    Sigfox and SSD1306
    6 Posts 3 Posters 90 Views 4 Watching
      alexlont
      Im trying to create a Sigfox signal tester using the return RSSI using a Fipy and a SSD1306 OLED
      im getting an error in relation to SSSD1306. i have a script from the following.
      https://github.com/pycom/pycom-micropython-sigfox/blob/master/drivers/display/ssd1306.py
      i get the following error
      ♦Traceback (most recent call last):
        File "<stdin>", line 12, in <module>
        File "ssd1306.py", line 109, in __init__
        File "ssd1306.py", line 37, in __init__
        File "ssd1306.py", line 64, in init_display
        File "ssd1306.py", line 89, in show
        File "ssd1306.py", line 119, in write_data
      AttributeError: 'I2C' object has no attribute 'start'
      Pycom MicroPython 1.20.2.r4 [v1.11-ffb0e1c] on 2021-01-12; FiPy with ESP32
      Pybytes Version: 1.6.1
      my main.py code is below
      from machine import I2C, Pin
      from network import Sigfox
      from ssd1306 import SSD1306_I2C
      #i2c = I2C.init(0, I2C.MASTER, baudrate=100000, pins=("P10","P10"))
      #INITIALIZATION AFTER POWER UP
      i2c = I2C(0, I2C.MASTER)             # create and init as a master
      # configure the I2C bus
      i2c.init(I2C.MASTER, baudrate=400000) # init as a master
      oled = SSD1306_I2C(128, 32, i2c, 60,external_vcc=True)
      sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ4)
      s = socket.socket(socket.AF_SIGFOX, socket.SOCK_RAW)
      s.setblocking(True)
      s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, True)
      s.send(bytes([0, 1, 2, 3]))
      r= s.recv(32)
      print(r)
      rssi=sigfox.rssi()
      print(rssi())
      oled.text(rssi, 0, 0, 1)
      oled.show()
      s.close()
        livius @alexlont
        @alexlont said in Sigfox and SSD1306:
        SSSD1306
        It is quite old. Try to use it from official micropython it use framebuffer then
        https://github.com/micropython/micropython/blob/master/drivers/display/ssd1306.py
        A 1 Reply Last reply Reply Quote 2
          alexlont @livius
          @livius I've updated my SSD1306.Py script to refect the newer library. however im still getting the exact same issues.
          Pybytes configuration read from /flash/pybytes_config.json
            File "main.py", line 7, in <module>
            livius @alexlont
            @alexlont
            Are you sure that you are using this new one?
            There is no start command in the new code.
              jcaron @livius
              @livius The new version uses i2c.writevto, though, which does not seem to exist in Pycom firmware (at least it's not documented, didn't check an actual device or the sources).
              But the error message should be slightly different, the error shown clearly points to the older version of the driver.
                livius @jcaron
                @jcaron said in Sigfox and SSD1306:
                i2c.writevto
                this looks like bug should be writeto
