L01 Baseboard - Removal of Bluetooth Circuit
Hi All,
If Bluetooth Antenna is not required on L01 module, does following circuitry goes away (apart from the yellow line) ?
@omer Bluetooth and WiFi use the same antennas and rf circuitry. The circuits you marked are the ones for switching between board antenna and external antenna. So this circuit can be omitted if you do not want to connect an external antenna.
Thanks Robert for replying
Much appreciated ...
