New firmware release, version 1.5.1.b1 (supporting the SiPy)
Thanks for the new firmware. I understand that you really want to catch up sigfox but the real IoT stays on batteries. And batteries rely on deepSleep. I also understand that deepsleep's delay root cause is esspresif but at least inform us.
Thanks in advance
Hi @daniel ,
Just now i downloaded the updater tool 1.0.0.b1 to upgrade the firmware for the FTP bug fix and when i ran the updater tool against my Lopy,i am getting the following error,
It looks like some JSON problem..Traceback (most recent call last): File "lopyupdate.py", line 96, in __after callback(result, param) File "lopyupdate.py", line 136, in <lambda> return self.get_file(key, True, lambda res, req: callback(BytesIO(res))) File "lopyupdate.py", line 331, in __firmwareDownloadCompleted self.__firmwareScript = load_tar(result) File "lopyupdate.py", line 58, in load_tar script = json.load(tar.extractfile("script")) File "E:\Pycom\Pycom Firmware Update\Python27\lib\json\__init__.py", line 291, in load **kw) File "E:\Pycom\Pycom Firmware Update\Python27\lib\json\__init__.py", line 339, in loads return _default_decoder.decode(s) File "E:\Pycom\Pycom Firmware Update\Python27\lib\json\decoder.py", line 364, in decode obj, end = self.raw_decode(s, idx=_w(s, 0).end()) File "E:\Pycom\Pycom Firmware Update\Python27\lib\json\decoder.py", line 382, in raw_decode raise ValueError("No JSON object could be decoded") ValueError: No JSON object could be decodedThanks & regards,
MK HB -
Unable to upgrade.
Connecting.....................................
Failure!Previous version upgrades no problem, so pins are properly bridged
We are currently checking this JSON error. We'll update you shortly.
Daniel -
Hello everyone,
JSON problem is fixed (no need to download a new tool), just try to update again. Thanks.
Daniel -
i have upgraded to 1.5.1 from 1.5.0
>>> os.uname() (sysname='WiPy', nodename='WiPy', release='1.5.1.b1', version='v1.8.6-422-g516b861 on 2017-02-07', machine='WiPy with ESP32') >>>and now i have problem with ftp by wifi
it disconnect me every few seconds (telnet work ok)rst:0x1 (POWERON_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT) configsip: 0, SPIWP:0x00 clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00 mode:QIO, clock div:2 load:0x3fff9010,len:8 load:0x3fff9018,len:268 ho 0 tail 12 room 4 load:0x40078000,len:2656 load:0x4009f000,len:2040 entry 0x4009f12c tcpip_task_hdlxxx : 3ffd4530, prio:18,stack:2048 I (2274) wifi: frc2_timer_task_hdl:3ffd7b48, prio:22, stack:2048 I (2279) wifi: pp_task_hdl : 3ffda3f8, prio:23, stack:8192 I (2280) wifi: sleep disable I (3254) wifi: mode : softAP (24:0a:c4:00:6e:c3) dhcp server start:(ip: 192.168.4.1, mask: 255.255.255.0, gw: 192.168.4.1) 16.58942 102146.0 130.268 wifi_ap MicroPython v1.8.6-422-g516b861 on 2017-02-07; WiPy with ESP32 Type "help()" for more information. >>> I (4752) wifi: n:6 0, o:6 0, ap:6 1, sta:255 255, prof:6 I (4752) wifi: station: 00:0c:f1:00:48:6b join, AID = 1, b, 20 I (11263) wifi: n:6 1, o:6 0, ap:6 1, sta:255 255, prof:6 I (11264) wifi: station: 7c:dd:90:4c:b5:9f join, AID = 2, n, 40U I (30080) wifi: station: 7c:dd:90:4c:b5:9f leave, AID = 2 I (30080) wifi: n:6 0, o:6 1, ap:6 1, sta:255 255, prof:6 I (31040) wifi: n:6 1, o:6 0, ap:6 1, sta:255 255, prof:6 I (31041) wifi: station: 7c:dd:90:4c:b5:9f join, AID = 2, n, 40U I (57272) wifi: station: 7c:dd:90:4c:b5:9f leave, AID = 2 I (57273) wifi: n:6 0, o:6 1, ap:6 1, sta:255 255, prof:6 I (58136) wifi: n:6 1, o:6 0, ap:6 1, sta:255 255, prof:6 I (58137) wifi: station: 7c:dd:90:4c:b5:9f join, AID = 2, n, 40U I (105199) wifi: station: 7c:dd:90:4c:b5:9f leave, AID = 2 I (105200) wifi: n:6 0, o:6 1, ap:6 1, sta:255 255, prof:6 I (106060) wifi: n:6 1, o:6 0, ap:6 1, sta:255 255, prof:6 I (106060) wifi: station: 7c:dd:90:4c:b5:9f join, AID = 2, n, 40U I (247788) wifi: station: 7c:dd:90:4c:b5:9f leave, AID = 2 I (247789) wifi: n:6 0, o:6 1, ap:6 1, sta:255 255, prof:6 I (248651) wifi: n:6 1, o:6 0, ap:6 1, sta:255 255, prof:6 I (248651) wifi: station: 7c:dd:90:4c:b5:9f join, AID = 2, n, 40U I (331797) wifi: station: 7c:dd:90:4c:b5:9f leave, AID = 2 I (331797) wifi: n:6 0, o:6 1, ap:6 1, sta:255 255, prof:6 I (332548) wifi: n:6 1, o:6 0, ap:6 1, sta:255 255, prof:6 I (332549) wifi: station: 7c:dd:90:4c:b5:9f join, AID = 2, n, 40UUPDATE
it looks strange - after "join" i can ping
but every few ping there is really long ping and back short pingPinging 192.168.4.1 with 32 bytes of data: Reply from 192.168.4.1: bytes=32 time=3ms TTL=255 Reply from 192.168.4.1: bytes=32 time=7ms TTL=255 Reply from 192.168.4.1: bytes=32 time=8ms TTL=255 Reply from 192.168.4.1: bytes=32 time=4ms TTL=255 Reply from 192.168.4.1: bytes=32 time<1ms TTL=255 **Reply from 192.168.4.1: bytes=32 time=1585ms TTL=255** Reply from 192.168.4.1: bytes=32 time<1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=5ms TTL=255 Reply from 192.168.4.1: bytes=32 time=2ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=2ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=65ms TTL=255 Reply from 192.168.4.1: bytes=32 time=79ms TTL=255 Reply from 192.168.4.1: bytes=32 time=87ms TTL=255 **Request timed out. Reply from 192.168.4.1: bytes=32 time=1253ms TTL=255 Reply from 192.168.4.1: bytes=32 time=612ms TTL=255 Reply from 192.168.4.1: bytes=32 time=116ms TTL=255** Reply from 192.168.4.1: bytes=32 time=2ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=3ms TTL=255 Reply from 192.168.4.1: bytes=32 time=2ms TTL=255 Reply from 192.168.4.1: bytes=32 time<1ms TTL=255 **Reply from 192.168.4.1: bytes=32 time=1082ms TTL=255** Reply from 192.168.4.1: bytes=32 time=5ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time<1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=4ms TTL=255 Reply from 192.168.4.1: bytes=32 time=12ms TTL=255 Reply from 192.168.4.1: bytes=32 time=3ms TTL=255 Reply from 192.168.4.1: bytes=32 time=11ms TTL=255 Reply from 192.168.4.1: bytes=32 time=3ms TTL=255 Reply from 192.168.4.1: bytes=32 time=5ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 **Reply from 192.168.4.1: bytes=32 time=1795ms TTL=255** Reply from 192.168.4.1: bytes=32 time<1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=16ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=6ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=4ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=2ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 **Reply from 192.168.4.1: bytes=32 time=1715ms TTL=255** Reply from 192.168.4.1: bytes=32 time<1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=5ms TTL=255 Reply from 192.168.4.1: bytes=32 time=8ms TTL=255 Reply from 192.168.4.1: bytes=32 time=6ms TTL=255 Reply from 192.168.4.1: bytes=32 time=5ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=6ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 **Reply from 192.168.4.1: bytes=32 time=1710ms TTL=255** Reply from 192.168.4.1: bytes=32 time=32ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time<1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=1ms TTL=255 Reply from 192.168.4.1: bytes=32 time=6ms TTL=255 Reply from 192.168.4.1: bytes=32 time=7ms TTL=255 Reply from 192.168.4.1: bytes=32 time=7ms TTL=255 Reply from 192.168.4.1: bytes=32 time=8ms TTL=255 Reply from 192.168.4.1: bytes=32 time=4ms TTL=255i mark lines with stars
UPDATE 2
i forgot to say that this is only in AP mode, STA mode work ok -
@daniel, do you know when the deepsleep feature will be added?
