BH1750 always give 0 lx
  • Hi,
    I have a problem with BH1750 light sensor.
    It is inside a sensorial node and communicate with LoPy by I2C bus.
    In the first cicle, i have a correct measure, for example (light is the first value: 79):
    79;22.0;63.5;1017.7;17;25;32;82;2021-02-17 10:53:55
    From 2nd, i have always 0.
    This is the code:
    from sht10 import SHT10
    from machine import Pin
    import struct
    import math
    import bh1750fvi
    import bme680
    from i2c import I2CAdapter
    from hm3301 import HM3301
    from network import Sigfox
    import utime
    from machine import I2C
    from network import WLAN
    from machine import RTC
    from machine import SD
    import sys
    pycom.heartbeat(False) # disable the blue blinking
    # ____ SD _____
    try:
        sd = SD()
        os.mount(sd, '/sd')
        # check the content
        os.listdir('/sd')
        # f = open('/sd/data.csv', 'w')
    except:
        print("Error: no SD")
        sys.exit(1)
    # ____ WiFi connession _____
    # configure the WLAN subsystem in station mode (the default is AP)
    print("Configuring WLAN...")
    wlan = WLAN(mode=WLAN.STA)
    # go for fixed IP settings (IP, Subnet, Gateway, DNS)
    wlan.ifconfig(config=('192.168.1.107', '255.255.255.0', '192.168.1.1', '192.168.1.1'))
    wlan.scan()     # scan for available networks
    wlan.connect(ssid='*********', auth=(WLAN.WPA2, '*********'))
    while not wlan.isconnected():
        pass
    print(wlan.ifconfig())
    time.sleep(5)
    # ____ Update time _____
    print("Update time...")
    rtc = RTC()
    rtc.ntp_sync("it.pool.ntp.org")
    data_pin = 'P9'
    sck_pin = 'P10'
    p_out_light = Pin('P20', mode=Pin.OUT)
    p_out_light.value(1)
    time.sleep(1)
    #i2c_var = I2CAdapter(pins=(data_pin, sck_pin))
    i2c=I2C(0, I2C.MASTER)
    i2c.scan()
    #print(i2c_var.scan())
    p_out_light.value(0) # Pin off
    try:
            f = open('/sd/data.csv', 'a')
            date = rtc.now()
            print("---- PIN ON ----")
            time.sleep(1)
            pycom.rgbled(0xFFA500)
            time.sleep(0.5)
            pycom.rgbled(0x000000)
            time.sleep(0.5)
            time.sleep(0.5)
            time.sleep(0.5)
            time.sleep(0.5)
            time.sleep(0.5)
            time.sleep(0.5)
            time.sleep(0.5)
            print("Measuring...")
            output = ""
            # Luminosità
            #i2c_var.writeto(i2c_var.scan()[0], bytes([0x10]))
            light_sensor = bh1750fvi.BH1750FVI(i2c_var)
            # print("LUX:")
            print(i2c_var.scan()[0])
            lux = light_sensor.read()
            #print(lux)
            output = str(lux) + ";"
            time.sleep(1)
            #time.sleep(1)
            # Temperatura
            sht = SHT10(data_pin, sck_pin)
            tmp = sht.readTemp()
            hum = sht.readHum()
            output += "{:.1f};{:.1f};".format(round(tmp,1), round(hum,1))
            time.sleep(1)
            # Pressione
            i2c_dev = I2CAdapter(pins=(data_pin, sck_pin))
            # print("PRESSION:")
            print(i2c_dev.scan()[1])
            # dev_add = i2c_dev.findSlaves()
            # print(dev_add)
            sensor = bme680.BME680(i2c_device=i2c_dev, i2c_addr=i2c_dev.scan()[1]) # se da errore "index out of range", cambiare da 1 a 0, poi da 0 ad 1 e ricaricare 4-5 volte
            sensor.set_pressure_oversample(bme680.OS_4X)
            sensor.set_filter(bme680.FILTER_SIZE_3)
            if sensor.get_sensor_data():
                output += "{:.1f};".format(round(sensor.data.pressure,1))
            time.sleep(1)
            # PM
            time.sleep(1)
            hm = HM3301('P21', 'P22') # P21 -> data , P22 -> clock
            #hm.findSlaves()
            pm1 = hm.readStandardPM()
            dep_string = ""
            pm_index_count = 0 # indice per PM
            c_pm1 = 0
            c_pm10 = 0
            c_pm25 = 0
            for digit in pm1:
                pm_index_count += 1
                if pm_index_count == 1:
                    c_pm1 = digit
                elif pm_index_count == 2:
                    c_pm25 = digit
                elif pm_index_count == 3:
                    c_pm10 = digit
            time.sleep(1)
            pm2 = hm.readAtmosphericPM()
            dep_string = ""
            c_pm1atm = 0
            c_pm10atm = 0
            c_pm25atm = 0
            for digit in pm2:
                pm_index_count += 1
                    c_pm1atm = digit
                    c_pm25atm = digit
                    c_pm10atm = digit
            time.sleep(1)
            # Media tra valori PM std e PM atm
            c_pm1_fin =  (c_pm1 + c_pm1atm) / 2
            c_pm10_fin = (c_pm10 + c_pm10atm) / 2
            c_pm25_fin = (c_pm25 + c_pm25atm) / 2
            output += str(round(c_pm1_fin)) + ";" + str(round(c_pm25_fin)) + ";" + str(round(c_pm10_fin)) + ";"
