Boot.py conf lost
  • Hi,
    I've a strange behavior with the boot.py file. At the boot time, boot.py is executed and connect correctly to my wifi network and returns the IP address, but when I get the REPL prompt, the configuration is lost, isconnected returns false. If I run manually the script, then the connection is fine.
    Thanks for your help
    Laurent
    Scanning for known wifi nets
    Connected to XXXXXXX with IP address:192.168.1.53
    Smart Provisioning started in the background
    See https://docs.pycom.io/smart for details
    Pycom MicroPython 1.20.2.r4 [v1.11-ffb0e1c] on 2021-01-12; LoPy4 with ESP32
    Pybytes Version: 1.6.1
    >>> wl.isconnected()
    False
    >>> Running C:\.........\boot.py
    Connected to XXXXXXXX with IP address: .isconnected()192.168.1.53
    >>> wl.isconnected()
    True
  • @Laurent-Toutain Smart provisioning is the pybytes stuff, which indeed mangles with the communication interfaces. If you do not use pybytes, switch it off.
    pycom.pybytes_on_boot(False).
    If that does not work, create a file on your device called pybytes_config.json and the content:
    {"pybytes_autostart": false}
  • Hi Robert,
    I takes few seconds, in both cases it works, I got the IP address, but when boot.py is started automatically, I lose the information. Note the variable are available from REPL, I can manipulate wl, but the connection is lost. When i start manually it works. Looks like something after the boot.py reset the connection. I don't know what is Smart Provisionning started in the background means.
    Laurent
  • @Laurent-Toutain how long does your boot script for the connection to get established. That may take a few seconds.
4 out of 4
