    Software watchdog
    7 Posts 4 Posters 183 Views 4 Watching
      Andrea Zauli
      Hi all, I am asking for a suggestion.
      I use a LoPy and need to check if the main task get stuck (don't terminate within a specified time) forcing it to terminate after the timeout happens.
      I tried using software timer, but I am not able to propagate the exception from the Timer's callback to the "stuck" thread, also using sys.exit() doesn't help: the SystemExit exception doesn't propagate to the main thread.
      Any help or idea would be appreciated...
      Many thanks!
        robert-hh @Andrea Zauli
        @Andrea-Zauli There is is always the big hammer called "machine.reset()", which starts the whole device again.
          tuftec
          I use the watchdog reset function. You enable the watchdog function and then keeping feeding the time out timer at various stages during your code. If something goes horribly wrong the watchdog timer expires (dog does not get feed) and forces a reset.
          When your code boots you need to read the reset reason code. If the reason is watchdog timeout you can then do something sensible, like flag an error message.
          I hope this helps.
          Peter.
            Andrea Zauli
            Thanks for the reply. How con I set the watchdog function? Is it a specific timer?
              tuftec @Andrea Zauli
              @Andrea-Zauli Yes!!!
              Read here
              https://docs.pycom.io/firmwareapi/pycom/machine/wdt/
              and here
              Peter.
              • rcolisteteR Offline
                rcolistete
                I suggest a hardware WDT (Watch Dog Timer), like the TPL5010.
                  Andrea Zauli @tuftec
                  @tuftec said in Software watchdog:
                  Read here
                  and here
                  Peter.
                  Many thanks!!
