    Error in the PyScan Pinout document
    21 Posts 3 Posters 110 Views 3 Watching
      gael cobert @robert-hh
      @robert-hh said in Error in the PyScan Pinout document:
      CS
      i put CS in P11
      https://drive.google.com/file/d/12chEnjlWTnu94V6AZnhyeMdt583pmbWF/view?usp=sharing
      and changed the code
      import epaper4in2
      from machine import Pin, SPI
      # SPIV on ESP32
      rst = Pin('P8')
      dc = Pin('P10')
      busy = Pin('P15')
      cs = Pin('P11')
      clk = Pin('P9')
      mosi = Pin('P19')
      spi = SPI(0, mode=SPI.MASTER, baudrate=2000000, polarity=0, phase=0, pins=(clk, mosi, None))
      e = epaper4in2.EPD(spi,cs , dc, rst, busy)
      e.init()
      w = 400
      h = 300
      x = 0
      y = 0
      import framebuf
      buf = bytearray(w * h // 8)
      fb = framebuf.FrameBuffer(buf, w, h, framebuf.MONO_HLSB)
      black = 0
      white = 1
      fb.fill(white)
      print('print hello world')
      fb.fill(white)
      fb.text('Hello World',30,0,black)
      e.display_frame(buf)
        robert-hh @gael cobert
        @gael-cobert Did it work? I'm not sure about using pins on the pyscan. Most of them have multiple labels, and when they are driven by the pyscan itself, they may not be usable.
        Your small test script works here.
          @robert-hh no it don't works :p
          i don't know what to do ...
            @gael-cobert Just give it a break. The connector where you have P11 now, is labeled as camera connector. As long as the camera is not used, all pins should be available. So let's focus on that, but not today. I will try to use the pyscan for that test tomorrow. At the moment, I use a simple expansion board.
              @robert-hh ok thank you so much for your help :) i learned a lot of things indeed. See you tomorrow.
                @gael-cobert Could not give it a rest, so I made a shot. This setting worked, all on the camera connector:
                import epaper4in2
                # SPIV on ESP32
                sck = "P9"
                miso = None
                mosi = "P10"
                dc = Pin("P3", Pin.OUT)
                cs = Pin("P19", Pin.OUT)
                rst = Pin("P11", Pin.OUT, value=1)
                busy = Pin("P15", Pin.IN)
                spi = SPI(0, baudrate=20000000, polarity=0, phase=0, pins=(sck, mosi, None))
                e = epaper4in2.EPD(spi, cs, dc, rst, busy)
                e.init()
                w = 400
                h = 300
                x = 0
                y = 0
                # use a frame buffer
                # 400 * 300 / 8 = 15000 - thats a lot of pixels
                import framebuf
                black = 0
                white = 1
                fb.fill(white)
                fb.fill(white)
                The only problem that I had was the USB of the pyscan. I never used it before, and so the driver needed am update. I skipped that and connected with telnet.
                G 2 Replies Last reply Reply Quote 0
                  sck = "P9"
                  miso = None
                  mosi = "P10"
                  did you try it with a piscan ? i changed my code with your example but not change ... i changed P8 to P11
                  I changed other pin
                  https://drive.google.com/file/d/12dhAIFz4ND_cvRy4eSzi3o79BKnx_9EB/view?usp=sharing
                    @gael-cobert Yes. I used Pyscan for that. The same 0.7 version that you have. with long male/male adapter pins.
                    If that does not work, the problem may be somewhere else.
                      @robert-hh P11 is to the left of P13 ?
                      https://drive.google.com/file/d/12uRecBvZEub8N-LTEvIxTz0T2M0FdGH_/view?usp=sharing
                      can you give me a photo of your board ?
                        import epaper4in2
                        SPIV on ESP32
                        sck = "P9"
                        miso = None
                        mosi = "P10"
                        e.init()
                        w = 400
                        h = 300
                        x = 0
                        y = 0
                        use a frame buffer
                        import framebuf
                        black = 0
                        white = 1
                        fb.fill(white)
                        fb.fill(white)
                        it works !!!!!!!!
                          @gael-cobert Wonderful. Although the display update times are pretty long. So it's more suited for signs.
                            @robert-hh yes do you know why it's so long ? ( around 3 sec )
                            i have another question, i am using atom IDE, i want to use the NFC scan, but sometimes it stop, if i click "run selected files"
                            if i transfer main.py file via FTP it don't seem to execute when the board start, it's a little bit strange
                            import epaper4in2
                            # NFC
                            from pyscan import Pyscan
                            from MFRC630 import MFRC630
                            from LIS2HH12 import LIS2HH12
                            from LTR329ALS01 import LTR329ALS01
                            import binascii
                            import _thread
                            ttf_dir = 'ttf'
                            # var NFC
                            # This is the default key for an unencrypted MiFare card
                            DEBUG = True  # change to True to see debug messages
                            VALID_CARDS = [[0x43, 0x95, 0xDD, 0xF8],
                                           [0x43, 0x95, 0xDD, 0xF9],
                                           [0x8C, 0x43, 0x00, 0x5C],
                                           [0x46, 0x5A, 0xEB, 0x7D, 0x8A, 0x08, 0x04]]
                            py = Pyscan()
                            nfc = MFRC630(py)
                            lt = LTR329ALS01(py)
                            li = LIS2HH12(py)
                            RGB_BRIGHTNESS = 0x8
                            RGB_RED = (RGB_BRIGHTNESS << 16)
                            RGB_GREEN = (RGB_BRIGHTNESS << 8)
                            RGB_BLUE = (RGB_BRIGHTNESS)
                            counter = 0
                            # SPIV on ESP32
                            sck = "P9"
                            miso = None
                            mosi = "P10"
                            e.init()
                            w = 400
                            h = 300
                            x = 0
                            y = 0
                            import framebuf
                            black = 0
                            white = 1
                            fb.fill(white)
                            fb.fill(white)
                            fb.text('bienvenue sur le système secureangel',30,0,black)
                            # Make sure heartbeat is disabled before setting RGB LED
                            pycom.heartbeat(False)
                            # Initialise the MFRC630 with some settings
                            nfc.mfrc630_cmd_init()
                            def check_uid(uid, len):
                                return VALID_CARDS.count(uid[:len])
                            def print_debug(msg):
                                if DEBUG:
                                    print(msg)
                            def send_sensor_data(name, timeout):
                                while(True):
                                    print(lt.light())
                                    print(li.acceleration())
                                    time.sleep(timeout)
                            def discovery_loop(nfc, id):
                                    # Send REQA for ISO14443A card type
                                    print_debug('Sending REQA for ISO14443A card type...')
                                    atqa = nfc.mfrc630_iso14443a_WUPA_REQA(nfc.MFRC630_ISO14443_CMD_REQA)
                                    print_debug('Response: {}'.format(atqa))
                                    if (atqa != 0):
                                        # A card has been detected, read UID
                                        print_debug('A card has been detected, read UID...')
                                        uid = bytearray(10)
                                        uid_len = nfc.mfrc630_iso14443a_select(uid)
                                        print_debug('UID has length: {}'.format(uid_len))
                                        if (uid_len > 0):
                                            s =  binascii.hexlify(uid[:uid_len],' ').upper()
                                            card_id = ("{:02X}"*len(s)).format(*s)
                                            print_debug('card_id : -> {} <-'.format(card_id))
                                            tst = s.decode("utf-8")
                                            print_debug('tst : {} <-'.format(tst))
                                            if(tst == "8C 43 00 5C") :
                                                print_debug('hello gael')
                                                fb.fill(white)
                                                fb.text('Hello Gaël ! :)',30,80,black)
                                            print_debug('Checking if card with UID: [{:s}] is listed in VALID_CARDS...'.format(binascii.hexlify(uid[:uid_len],' ').upper()))
                                            if (check_uid(list(uid), uid_len)) > 0:
                                                print_debug('Card is listed, turn LED green')
                                                pycom.rgbled(RGB_GREEN)
                                                print_debug('Card is not listed, turn LED red')
                                                pycom.rgbled(RGB_RED)
                                                fb.fill(white)
                                                fb.text('carte introuvable :p',30,0,black)
                                        # No card detected
                                        #print_debug('Did not detect any card...')
                                        pycom.rgbled(RGB_BLUE)
                                    nfc.mfrc630_cmd_reset()
                                    time.sleep(.5)
                            # This is the start of our main execution... start the thread
                            _thread.start_new_thread(discovery_loop, (nfc, 0))
                            _thread.start_new_thread(send_sensor_data, ('Thread 2', 10))
                              @gael-cobert I cannot tell anything about the Pycom IDE with either Atom or VSCode. The seem to fail constantly.
                              I prefer to use primitive tools, like picocom | putty | beagle term for REPL, and plain ftp | filezilla or in the absence of wifi pyboard.py + mpr.py for file transfer.
                                @robert-hh You are correct, Im not sure yet how they messed it up, but it seems to be a mirrorring issue. From what I see, the connector is labeled from the top view, but the square pad is definitely connected to GND, instead of PWR_EN
                                I'll make sure it gets fixed, thanks!
