MRAA and UPM Python3 use
Hello, I will try to make the question mores specific. Any suggestion related to solve this issue is highly appreciated.
This is the situation.
This code works fine, MRAA only :
#!/usr/bin/env python3
import mraa
board_type = mraa.getPlatformType()
print (" Board type", board_type)
board_name = mraa.getPlatformName()
print (" Board name", board_name)
mraa_version = mraa.getVersion()
print (" MRAA Verson = ", mraa_version)
for x in range(0,40):
mraa_pin_name = mraa.getPinName (x)
print (" Pin ", x, " name = ", mraa_pin_name)This code works also fine, MRAA and UPM :
from time import sleep, localtime
DIO = 8
CLK = 7
from upm import _pyupm_tm1637 as TM1637
getVersion = TM1637.getVersion()
print ("Version TM1637 = ",getVersion)This code works not, MRAA and UPM based on UPM examples included with the installation of UPM :
This is the example python code
I tried with and without the _ wto different responses../tm1637.py
File "./tm1637.py", line 27, in <module>
from upm import pyupm_tm1637 as tm1637
ImportError: cannot import name 'pyupm_tm1637' from 'upm' (/usr/lib64/python3.8/site-packages/upm/init.py)./tm1637.py
File "./tm1637.py", line 62, in <module>
main()
File "./tm1637.py", line 37, in mainThe code used (based on the installedexamples during the UPM installation process.)
from future import print_function
import time, signalTwo different tries ...
from upm import -pyupm_tm1637 as tm1637
def main():
# Register exit handler for normal Ctrl+C exit
def SIGINTHandler(signum, frame):
raise SystemExit
signal.signal(signal.SIGINT, SIGINTHandler)# Create a display object on pins 0 CLK and 1 DIO display = tm1637.TM1637(0, 1) dots = True # Get local time myTime = time.localtime(time.time()) print(time.strftime("System time: %H:%M", myTime)) print ("You can adjust your time zone by setting the TZ environment variable.") # Draw a box for 3 seconds using 7-segment encoding display.write(0x39, 0x09, 0x09, 0x0f) time.sleep(3) # Loop indefinitely while True: # Update and display time timeString = time.strftime("%H%M", time.localtime(time.time())) display.write(timeString) # Toggle colon display.setColon(dots) dots = not dots # Sleep for 1 s time.sleep(1)if name == 'main':
main()
