'LoRa' object has no attribute 'Mesh'
I had the same problem, to fix it put the version 1.20.0.rc11 and now i don't have that error but the mesh doesn't detect any neighbor and don't know how fix that
Pymesh (Mesh subclass of Lora) was excluded from build rc12. There are some licensing issues which we are trying to solve.
Most likely, next week, I'll make a separate pymesh firmware binary release (just latest RC+pymesh module).
As a temporary workaround, some older releases can be used, 1.20.0.rc8-9-10. -
Hello @catalin I want to implement pymesh but I get the same error, what is the latest version in which pymesh is included? I have tried lowering the version to 1.20.2.rc10 but y get the same error, can you help me please?
thanks in advanced.
Hi, nowadays you can get the pymesh firmware through Pybytes: https://docs.pycom.io/pybytes/pymeshintegration/
Hello, I have the same error, I tried whit the FW version 1.20.2.rc7, rc10, r4, can you help me please?, maybe I need another FW.
thanks in advance.
Hi @jclo13,
Sorry to hear about your experience.
I’ve just flashed a new Lopy4 with the latest v1.20.2.r4, registered to Pybytes, did all the steps from https://docs.pycom.io/pybytes/pymeshintegration/provisioning/; the device updated Pymesh firmware v.1. 20.2.rc11.
Bellow is the log. After update, you can obtain the pymesh object using:
pymesh = pybytes.__pymesh.__pymeshAs explained here: https://docs.pycom.io/pymesh/simple-example/
Firmware: 1.20.2.r4 Pybytes: 1.6.1 Initialized watchdog for WiFi and LTE connection with timeout 1260000 ms WiFi connection established Connected to MQTT mqtt.pybytes.pycom.io Pybytes connected successfully (using the built-in pybytes library) Configuration successfully converted to pybytes_config.json Pycom MicroPython 1.20.2.r4 [v1.11-ffb0e1c] on 2021-01-12; LoPy4 with ESP32 Pybytes Version: 1.6.1 Type "help()" for more information. >>> >>> Pymesh configuration written to /flash/pymesh_config.json Requesting: manifest.json?current_ver=1.20.2.r4&sysname=LoPy4&token=f10b536c-d264-458f-a5cf-d6676ec8fba8&ota_slot=0x210000&wmac=30AEA4ECAB28&fwtype=pymesh¤t_fwtype=pybytes to software.pycom.io:443 with SSL? True Wrapping socket Sending request Requesting: downloads/appimg/firmware_LoPy4_1.20.2.rc11-pymesh.bin to software.pycom.io:443 with SSL? True Wrapping socket Sending request Full Update Image detected. Restart the device to load the new firmware. ets Jun 8 2016 00:22:57 rst:0x7 (TG0WDT_SYS_RESET),boot:0x16 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0xee clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:DIO, clock div:1 load:0x3fff8020,len:8 load:0x3fff8028,len:2128 load:0x4009fa00,len:19760 entry 0x400a05bc WMAC: 30AEA4ECAB28 Firmware: 1.20.2.rc11 Pybytes: 1.5.2 Initialized watchdog for WiFi and LTE connection with timeout 1260000 ms WiFi connection established Connected to MQTT mqtt.pybytes.pycom.io Pybytes connected successfully (using the built-in pybytes library) Set MAC in config file as 8121069065078588544 MAC ok8121069065078588544 Settings:{'Pymesh': {'key': 'f1a1d8f7-2f9b8274-3d17e71f-3add897c'}, 'debug': 5, 'ble_api': False, 'ble_name_prefix': 'Device-30AEA4ECAB28', 'br_prio': 0, 'MAC': 8121069065078588544, 'LoRa': {'sf': 7, 'freq': 868000000, 'region': 5, 'bandwidth': 0}, 'br_ena': False, 'autostart': True} ============ MESH THREAD >>>>>>>>>>> 15: MAC 0x70b3d549946c4480(8121069065078588544), State Detached, Single True ['fdde:ad00:beef:0:0:0:0:4480', 'fdde:ad00:beef:0:8c3c:4c8d:4cc:b5d5', 'fe80:0:0:0:72b3:d549:946c:4480'] >>>>>>>>>>> DONE MESH THREAD ============ 49 Pybytes configuration read from /flash/pybytes_config.json Pycom MicroPython 1.20.2.rc11 [v1.11-f4d850b] on 2020-07-08; LoPy4 with ESP32 Pybytes Version: 1.5.2 Pymesh Version: 1.0.1 Type "help()" for more information. >>> os.uname() (sysname='LoPy4', nodename='LoPy4', release='1.20.2.rc11', version='v1.11-f4d850b on 2020-07-08', machine='LoPy4 with