            vl_pm10 = 50 # limite giornaliero PM10 -> è 50 per la legge italiana
            vl_pm25 = 25 # limite giornaliero PM2.5
            # PM1 -> NON é POSSIBILE INSERIRLI PERCHé NON C'é UN LIMITE GIORNALIERO MESSO PER LEGGE
            # sottoindici
            i_pm10 = (c_pm10_fin / vl_pm10) * 100
            i_pm25 = (c_pm25_fin / vl_pm25) * 100
            index_pm = round((i_pm10 + i_pm25) / 2)
            if index_pm >= 0 and index_pm <= 50:
                dep_pm = 1 # "OTTIMA"
            elif index_pm > 50 and index_pm <= 75:
                dep_pm = 2 # "BUONA"
            elif index_pm > 75 and index_pm <= 100:
                dep_pm = 3 # "DISCRETA"
            elif index_pm > 100 and index_pm <= 125:
                dep_pm = 4 # "MEDIOCRE"
            elif index_pm > 125 and index_pm <= 150:
                dep_pm = 5 # "POCO SALUBRE"
            elif index_pm > 150 and index_pm <= 175:
                dep_pm = 6 # "INSALUBRE"
            elif index_pm > 175:
                dep_pm = 7 # "MOLTO INSALUBRE"
            # init Sigfox for RCZ1 (Europe)
            print("Init SigFox...")
            sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ1)
            # create a Sigfox socket
            s = socket.socket(socket.AF_SIGFOX, socket.SOCK_RAW)
            # make the socket blocking
            s.setblocking(True)
            # configure it as uplink only
            s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
            # send AQI
            my_string = str(round(tmp))+";"+str(round(hum))+";"+str(dep_pm)
            my_bytes = my_string.encode('utf-8')
            s.send(my_bytes)
            time.sleep(5)
            time.sleep(1)
            pycom.rgbled(0x2eff00)
            time.sleep(1)
            time.sleep(1)
            output += str(index_pm) + ";"
            dateUTC = '{:02d}-{:02d}-{:02d} {:02d}:{:02d}:{:02d}'.format(date[0],date[1],date[2],date[3],date[4],date[5])
            output += str(dateUTC) #timestamp
            print(output)
            # try some standard file operations
            f.seek(0, 2) # seek to end
            f.write(output+"\r\n")
            f.close()
            print("---- PIN OFF ----\n\n")
            index_time = 1 #600 # effettuo 6 misurazioni all'ora, 1 ogni 10 min
            while(index_time > 0):
                if index_time % 2:
                    pycom.rgbled(0x4F3394)
                time.sleep(1)
                index_time = index_time - 1
            s.close()
            time.sleep(1)
    except KeyboardInterrupt:
        print("\n---- END POLLING ----\n")
        f.close()
        pass
    I have found something similar in forum (here) but i don't know how to solve this problem.
    Sorry for my english!
    Thanks a lot.
  • @rcolistete Thank you but for this thesis' project i have only this type of sensor.
    I'll remember it!
  • I suggest anoter light sensor, MAX44009, better than BH1750 : low power (about 1 uA), "ultra-wide 22-bit dynamic range from 0.045 lux to 188,000 lux", etc.
  • @Luca-Albano
    for me it looks like a fastest way to werify
  • @livius I probably damaged it: yesterday, for a second, I connected GND and Vcc by reversing them. Since then, the sensor has worked like this. The only way, i think, is trying with another BH1750 to verificate if it is damaged or not, do you think?
  • If you have tried this sensor with different hardware and still problem occurs then probably some problem with sensor itself.
    I use this sensor long long time and i have not any problems.
  • @livius Thanks for reply.
    I tried this sensor in single in another shield (Arduino UNO) and there was always this problem.
    I could try with P21 and P22 which I am already using for the PM sensor, but for me this is not an I2C bus problem ...
  • @Luca-Albano
    Did you tried on different pins then P9 and P10?
    And how this sensor behave if you have only import releated to i2c and all otheres devicess are not connected?
    I meen simple code without sd card, wifi, .....
    I ask because for me it is working without any problems form months
  • @Matthew-Felgate-0 I have tried but this is the ouput:
    Configuring WLAN...
    Update time...
    ---- PIN ON ----
    Measuring...
    35
    119
    Init SigFox...
    205;21.2;62.8;1016.0;19;28;33;89;2021-02-17 15:22:11
    ---- PIN OFF ----
    ---- PIN ON ----
    Measuring...
    35
    119
    Init SigFox...
    0;21.2;62.7;1016.0;16;24;28;74;2021-02-17 15:22:44
    ---- PIN OFF ----
    ---- PIN ON ----
    Measuring...
    35
    119
    Init SigFox...
    0;21.2;62.9;1015.9;28;38;42;116;2021-02-17 15:23:16
    ---- PIN OFF ----
    It doesn't work correctly
  • Global Moderator
    Can you try reading the sensor twice?
    (and throw away the first result)
    light_sensor_temp = bh1750fvi.BH1750FVI(i2c_var)
