crash when running thread
I have the main thread and another thread, available memory whilst both are running is more than 50% free,
Here's the backtrace:
Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled. Register dump: PC : 0x400e9598 PS : 0x00060b30 A0 : 0x800e95ec A1 : 0x3ffe1850 A2 : 0x3ffe43f0 A3 : 0x00000001 A4 : 0x00000000 A5 : 0x3ffe1870 A6 : 0x400dbf40 A7 : 0x3ffc1068 A8 : 0x800e9598 A9 : 0x3ffe1830 A10 : 0x0000000d A11 : 0x00060b23 A12 : 0x00060b20 A13 : 0xb33f0000 A14 : 0xb33fffff A15 : 0x00060923 SAR : 0x00000013 EXCCAUSE: 0x0000001c EXCVADDR: 0x0000001d LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff Backtrace: 0x400e9598:0x3ffe1850 0x400e95ec:0x3ffe1870 0x400dbf50:0x3ffe18a0 0x400e071f:0x3ffe18c0 0x400d7e80:0x3ffe1940 Rebooting... ets Jun 8 2016 00:22:57
Any suggestions on what this is indicating - 'loadProhibited' ?
@jmarcelino - thanks, I am now seeing crashes regularly pretty much when anything that involves interrupts or threads.
I am starting to think that maybe threading is still work in progress ??
You can have an idea of what going on by building micropython from source (from https://github.com/pycom/pycom-micropython) and using gdb or addr2line
Once built go into the build directory (build/WIPY/release) and run:
xtensa-esp32-elf-addr2line -fe application.elf 0x400e9598
My source is modified and I'm running on the LoPy not the WiPy so the result will very likely not not match yours (your build should match exactly what you're running, same version, same options, so ideally run your own build on the WiPy), but just as an example for me it says:
Dev/LoPy/build/pycom-micropython/esp32/../py/parse.c:1027
(but as I explained above this may NOT be the same for you)Another option is to use gdb:
xtensa-esp32-elf-gdb application.elf
Then take your PC (program counter) from your dump:
info symbol 0x400e9598
which should return where in the code it crashed.
mp_parse + 1020 in section .flash.text
If you want to get really deep into it you can also do :
disassemble 0x400e9598
and get a complete disassembly of where the code crashed.
@crankshaft
loadProhibited
is equal to desktopAccess Violation
