Error posting data to my server
Hi
I'm using this code to post a json to my server. In Arduino we use HTTP client using this variables:
char server[] = "********.com";
char path[] = "/api/v2/gprs";
int port = 11880;In the request library I changed the default port 80 in HTTP to 11880
urequest.pydef request(method, url, data=None, json=None, headers={}, stream=None): try: proto, dummy, host, path = url.split("/", 3) except ValueError: proto, dummy, host = url.split("/", 2) path = "" if proto == "http:": port = 11880 elif proto == "https:": import ussl port = 443 else: raise ValueError("Unsupported protocol: " + proto)import os import pycom import machine import time import ujson import urequests from network import WLAN wlan = WLAN(mode=WLAN.STA) # Configure first UART bus to see the communication on the pc uart = machine.UART(0, 115200) # Configure second UART bus on pins P3(TX1) and P4(RX1) uart1 = UART(1, baudrate=115200) # 9600 baudrate also causes the same problem # Init WLAN try: wlan.connect(ssid="******", auth=(WLAN.WPA2, "*********")) while not wlan.isconnected(): time.sleep_ms(50) print(wlan.ifconfig()) print("WLAN connection on ...") except: print("[WLAN] try() (except). reset board.") data_set = {"dot":"gsm001","data":{"5":0,"6":999,"7":0,"14":3.0832,"31":0,"32":0,"33":0,"35":22,"38":300,"39":-50,"40":300,"42":300}} jsondump= ujson.dumps(data_set) urequests.request("POST","http://********.com/api/v2/gprs",data = jsondum, None, {"Content-Type": "application/json"},None).textbut I got the following error:
WiFi connection established MQTT ERROR! function got multiple values for argument 'user' ERROR! Could not connect to Pybytes! Pybytes configuration read from /flash/pybytes_config.json Traceback (most recent call last): File "main.py", line 27, in <module> SyntaxError: non-keyword arg after keyword arg Pycom MicroPython 1.20.2.r2 [v1.11-3a7776d] on 2020-11-23; GPy with ESP32Any idea what I'm doing wrong? I'm a newbie in pycom code, sorry
thank's
@ecabanas If you don't use Pybytes you probably want to disable it with
pycom.pybytes_on_boot(False)to avoid confusing messages.The issue is that you have a mix of arguments with explicit names (
name =) and without in your call tourequests.request.Either use names for all args (
method="POST", url="...", data=jsondum, json=None, headers={"Content-Type": "application/json"}, stream=None— in which case you can actually skip those where your argument matches the default) or don't use any and just respect the order (i.e. just removedata=). -
Hi @jcaron
WOW!!! thanks now is working perfect!!!Thanks again!!!
