while not wlan.isconnected(): - Infinite Loop
Hi Team,
After the latest update(sysname='LoPy', nodename='LoPy', release='1.5.0.b2', version='v1.8.6-412-gf55ba50 on 2017-01-28', machine='LoPy with ESP32')
The below code is entering into an infinite Loop.Is wlan isConnected not working ?
from network import WLAN from time import sleep_ms wifi_count=1 while not wlan.isconnected(): print('Connecting Wifi attempt-{}'.format(wifi_count)) wlan.connect('XXXX-NetGear', auth=(WLAN.WPA2, 'booboo@123'), timeout=5000) sleep_ms(1000) wifi_count=wifi_count+1 pass
Thanks & regards,
MK HB
@livius Thanks a lot :)
no it is not good
look here for example:
https://docs.pycom.io/pycom_esp32/pycom_esp32/tutorial/includes/wlan.htmlwhile not wlan.isconnected(): machine.idle() # save power while waiting
and questions:
- your router have dhcp enabled?
if not then try setting fixed ip in your LoPY
e.g.
wlan.ifconfig(config=('192.168.1.120', '255.255.255.0', '192.168.1.1', '192.168.1.1'))
- Do you have MAC filtering in your router enabled?
if yes you must add mac of your LoPy
Hi Guys,
If we increase sleep_ms to 5 secs then it works ? Is that the proper way to do this ?Thanks & regards,
MK HB