ESP32', lorawan='1.0.2', sigfox='1.0.1', pybytes='1.5.2', pymesh='1.0.1') >>> ============ MESH THREAD >>>>>>>>>>> 25: MAC 0x70b3d549946c4480(8121069065078588544), State Detached, Single True ['fdde:ad00:beef:0:0:0:0:4480', 'fdde:ad00:beef:0:8c3c:4c8d:4cc:b5d5', 'fe80:0:0:0:72b3:d549:946c:4480'] >>>>>>>>>>> DONE MESH THREAD ============ 49 ============ MESH THREAD >>>>>>>>>>> 35: MAC 0x70b3d549946c4480(8121069065078588544), State Detached, Single True ['fdde:ad00:beef:0:0:0:0:4480', 'fdde:ad00:beef:0:8c3c:4c8d:4cc:b5d5', 'fe80:0:0:0:72b3:d549:946c:4480'] >>>>>>>>>>> DONE MESH THREAD ============ 51 >>> pymesh = pybytes.__pymesh.__pymesh >>> ============ MESH THREAD >>>>>>>>>>> 55: MAC 0x70b3d549946c4480(8121069065078588544), State Leader, Single True ['fdde:ad00:beef:0:0:ff:fe00:fc00', 'fdde:ad00:beef:0:0:ff:fe00:3c00', 'fdde:ad00:beef:0:0:0:0:4480', 'fdde:ad00:beef:0:8c3c:4c8d:4cc:b5d5', 'fe80:0:0:0:72b3:d549:946c:4480'] Leader: mac 0x70b3d549946c4480, rloc 0x3c00, net: 0x7b92bd9d Neighbors Table: None >>>>>>>>>>> DONE MESH THREAD ============ 111 pymesh.debug_level(0) >>> pymesh.status_str() "Role 4, Single True, IPv6: ['fdde:ad00:beef:0:0:ff:fe00:fc00', 'fdde:ad00:beef:0:0:ff:fe00:3c00', 'fdde:ad00:beef:0:0:0:0:4480', 'fdde:ad00:beef:0:8c3c:4c8d:4cc:b5d5', 'fe80:0:0:0:72b3:d549:946c:4480']" >>> -
@catalin Thank you very much for the prompt reply, I was trying to use the code found on Github (https://github.com/pycom/pycom-libraries/tree/master/pymesh/pymesh_frozen) and I was getting that error, it will be possible to use this code ?.
Thanks in advance.
@catalin I'm a bit confused, the micropython API that is in the DOCs (https://docs.pycom.io/firmwareapi/pycom/network/lora/pymesh/) works with Pymesh from Pybytes? or how it should use the micropython API?.
thanks in advance.
@jclo13 As I've tried to explained here https://docs.pycom.io/pymesh/simple-example/ if Pybytes is stopped then you can use directly the Pymesh Library API (like:
pymesh = Pymesh(pymesh_config, new_message_cb))Stopping Pybytes can be done using (and enabling it can be done by using parameter
pycom.pybytes_on_boot(True)):import pycom pycom.pybytes_on_boot(False) machine.reset()If Pybtyes is stopped then Pymesh is not automatically started, but Pybytes Library scripts are included as frozen.
- You can re-upload Pymesh Library scripts (with custom modifications), and this ones will be executed, they are preferred instead of the frozen ones
- OR, You can use directly Pybytes low-level micropython API: https://docs.pycom.io/firmwareapi/pycom/network/lora/pymesh/
Thanks and let me know if anything else is not clear.
@catalin thanks for your response, I am having problems whit the Pymesh Firmware, exactly whit the following code:
loraSaved = pycom.nvs_get('loraSaved')I have the follogin error:
ValueError: No matching object for the provided keyCan you help me, please?
thanks in advance.
I don't think that has to do with the Pymesh firmware, but rather a missing key in the NVS. You can use a try-except block to catch the error, or use any of the following:pycom.nvs_set('loraSaved', value)to set the key, or
pycom.nvs_get('loraSaved', value)Which will return
valueif the key is not set. -
@Gijs Wasn't there a few months ago a breaking change in
nvs_getwhich switched from returningNoneto generating aValueErrorexception when the key does not already exists? -
I did a quick search for what you mention, and could only find this, from about a year ago: https://forum.pycom.io/topic/6132/pycom-nvs_get-returns-an-exception. Indeed there was a time where it returned 'None' as per the docs, but it has been like this for (at least) a year, so it should also be implemented in the Pymesh :)
You're correct when mentioning we should keep track of the API per firmware version.
@catalin said in 'LoRa' object has no attribute 'Mesh':
machine.reset()Dear Catalin, many thanks for your support. I still have issues with pmesh on my pycom Fipy.