I'm already stuck on the firmware update step...
I cannot find this updater 1.5.1.b1. The link in your description (https://www.pycom.io/supportdownloads) points to a download page where I can only find a file "pycom_firmware_update_1.1.1.b1.exe or on mac pycom_update_1.1.1.b1.dmg)
This application does absolutely nothing, not on my mac (10.11.6) and not on windows. I do not get any application window...
Please advice on what I should do.
I might be able to help because I had a similar issue.
The updater software version and the latest firmware version are two different things. It confused me for a bit as well to see the version of the file being dowloaded not match. You do not need to download the updater every new firmware version. When you download and able to connect to your device the updated software gets the latest firmware and puts it on your device.
I had trouble on my mac and it was related to macports being installed. I was not using macports anymore so I just removed it.
@TravisT Thanks!
Issue is resolved. Indeed, it is quite confusing the version number on the download page. However, my mac refused to run the app because it wasn't trusted. I just clicked away the message without reading it... duh! Managed to start it now
It's upgraded to 1.5.1.b1 successfully now.
@Meirssv Don't confuse the version of the updater tool with the version of the firmware you will be installing. They are two different things, albeit the values of both are currently rather similar.
The main updater linked in this thread downloads the latest firmware file automatically. However, I found that it doesn't work for me (different error to you, though :-) ). Have a look for my recent thread about firmware updates and the uart - I'm on my phone right now and finding a link is too hard. In that thread we found a solution that should work for you too.
Pete
@daniel Still getting alot of these:
W (158381) wifi: post pm rx bcn failed
W (158382) wifi: post pm rx bcn failed
W (158384) wifi: post pm rx bcn failed
W (158388) wifi: post pm rx bcn failed
W (158391) wifi: post pm rx bcn failed
W (158395) wifi: post pm rx bcn failed
W (158398) wifi: post pm rx bcn failedActually worse than before. I can only have a socket open for a couple of minutes, and then its getting silently dropped. Also, because of another issue reported here, it is not possible to connect again after a socket failure.
Is there a way to disable power save in this release ?
@Wembly this weekend we'll be releasing new firmware with an option to disable power saving.
We have been late on releasing new firmware the last couple of weeks due to the recent Sigfox activities, but things we'll get back to normal next week.
@daniel - is it possible to disable these wlan debug messages as it is making it very difficult for me to read my own debug data:
W (366925) wifi: post pm rx bcn failed W (366925) wifi: post pm rx bcn failed W (366925) wifi: post pm rx bcn failed W (366925) wifi: post pm rx bcn failed W (366928) wifi: post pm rx bcn failed W (366931) wifi: post pm rx bcn failedThanks
@daniel Is it possible to modify the FTP server to support file or folder names containing spaces or accents. The OS supports this kind of files/folders because I can create them in REPL, thus it should be possible because any server program uses the same instructions to create a file or a folder.
Thanks -
@crankshaft yes we are working on disabling those messages.
@cvp It is possible, we will include that on the next release.
@daniel
i try diagnose problems with wifi in the current firmware
and i have question:I (539229) wifi: station: 7c:dd:90:4c:b5:9f leave, AID = 1 I (539229) wifi: n:6 0, o:6 1, ap:6 1, sta:255 255, prof:6 I (539260) wifi: max connection already. unexpected aid! I (539262) wifi: n:6 1, o:6 0, ap:6 1, sta:255 255, prof:6 I (539263) wifi: station: 7c:dd:90:4c:b5:9f join, AID = 1, n, 40U ets Jun 8 2016 00:22:57what is
unexpected aid!?
maybe it is not releated (because first is max connections) but..UPDATE
Can someone tell me if also have some problem with wifi in current firmware?
Or i am only one?
I have downgraded firmware and all work ok - if i flash it back to 1.5.1 problem appear -
@daniel Do you think you will soon support SD card of 64GB?
I had asked that via a mail to Pycom support and the answer had be yes, some time ago, before I buy the Wipy2.And thanks for the future FTP support of spaces and accents in files and folders names
@cvp we are working on it, we just need to enable exFAT support in FatFs.
