    New firmware release 1.5.0.b2
    29 Posts 10 Posters 10.0k Views 11 Watching
      livius @daniel
      @daniel
      confirmed - i2c work :)
        gertjanvanhethof Pybytes Beta
        Finally my i2c is working fine now! Thxs!
        • W Offline
          Wembly
          Will it be possible to deactivate the wifi power save stuff soon ?
          I am unable to keep my sockets as it is today, do not know the root cause yet, but I am guessing that it has something to do with power save.
            @Wembly yes, we'll make that available this week.
              mkharibalaji
              @daniel Believing the i2c issue is resolved in this release,the files are getting synced properly and when i try to open up the file via FileZilla/FireFtp Clients,I am able to see the few lines of code are missing which was not happening before.
              Is it a problem with the PyMakr or in my windows 8.I use the latest version of Pymkar 1.0.0.b8
              (sysname='LoPy', nodename='LoPy', release='1.5.0.b2', version='v1.8.6-412-gf55ba50 on 2017-01-28', machine='LoPy with ESP32')
              Thanks & regards,
              MK HB
                mkharibalaji
                @daniel With the previous post below,the actions taken so far
                And more info I recently formated the flash
                os.mkfs('/flash')
                even then issue persists.
                Thanks & regards,
                MKHB
                  livius @mkharibalaji
                  @mkharibalaji
                  No this is not only pymakr problem
                  same is by filezilla :(
                    Jiemde Pybytes Beta @livius
                    @livius Have the same problem since 10 days now ( cannot test anything :(( )
                      jmarcelino
                      What FTP/Pymakr problem is everyone talking about?
                      You're seeing missing lines in synced files?
                        Jiemde Pybytes Beta @jmarcelino
                        @jmarcelino Exactly!
                          @livius @Jiemde is this something that only occurs with the latest 2 releases?
                          J L 2 Replies Last reply Reply Quote 0
                            Jiemde Pybytes Beta @daniel
                            @daniel Yes, with the 1.0.4.b1 ftp is working without problem and Pymakr only the first time after that the message is "syncing failed"
                            with the new release 1.5.0.b2 ftp seem to working but the transfered file have missing lines.
                            And in Pymakr the message is always "synced sucessfuly" but the same missing line or characters are present
                              @Jiemde thanks, I'll investigate this ASAP.
                                @daniel Many Thanks
                                  livius @daniel
                                  @daniel
                                  Yes, previously was ok (i did not see it)
                                  • K Offline
                                    Knoahlr @daniel
                                    @daniel Hi, should we expect WPA2-enterprise support anytime soon?
                                      leelive @daniel
                                      @daniel Thanks for the increased RAM. Is framebuf going to be added soon?
                                        @leelive yes framebuf will be added when we merge the code with the official MicroPython repository.
                                          cvp
                                          Hi, just new here
                                          Bought Wipy2.0 yesterday, installed and firmware upgraded today, but ifconfig does not work really.
                                          If I put wlan.ifconfig in my boot.py, I can' connect to device on my own network (and DNS is replaced by 0.0.0.0).
                                          If I remove this line, no problem of connection but no fixed IP...
                                            jmarcelino @cvp
                                            @cvp
                                            Could you post your ifconfig line please showing the tulple, like:
                                            wlan.ifconfig(config=('192.168.0.4', '255.255.255.0', '192.168.0.1', '8.8.8.8'))
