WiFi Manager LoPy4
  • I am running wifi manager on LoPy4 I need to made changes to make it work with LoPy 4 but it doesn't work for me pleas if someone can help me .
    https://github.com/tayfunulu/WiFiManager
  • @hamza-charhour how is it not working? What do you expect it to do, and what does it actually do? What are you trying to connect with? How? What happens?
  • import network
    import ure
    from network import WLAN
    wlan = WLAN()
    NETWORK_PROFILES = 'wifi.dat'
    wlan_sta = network.WLAN(mode=network.WLAN.STA)
    server_socket = None
    def get_connection():
        """return a working WLAN(STA_IF) instance or None"""
        # First check if there already is any connection:
        if wlan_sta.isconnected():
            return wlan_sta
        connected = False
        try:
            # ESP connecting to WiFi takes time, wait a bit and try again:
            time.sleep(3)
                return wlan_sta
            # Read known network profiles from file
            profiles = read_profiles()
            # Search WiFis in range
            wlan_sta.active(True)
            networks = wlan_sta.scan()
            AUTHMODE = {0: "open", 1: "WEP", 2: "WPA2", 3: "WPA2-PSK", 4: "WPA/WPA2-PSK"}
            for ssid, bssid, channel, rssi, authmode, hidden in sorted(networks, key=lambda x: x[3], reverse=True):
                ssid = ssid.decode('utf-8')
                encrypted = authmode > 0
                print("ssid: %s chan: %d rssi: %d authmode: %s" % (ssid, channel, rssi, AUTHMODE.get(authmode, '?')))
                if encrypted:
                    if ssid in profiles:
                        password = profiles[ssid]
                        connected = do_connect(ssid, password)
                        print("skipping unknown encrypted network")
                else:  # open
                    connected = do_connect(ssid, None)
                if connected:
                    break
        except OSError as e:
            print("exception", str(e))
        # start web server for connection manager:
        if not connected:
            connected = start()
        return wlan_sta if connected else None
    def read_profiles():
        with open(NETWORK_PROFILES) as f:
            lines = f.readlines()
        profiles = {}
        for line in lines:
            ssid, password = line.strip("\n").split(";")
            profiles[ssid] = password
        return profiles
    def write_profiles(profiles):
        lines = []
        for ssid, password in profiles.items():
            lines.append("%s;%s\n" % (ssid, password))
        with open(NETWORK_PROFILES, "w") as f:
            f.write(''.join(lines))
    def send_header(client, status_code=200, content_length=None ):
        client.sendall("HTTP/1.0 {} OK\r\n".format(status_code))
        client.sendall("Content-Type: text/html\r\n")
        if content_length is not None:
          client.sendall("Content-Length: {}\r\n".format(content_length))
        client.sendall("\r\n")
    def send_response(client, payload, status_code=200):
        content_length = len(payload)
        send_header(client, status_code, content_length)
        if content_length > 0:
            client.sendall(payload)
        client.close()
    def handle_root(client):
        ssids = sorted(ssid.decode('utf-8') for ssid, *_ in wlan_sta.scan())
        send_header(client)
        client.sendall("""\
            <html>
                <h1 style="color: #5e9ca0; text-align: center;">
                    <span style="color: #ff0000;">
                        Wi-Fi Client Setup
                    </span>
                </h1>
                <form action="configure" method="post">
                    <table style="margin-left: auto; margin-right: auto;">
                        <tbody>
        while len(ssids):
            ssid = ssids.pop(0)
            client.sendall("""\
                            <tr>
                                <td colspan="2">
                                    <input type="radio" name="ssid" value="{0}" />{0}
                                </td>
                            </tr>
            """.format(ssid))
        client.sendall("""\
                            <tr>
                                <td>Password:</td>
                                <td><input name="password" type="password" /></td>
                            </tr>
                        </tbody>
                    </table>
                    <p style="text-align: center;">
                        <input type="submit" value="Submit" />
                    </p>
                </form>
                <p>&nbsp;</p>
                <hr />
                <h5>
                        Your ssid and password information will be saved into the
                        "%(filename)s" file in your ESP module for future usage.
