Don't understand fundamental concept of Pymakr and modules
  • I wasn't sure whether to put this in Pymakr or just "Getting Started"...
    I know Python well, but despite reading lots of introductory documentation there is something fundamental that I don't understand. I have Atom and Pymakr running fine. I can load a Python module as main.py and it executes just fine. I can type Python statements to the ">>>" and they work fine too.
    My program will use MQTT, and so I found the module and I have it as umqtt.py. I copied it to .atom/packages/umqtt/umqtt.py
    I have a project that has three files:
    boot.py (empty)
    main.py (38 lines of code)
    lib/umtqq.py (205 lines of code)
    The first few lines of main.py are
    print("Init of main")
    pycom.heartbeat(False)
    pycom.rgbled(0xFF0000)  # Green
    from umqtt import MQTTClient
    from network import WLAN
    So I use Pymakr to
    • Format flash storage
    • With the project selected, Upload Project to Device
    Reading file status
    Creating dir Garage
    Creating dir Garage/lib
    [1/3] Writing file Garage/boot.py (0kb)
    [2/3] Writing file Garage/lib/umqtt.py (6kb)
    [3/3] Writing file Garage/main.py (0kb)
    OKets Jun  8 2016 00:22:57
    configsip: 0, SPIWP:0xee
    mode:DIO, clock div:1
    load:0x3fff8020,len:8
    load:0x3fff8028,len:2140
    ho 0 tail 12 room 4
    load:0x4009fa00,len:19760'''
    That all looks OK to me, but then if I select main.py and click Run I get
    Init of main
      File "<stdin>", line 7, in <module>
    ImportError: no module named 'umqtt'
    Pycom MicroPython 1.20.2.r1 [v1.11-a5aa0b8] on 2020-09-09; WiPy with ESP32
    Pybytes Version: 1.6.0
    So main.py runs and the LED is indeed red, but the import fails. So what am I not understanding about importing modules?
  • This is a classic.
    You have to change your import from
    to
    from lib.umqtt import MQTTClient
    Thit will solve the problem.
    However, I would recommend creating an empty file called __init__.py inside your lib folder. This way you just need to make a reference to the package where your libraries are, like
    from directory.filename import Myclass
    This might be helpful if you need to import something from a directory one level up.
  • @Patrick-Keogh said in Don't understand fundamental concept of Pymakr and modules:
    Garage
    Hi. I suggest you to upload files directly in flash. As I seen in your upload sketch it appears a Garage folder and inside the lib folder and so on.
