is the potential issue here (I cannot see a reason how it would be related to the power distribution of the PoE and USB devices, but you probably know about Murphy's law). Could you perhaps try a USB cable without communication link (or like connected to a powerbank?)
Hi @Richard-Martineau
Over the last weeks we did some tests with the method you describe, but unfortunately no resolution there :( -