Here what I did:
a. git clone https://github.com/pycom/pycom-libraries.git
b. in Atom Add a new project from pycom-libraries/pymes/pymesh_frozen
c. execute the code you suggestimport machine
machine.reset()d. Upload the project to the device
result: I got the error:
Traceback (most recent call last): File "main.py", line 35, in <module> File "/flash/lib/pymesh.py", line 57, in __init__ File "/flash/lib/mesh_interface.py", line 56, in __init__ File "/flash/lib/mesh_internal.py", line 123, in __init__ File "/flash/lib/loramesh.py", line 73, in __init__ File "/flash/lib/loramesh.py", line 122, in _lora_init AttributeError: 'LoRa' object has no attribute 'Mesh' Pycom MicroPython 1.20.3.b3 [v1.11-92f2b22e] on 2021-04-19; FiPy with ESP32in line 122 does not exist lora.Mesh()
Wrong firmware version? Which is the right one?
Here my current version:Pycom MicroPython 1.20.3.b3 [v1.11-92f2b22e] on 2021-04-19; FiPy with ESP32Thanks!
F. -
As I mentioned in a post above, nowadays you need to get the pymesh firmware through Pybytes. There is a guide here: https://docs.pycom.io/pybytes/pymeshintegration/. The pycom-libraries version of pymesh frozen is a reference to the pymesh code, but the firmware includes some additional closed-source components. If you use the firmware, you do not need to load the pymesh-frozen library seperately. -
@Gijs
Hi, thanks for your quick answer. I understood that is possible to use Pybytes, but I would like to understand if the code in github can be still used with some older firmware version or not.BR,
F- -
To be honest, I don't know. Perhaps the special submodule can be found in versions 1.20.0.rc8 through rc10 as my colleague Catalin described 2 years ago, but I would not recommend using that firmware in a production environment.
This post is deleted! -
As I mentioned before, the pymesh firmware uses closed-source libraries that unfortunately we cannot publish. When you update to the Pymesh firmware through Pybytes, you accept the license agreement, which is why we cannot publish the source or binary for this firmware. Sorry for the inconvenience.
Hello! I'm trying to create a LoRa Mesh or PyMesh network. I'm using LoPy4 and FiPy with expansion board 3.1v. After a few problems, I was able to create a PyMesh network using Pybytes. I have a project on Pybytes with WiFi and LoRa added as networks.
The devices have the same firmware version (1.20.2.rc11). They connet to Pybytes and they get a role (the rgbled change its color). However, I checked the monitoring tab and they don't find neighbours.
Moreover, I set the FiPy as Border Router, but something happened because in the image above it isn't appear as I defined previously.
I'm running tests right now, the FiPy is the leader of the network (MAGENTA) and the LoPy4 is a router (GREEN). Do I need another LoPy/FiPy to find neighbours between them?
I read the tutorials in the Pycom website, but I'm getting a bit confused because what I found here (https://docs.pycom.io/pymesh/licence/) works, but couldn't find neighbours in the network, and what I also found on the website (https://docs.pycom.io/firmwareapi/pycom/network/lora/pymesh/) doesn't work. It throws an error:
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled. Core 1 register dump: PC : 0x400ff85a PS : 0x00060030 A0 : 0x800ff890 A1 : 0x3ffdd450 A2 : 0x00000000 A3 : 0x00000000 A4 : 0x3f433b18 A5 : 0x3ffdd5b8 A6 : 0x0000002a A7 : 0x0000098a A8 : 0x3f40fc38 A9 : 0x3ffdd430 A10 : 0x00000000 A11 : 0x00060023 A12 : 0x00060020 A13 : 0x00000000 A14 : 0x0000000a A15 : 0x3ffdd5e0 SAR : 0x0000001e EXCCAUSE: 0x0000001c EXCVADDR: 0x00000000 LBEG : 0x4009527c LEND : 0x40095287 LCOUNT : 0xffffffff ELF file SHA256: 0000000000000000000000000000000000000000000000000000000000000000 Backtrace: 0x400ff85a:0x3ffdd450 0x400ff88d:0x3ffdd470 0x40108334:0x3ffdd490 0x40101e71:0x3ffdd4c0 0x400fe299:0x3ffdd4e0 0x4010a251:0x3ffdd500 0x40101f84:0x3ffdd5a0 0x400fe299:0x3ffdd600 0x400fe2c6:0x3ffdd620 0x400e1679:0x3ffdd640 0x400e1908:0x3ffdd6e0 0x400e01bd:0x3ffdd720The code above had some core dump info but it was a bunch of letters without much sense and I decided not to put it here.
So I would appreciate if someone can give me some hints about whats happening or what to do now.
