    socket.error
    Scheduled Pinned Locked Moved Pymakr
    4 Posts 3 Posters 56 Views 3 Watching
    • I Offline
      Ibrahim Salim Omari
      Greetings,
      there seems to be no socket.error nor socket.OSError. How can I trap an error seeing that the socket library has no socket.error clause?
      here's my sample snippet:
          msg = input('Enter message to send : ')
          try :
              # Set the whole string and convert encode the string to bytes
              s.sendto(str.encode(msg), (host, port))
              # receive data from client (data, addr)
              d = s.recvfrom(1024)
              reply = d[0]
              addr = d[1]
              print('Server reply : ' + str(bytes.decode(reply)))  # convert reply to string
          except socket.error:
              print('Error Code : ' + str(msg[0]) + ' Message ' + str(msg[1]))
              sys.exit()
      and the error is:
        File "/lib/udpClient.py", line 32, in <module>
      AttributeError: 'module' object has no attribute 'error'
      The "except socket.error" is the error line
      thanks
      omari
        For me, it works if I use it like this (perhaps you are importing usocket instead of socket?):
        from network import WLAN
        import sys
        wlan = WLAN()
        wlan.mode(WLAN.STA)
        wlan.connect(ssid="",auth=(WLAN.WPA2, "#"))
        print("connecting.",end ='')
        while not wlan.isconnected():
            print(".",end='')
            time.sleep(1)
        print("connected")
        print("WiFi connection established")
        s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
        s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
            msg = 'Enter message to send : '
            try :
                s.sendto(str.encode(msg), ('192.168.4.4', 80))
                reply = d[0]
                addr = d[1]
                sys.exit()
        • I Offline
          Ibrahim Salim Omari
          Which board are you using? I'm using the expressif esp32-wrover-b.
          Your code is no different than mine. Even if I enter it line by line in pymakr repl, I still get an error on: except socket.error.
          From the pymakr prompt, there is no socket.error nor socket.socket.error routine. And yes, I'm importing socket not usocket although I tried it with usocket and got the same error.
          The code runs fine as long as there are no errors at which time the socket.error routine is called.
            MichaelWojcik @Ibrahim Salim Omari
            @Ibrahim-Salim-Omari
            The usocket implementation does not include an form of custom errors. Instead it throws in instance of OSError
            instead of:
            try
            except OSError:
