Cannot access LoPy4 after connecting using UART, which has not enable
@Gijs I have check the LoPy4 for broken pins, also the expansion board and everything looks ok. I have another expansion board with its USB cable (and another working LoPy4), so I have connect the not working LoPy4 there and I have the same results, so it looks like is not a problem with some broken pin (at least not in the expansion board or USB cable).
The firmware and the python code that was uploaded in the LoPy4 was working until I did the UART connection, by this I mean connecting the LoPy4 to a usb port using P0 and P1, and a USB Serial adapter.
Now the LoPy4 is connected to a expansion board 2, using a working USB cable. I try to update the firmware using the CLI firmware updater, but got the same result:Running in PIC mode Exception: Failed to connect to ESP32: Timed out waiting for packet headerCan it be that the LoPy4 has some pin broken "inside"? Should I run the erase_fs command? what else can I do?
Thanks for all your help
@elfarah The expansion board 2 also does not support auto-switch to boot mode. To get into boot mode, you have to connect P2 to GND and push the reset button. Then you can start the updater.
@robert-hh Hello I have a expansion board v3.1, the 2 was an old one and I was mistaken, sorry for that. How can I get the LoPy4, using the 3.1 expansion board, into boot mode? I have try P12 to 3.3v after reset, also using the safe boot button with no results. I also try the esptool and got the same error, timeout waiting for packet header.
@elfarah The pycom updater supports the expansion board 3.1 for switching into boot mode. Check that all jumpers on the board are present. esptool.py does not know how to tell the expansion board to go into boot mode.
In any case: Connecting P2 to GND and pushing reset will put the device into boot mode. -
@robert-hh I have try both the pycom-updater and the esptool.py, connecting P2 to GND, and pushing the reset button. The output is the same:
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet headerAll jumpers are present in the expansion board.
@elfarah P2 to GND + reset forces boot mode. This is implemented in the ESP32 boot ROM and cannot be bypassed. P2 of the LoPy4 module is GPIO0 of the ESP32.
If that connection is right,- try a different USB cable
- verify that you used the right USB port on your PC.
What do you see if you open the terminal window to the board, connect P2 to GND and push reset. You should see something like
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2)) waiting for download -
@robert-hh I didn’t have any success using the expansion board 3.1. When I connected P2 to GND and reset, I get no answer back from the LoPy4, in vscode terminal. So, I connected the LoPy4 to a breadboard, using a usb-serial adapter (the one that I thought cause the problem), and the minimum circuit, I was able to connect to the LoPy4. I then reset the device and got the message DOWNLOAD_BOOT, in a terminal. So, I opened the pycom firmware update software and updated the firmware of the LoPy and then, after reset, the code in main.py was running (as the LED changed colors indicating the code was running). So I put the LoPy back in the expansion board, open vscode, and got the same unrecognized characters and the
RTCWDT_RTC_RESETmessage. I disconnected the LoPy from the expansion board, connected another LoPy4 to same expansion board and it worked without any issues.As a summary:
I was able to update the firmware of the LoPy4 using a USB-serial adapter, a breadboard, and P2 connected to GND.
The LoPy4, in the breadboard and using the USB-serial adapter as power source is working.
The LoPy4 when tested in three different expansion boards didn’t work. Others LoPy4s do work in all expansion boards tested.
The LoPy4 in the breadboard works, the expansion board with other LoPys work, but the LoPy4 in any expansion board doesn’t work.
I am not exactly sure why it is not working, and also I was not able to connect to the LoPy from vscode when using the usb-serial adapter, I am not sure if I need the expansion board to upload the code.
Thanks for your help,
@elfarah said in Cannot access LoPy4 after connecting using UART, which has not enable:
I know this is currently related to a bug in the latest VScode version of Pymakr where the serial connection does not work properly, we hope to have that fixed soon!
I find it quite odd the one Lopy4 does not work in any of your expansionboard, while others do work. Could you elaborate some on that? (ie, no response on usb, not showing up in lsusb, leds status, possibly the voltages on Vin and 3V3 pins)
@Gijs Actually I had to downgrade the vscode to version 1.49 and pymakr to version 1.1.7 to make it work again.
Besides that, the problem that I got when connecting the LoPy4 with th expansion board 3.1 is the one describe above. I get the following output from the vscode terminal, when connected thru the expansion board:
e�3 Jun 8 2016 00�22:57 rst:0x�0 (RTCWDT_RTC�ESET),boot:ets ��*����ʘ$�ꕳ���崚�e���ets Jun 8 2016 00:2�:�7 rst:������ets ��*����ʘ$�ꕳ���崚�e��!������e�s Jun 8 2016 ets Jun 8�2016 ets Jun 8 2016 00:22:57 rst:0x�0 (RTCWDT_RTC�ESET),boot:0�3� (�I�ST�LASH_BOOT)In the expansion board the leds are working. The LoPy4 port is found in the vscode. I checked Vin (equal to 4.96v) and the output 3.3v (is 3.4v in the back of the expansion board). Can it be other inputs of the LoPy4, that are not working and causing this restarts.
@elfarah That fuzz still looks like an hardware problem. Electrical connection, signal levels, crystal speed, .. and so on. If you have an oscilloscope, you could check that.
Hi @elfarah, I would like to know if you had success with this problem. Currently I get the following output, connecting the LoPy4 without expansion board. Almost the same that you had been describing.
The LoPy4 port is found in the Atom IDE.
@Jorge-Romero That looks like a wrong baud rate. Is your PC's COM port set to 115200 baud, 8 bits, no parity?
@robert-hh Hello, I have the baud rate setup in my PC's COM like this: 115200 baud, 8 bits, no parity
@Jorge-Romero So that's the configuration for COM4, which seems to be used with the LoPy4. If you say "without expansion board", you must have used another USB/UART converter.
