    gzip file problem
    4 Posts 2 Posters 31 Views 2 Watching
    • K Offline
      kjm
      I've got a small gzip compressed file called Lcomp.py
      The file is valid & I can print it in both it's compressed & uncompressed formats
      with open('Lcomp.py', 'r') as f: m=f.read(); print(); print('compressed L:'); s=repr(m); print(s); print(len(s), 'bytes')
      import uzlib; from uio import StringIO as s; u=uzlib.DecompIO(s(m),31); m=u.read(); print(); print('decomp: '); print(m); print(len(m), 'bytes')
      if '\x1f\x08' in m:  import uzlib; from uio import StringIO as s; u=uzlib.DecompIO(s(m),31); m=u.read(); print(); print('if test decomp: '); print(m); print(len(m), 'bytes')
      gives
      compressed L:
      '\x1f\x08\x08v<Ia\x04\x00L.py\x00]\r\n0\x10\uf17e\x03\x14\x0b*\x04?b\t\x1bx\x0c-\x05 4\U0001102e\x12S\x12\x07o"\x0b\x0b\x03\x001\x0cHy9\x08dg\x011+\x05d\x04\x18Vq\\$\x1b)\x07\x01]\x150(~\u64bc\u0379FkF7!kH,lrU\x0ee\x01a#2X\x03.\x0e\x06W\x10+\x0fmZ\x13\u02b1\x0e\x12\x1b\u05e0\x0f\x0132\x11!<%F\x08\x1c:\x05\x1685\x01K\x04zsU\x04\x03\x08~v\x13\x1b\x06\U0002f6ff\x1cn>\\I\x07\x00\x00\x00'
      386 bytes
      decomp:
      b'[[72, 86, 148], ["  if len(L)!=5: TxL.append([\'wrong list length\', len(L)); return\\r", "  print(); print(\'new file:\'); print(nf); with open(\'newfile\', \'w\') as f: f.write(nf)\\r", "            if \'[\' in m: TxL.append(m)\\r"], [72, 86, 148], [], []]\r\n'
      247 bytes
      What I don't understand is why it fails to print a second time after I test it for the compression header '\x1f\x08' ? Any body see what I'm doing wrong?
        livius @kjm
        @kjm
        you have overridden value of m in second line
        so in third line it is not the same operation as you decompress already decompressed value.
        And really better if you follow guaidance of writing python code, as you write all in one line.
        Python designed indents to have more understandable code at first look.
        • K Offline
          kjm
          OK, I redid
          def _decomp(c):
            import uzlib
            u=uzlib.DecompIO(s(c),31)
            n=u.read()
            print(n)
            print(len(n), 'bytes')
          s=repr(m); print(s)
          _decomp(m)
          if '\x1f\x08' in m:  _decomp(m)
          but my problem persists
          compressed L:
          386 bytes
          decomp:
          247 bytes
          only 1 print
            livius @kjm
            @kjm said in gzip file problem:
            if '\x1f\x08'
            what if you write
            if b'\x1f\x08' in
