    New firmware release 1.4.0.b1
    65 Posts 15 Posters 42.3k Views 14 Watching
      livius @Colateral
      @Colateral
      yes i can read data from it but fix is not clear to me - i still can not diagnose what is crux of the problem.
      I can not work with BMP180 alone i must have something more on bus like e.g. light sensor BH1750
      if i reverse sensors initialization order i got always I2C bus error
      it looks like i must write something one to i2c and then i can read from it or vice versa.
      It is not connected with the resistance or the capacitance.
      I do not know if i2c is now hardware or still software implementation
      J C 2 Replies Last reply Reply Quote 0
        jmarcelino @livius
        @livius said in New firmware release 1.4.0.b1:
        i2c is still done in software.
        Is anyone using external pull-up resistors on their I2C? I see the internal ESP32 pull-ups are enabled in the code, but have not seen any reference to what the resistance value is like or attempted to measure it.
          livius @jmarcelino
          @jmarcelino said in New firmware release 1.4.0.b1:
          I tested with and without resistors but "nothing" change
          only reverse order of initialization of sensors help
          difference between sensors is that in light sensor first is memwrite
          in bm180 first is memread
          and problem appear in 1.4 version of firmware - previously all work without any problem
          i do not dig what was changed on esp-idf in the mean time
            Colateral @livius
            @livius Using the same board and connectivity, I can tell you that I succeed to read BME280 (alone) without any resistors or etc.
            I have 2 BMP180 sensors from 2 different providers. BME280 and these 2 sensors, I can read them with Arduino ... but not at all with the PyCom I2C stack. This make me think that something is "nasty" with in the I2C implementation...
            Which rate are did you configured your I2C baudrate in order to read BMP180?
            Using your BMP180, If you run: print(i2c.readfrom_mem(119, 0xD0, 2)) ... can you got the chip id?
              livius @Colateral
              @Colateral
              bus = I2C(0, I2C.MASTER, baudrate=100000, pins=("P19", "P20"))
              return:
              b'U\x02'
              print(ubinascii.hexlify(bus.readfrom_mem(119, 0xD0, 1)))
              b'55'
              print(ubinascii.hexlify(bus.readfrom_mem(119, 0xD0, 2)))
              b'5502'
              and chip revision:
              >>> print(ubinascii.hexlify(bus.readfrom_mem(119,0xd1, 2)))
              b'0206'
              it looks ok 550206
              • 4 / 4