                        Be careful about security!
                    </span>
                </h5>
                <hr />
                <h2 style="color: #2e6c80;">
                    Some useful infos:
                </h2>
                <ul>
                    <li>
                        Original code from <a href="https://github.com/cpopp/MicroPythonSamples"
                            target="_blank" rel="noopener">cpopp/MicroPythonSamples</a>.
                    </li>
                    <li>
                        This code available at <a href="https://github.com/tayfunulu/WiFiManager"
                            target="_blank" rel="noopener">tayfunulu/WiFiManager</a>.
                    </li>
                </ul>
            </html>
        """ % dict(filename=NETWORK_PROFILES))
        client.close()
    def handle_configure(client, request):
        match = ure.search("ssid=([^&]*)&password=(.*)", request)
        if match is None:
            send_response(client, "Parameters not found", status_code=400)
            return False
        # version 1.9 compatibility
        try:
            ssid = match.group(1).decode("utf-8").replace("%3F", "?").replace("%21", "!")
            password = match.group(2).decode("utf-8").replace("%3F", "?").replace("%21", "!")
        except Exception:
            ssid = match.group(1).replace("%3F", "?").replace("%21", "!")
            password = match.group(2).replace("%3F", "?").replace("%21", "!")
        if len(ssid) == 0:
            send_response(client, "SSID must be provided", status_code=400)
            return False
        if do_connect(ssid, password):
            response = """\
                <html>
                    <center>
                        <br><br>
                                ESP successfully connected to WiFi network %(ssid)s.
                            </span>
                        </h1>
                        <br><br>
                    </center>
                </html>
            """ % dict(ssid=ssid)
            send_response(client, response)
            try:
            except OSError:
                profiles = {}
            time.sleep(5)
            return True
            response = """\
                <html>
                    <center>
                                ESP could not connect to WiFi network %(ssid)s.
                            </span>
                        </h1>
                        <br><br>
                        <form>
                            <input type="button" value="Go back!" onclick="history.back()"></input>
                        </form>
                    </center>
                </html>
            return False
    def handle_not_found(client, url):
        send_response(client, "Path not found: {}".format(url), status_code=404)
    def stop():
        global server_socket
        if server_socket:
            server_socket.close()
    def start(port=80):
        addr = socket.getaddrinfo('0.0.0.0', port)[0][-1]
        stop()
        wlan.init(mode=WLAN.AP, ssid='hello world')
        server_socket = socket.socket()
        server_socket.bind(addr)
        server_socket.listen(1)
        print('Connect to WiFi ssid ' + ssid  )
        print('and access the ESP via your favorite web browser at 192.168.4.1.')
        print('Listening on:', addr)
                return True
            client, addr = server_socket.accept()
            print('client connected from', addr)
            try:
                client.settimeout(5.0)
                request = b""
                try:
                    while "\r\n\r\n" not in request:
                        request += client.recv(512)
                except OSError:
                    pass
                print("Request is: {}".format(request))
                if "HTTP" not in request:  # skip invalid requests
                    continue
                try:
                    url = ure.search("(?:GET|POST) /(.*?)(?:\\?.*?)? HTTP", request).group(1).decode("utf-8").rstrip("/")
                except Exception:
                    url = ure.search("(?:GET|POST) /(.*?)(?:\\?.*?)? HTTP", request).group(1).rstrip("/")
                print("URL is {}".format(url))
                if url == "":
                    handle_root(client)
                elif url == "configure":
            finally:
                client.close()
    THIS IS MY CODE NO ERROR BUT IT IS NOT WORKING
  • @hamza-charhour Unless you state what doesn't work (what you expect it to do, what it actually does, what errors and logs you get...) or what changes you need to make, it's going to be quite difficult for anyone to help you...
