    Crashing after a couple of hours
    2 Posts 1 Posters 32 Views 1 Watching
    • Åke ForslundÅ Offline
      Åke Forslund
      Hi I'm setting up a temperature sensor using the gPy device. My idea was to have it in deepsleep for ~30 minutes and then perform a measurement and go back to sleep.
      I've created a main.py that looks like this:
      from machine import Pin
      from onewire import DS18X20, OneWire
      print("Booted into application at {}".format(time.time()))
      def get_temperature():
          """Get temperature from OneWire sensor."""
          ow = OneWire(Pin('P10'))
          temp = DS18X20(ow)
          for _ in range(10):
              temperature = temp.read_temp_async()
              time.sleep(1)
              temp.start_conversion()
              if temperature:
                  break
          return temperature
      def publish_to_web(temperature):
          print('Publishing a temperature of {}'.format(temperature))
          pybytes.send_signal(0, temperature)
      time.sleep(1)
      temperature = get_temperature()
      time.sleep(1)
      print("Going to sleep")
      pybytes.deepsleep(30*60*1000) # 30 Minutes
      And this works for some time but after 5-8 hours samples stop coming in and when looking at my computer I see that the Atom shell is trying to connect to the serial port but failing.
      Disconnecting / reconnecting then shows a SyntaxError message. Resetting the device resumes the operation.
      Has anyone seen anything similar to this? Any ideas how to make it more robust? Could I setup a watchdog in the boot.py and then feed / disable it in my main.py? would it help or is it likely that the issue occurs earlier.
      I've now connected it to an usb-charger in case there's something my computer does.
      Any help / insights would be appreciated!
        Åke Forslund
        Having it plugged to an usb-charger instead of the computer's usb has kept it stable since I sent above message so maybe it was the USB port on my computer or possibly Atom causing the issue.
