Connect Lopy to Windows over BLE
Hey, i could use some help.
I am traying to send pysense data to my Windows Pc from BLE.
My first problem is i see the Lopy and i can connect him. But a few second later the Lopy disconnected.
And the secouns Problem is the GATT service what is to do with the uuid and the characteristic?
This is my code:
from network import Bluetoothpycom.rgbled(0x00008b) # blue
#Bluetooth initialisierung
bluetooth = Bluetooth()
bluetooth.set_advertisement(name='LoPy', service_uuid=b'1234567890123456')def conn_cb (bt_o):
events = bt_o.events() # this method returns the flags and clears the internal registry
if events & Bluetooth.CLIENT_CONNECTED:
print("Client connected")
pycom.rgbled(0x00ff00)
elif events & Bluetooth.CLIENT_DISCONNECTED:
print("Client disconnected")
pycom.rgbled(0xFF0000)bluetooth.callback(trigger=Bluetooth.CLIENT_CONNECTED | Bluetooth.CLIENT_DISCONNECTED, handler=conn_cb)
bluetooth.advertise(True)
srv1 = bluetooth.service(uuid=b'1223190123456', isprimary=True)
chr1 = srv1.characteristic(uuid=b'ab3451230123456', value=5)
print("Send Data")
chr1.value("here is the data need to be send it should be a very very long string")
time.sleep(3.050)def char1_cb_handler(chr, data):
# The data is a tuple containing the triggering event and the value if the event is a WRITE event. # We recommend fetching the event and value from the input parameter, and not via characteristic.event() and characteristic.value() events, value = data if events & Bluetooth.CHAR_WRITE_EVENT: print("Write request with value = {}".format(value)) else: print('Read request on char 1')
