    How can I read Hertz frequency from a LoPy Pin?
    Scheduled Pinned Locked Moved Projects
    13 Posts 2 Posters 133 Views 2 Watching
      Lorenzo Comparini @robert-hh
      @robert-hh I tried changing channel to 7, and now the length of the output result changes accordingly to the sensor movement, the maximum level I can reach is 128. How can i obtain the frequency in Hz?
        robert-hh @Lorenzo Comparini
        @Lorenzo-Comparini So th efrequency is between 16 and 90 Hz, meaning that you have to use channel 7. The frequency should be something like 1000/(2 * pulse_length * 3.125)
          @Lorenzo-Comparini If the maximum number is 128, then y.ou can as well go for channel 4 or 5, which gives a better resolution. Then replace 3.125 by 1.0
          robert-hhR L 2 Replies Last reply Reply Quote 0
            robert-hh @robert-hh
            @robert-hh Please not, that he sonsor runs at 5V, and the input at the Lopy must not exceed 3.3 V.
              @robert-hh I know, the VCC is joined to an external power source at 5V
                @robert-hh I just tried both, but the maximum legth of the pulse is still 128
                  @Lorenzo-Comparini What you do is guessing. Get yourself an independent method for displaying the signals. Like a 10 € logic analyzer, available e.g. at Amazon: https://www.amazon.de/AZDelivery-⭐⭐⭐⭐⭐-Logic-Analyzer-gratis/dp/B01MUFRHQ2/ref=sr_1_5?__mk_de_DE=ÅMÅŽÕÑ&crid=1LM4V4HE5L3CG&dchild=1&keywords=logic+analyzer&qid=1623852278&sprefix=Logic+%2Caps%2C181&sr=8-5
                    @robert-hh thanks, guess I'll try that, can you explain me what is that for and what it does? sorry but I'm very noob at this
                      @Lorenzo-Comparini That is the front end of a software, which display the function of signal level over time. SO you can see the signal. In you case some kind of high/low level changes. And you can measure it's timing properties. It supports 8 input channels. The software you need is either 'pulseview' or the Logic software. Links:
                      https://sigrok.org/wiki/PulseView
                      https://www.saleae.com/downloads/
                        @robert-hh Thank you very much, hope to solve this soon
