    building firmware 1.18.2.r7 errors
    4 Posts 3 Posters 65 Views 3 Watching
      gt1
      Im trying to build a firmware but it is failing with errors
      root@gt-VirtualBox:~/pycom-micropython-sigfox/esp32# make clean
      Use make SECURE=on [optionally SECURE_KEY ?= secure_boot_signing_key.pem] to enable Secure Boot and Flash Encryption mechanisms.
      Use make V=1 or set BUILD_VERBOSE in your environment to increase build verbosity.
      rm -rf build/WIPY/release
      mkdir -p build/WIPY/release/genhdr
      Create build/WIPY/release/genhdr/pins.h
      Generating build/WIPY/release/genhdr/mpversion.h
      GEN build/WIPY/release/genhdr/qstr.i.last
      In file included from ./mpconfigport.h:43:0,
                       from ../py/mpconfig.h:45,
                       from ../py/mpstate.h:31,
                       from ../py/mpstate.c:27:
      ./mp_pycom_err.h:11:33: fatal error: mbedtls/net_sockets.h: No such file or directory
      compilation terminated.
      i have compiled the most recent firmware following the readme with no issues.
      my paths are set the same as the newest firmware but i must be missing something. I have tried
      git clone --recursive -b v1.18.2.r7 https://github.com/pycom/pycom-micropython-sigfox.git
      with the newest idf. then i have tried different versions of the idf but I cant find any info on what i should be using.
      I have also tried downloading the gz file as well and seem to get the same results.
      im using https://dl.espressif.com/dl/xtensa-esp32-elf-linux64-1.22.0-80-g6c4433a-5.2.0.tar.gz
      does anyone have any ideas what i am missing or what i should be doing differently?
        livius @gt1
        @gt1
        you should use this two repos:
        https://github.com/pycom/pycom-esp-idf
        and
          gt1
          I have complied a firmware with frozen modules but it is v 1.20.2.R4 with the modules and it seems to work well.
          is there a way i can add a folder www with my html files so i can include it in the firmware?
          i tried putting this into the frozen/Common folder but it doesnt seem to work or i dont know the path to wall the html pages.
            Jan Rune Herheim
            Hi, I have a similar issue. What I found was that the paths in the pycom-esp-idf master branch is different from what I get when I clone with this branch idf_v3.3.1 (as stated in the readme). E.g. there was an additional level with mbedtls in the idf_v3.3.1 compared to the master.
            I then tried to checkout the master branch of pycom-esp-idf and it build ok. I haven't check if the actual image/bin file is working / equal to the released version.
