Expose Pygate events with the forwarder payload
Hi everyone,
I'm building a very quick POC that involves Pygate (with WIPY). The goal is to capture the payload (the diagram JSON built by packet forwarder) and provide it to a higher level, so I can access it withing Python environment. This data will be passed over to another hardware component of the POC.
I can not fully digest the architecture so may miss some essential bits, but here's what's done so far:
I've added another method to set machine status to include more
void machine_pygate_set_status_args(machine_pygate_states_t status, void* data) { bool trig = false; pygate_status = status; switch (pygate_status) { case PYGATE_LORA_PCKT_IN: if(machine_obj.trigger & PYGATE_LORA_EVENT) { trig = true; machine_obj.events |= PYGATE_LORA_EVENT; machine_obj.handler_arg = data; } break; default: break; } if(trig) { mp_irq_queue_interrupt(machine_callback_handler, &machine_obj); } }and call it once the diagram sent to the server like this:
machine_pygate_set_status_args(PYGATE_LORA_PCKT_IN, (char *)(buff_up + 12));I can see the event is triggered if I include it in main.py like this
elif (evt & machine.PYGATE_LORA_EVT): print('LoRa Event\n')However, I'm not sure how do I access the payload, ie the
machine_obj.handler_arg. Might be something trivial, but having very little familiarity with backend architecture doesn't help much.Also, is the approach is right or there's a better solution I've overlooked?
Many thanks in advance!
P.S. I did omit some details of the firmware code for brevity
The Payload is handled and parsed around this line in the sourcecode: https://github.com/pycom/pycom-micropython-sigfox/blob/Dev/esp32/pygate/lora_pkt_fwd/lora_pkt_fwd.c#L1526, which Im not sure how to couple with your function..
Interesting to see you were able to make the callback work!
@Gijs thanks! Do you think I posted in the wrong forum - there are very few views. I'm really after architectural hint as it's not documented anywhere.
The Pygate LoRaWAN stack is very similar to the loranet/packet forwarder repository on github: https://github.com/Lora-net/packet_forwarder/tree/master/lora_pkt_fwd/src. Maybe they can provide you some answers. I sort of have an idea of what you are trying to achieve, but Im not sure how to accomplish it in combination with the micropython layer
@Gijs I managed to get the event payload to the higher level, thanks for the hint! I can see the whole diagram sent which is built by the packet forwarder, ie the full PUSH_DATA packet as per Semtech specs.
Basically, I can do this now:
elif (evt & machine.PYGATE_LORA_EVT): print('LoRa Event') print(arg, end='\n') print('\n')and get normal Python byte string with PUSH_DATA packet in
arg -
