LTE not attaching anymore
I have a couple of older GPY working wiht no issues in LTE CAT-M. Since I received a new batch ( with the new firmware), im not able to attach to LTE, using the exact same code and sim card batch ( tested on multiple gpy).
Can I roll-back the modem firmware to the 'working version', or is there anything I can do to troubleshoot?
What I did so far :
<<< Welcome to the SQN3330 firmware updater [1.2.6] >>> >>> GPy with firmware version 1.20.2.r6 Your modem is in application mode. Here is the current version: UE5.4.0.2 LR5.4.1.0-50523DL SYNCHRO STATISTICS ===================== Synchro state : DRX_SLEEP PPU SIB1 ACQ watchdog : 0 Frequency Hypothesis RF (Hz) : 1000 RSRP (dBm) : -104.85 RSRQ (dB) : -12.36 Channel estimation state (Cell-spec.) : LOW CINR Channel estimation state (UE-spec.) : LOW CINR Channel estimation state (MBSFN) : LOW CINR Channel estimation CINR : 4.99 Channel length : SHORT AGC AGC RX gain (dB) : 59.74 RX PSD BO (dBFs) : -18.59 RX PSD (dBm) : -106.24 Noise level RS (dBm) : -108.12 Digital gain (dB) : 9.91 CINR RS (dB) : 3.27 NARROWBANDS Last DL NB : Central Last UL NB : 3 AFC Frequency offset RF (Hz) : -470 Frequency offset BB (Hz) : 0 PBCH MIB received quantity : 435 MIB timeout quantity : 0 RLF RLF idle qty : 1 RLF connected qty : 0 OK Sent to modem: 'AT!="fsm"' SYSTEM FSM ========== +--------------------------+--------------------+ | FSM | STATE | +--------------------------+--------------------+ | RRC TOP FSM |CAMPED | | RRC SEARCH FSM |CAMPED | | RRC ACTIVE FSM |IDLE | | PMM PLMN FSM |NORM_CAMPED | | EMM MAIN FSM |NULL | | EMM AUTH FSM |NULL | | EMM CONN FSM |NULL | | EMM TAU FSM |NULL | | EMM TEST FSM |NULL | | ESM BEARER FSM |BEARER_NULL | | SMS MT FSM |IDLE | | SMS MO FSM |IDLE | | HP MAIN FSM |IDLE | | HP USIM FSM |READY | | HP SMS MO FSM |IDLE | | HP SMS MT FSM |IDLE | | HP CAT FSM |IDLE | +--------------------------+--------------------+ OK .Sent to modem: 'AT!="showphy"' DL SYNCHRO STATISTICS ===================== Synchro state : DRX_SLEEP PPU SIB1 ACQ watchdog : 0 Frequency Hypothesis RF (Hz) : 1000 RSRP (dBm) : -105.53 RSRQ (dB) : -12.47 Channel estimation state (Cell-spec.) : LOW CINR Channel estimation state (UE-spec.) : LOW CINR Channel estimation state (MBSFN) : LOW CINR Channel estimation CINR : 4.61 Channel length : SHORT AGC AGC RX gain (dB) : 59.74 RX PSD BO (dBFs) : -20.91 RX PSD (dBm) : -106.39 Noise level RS (dBm) : -107.83 Digital gain (dB) : 10.06 CINR RS (dB) : 2.30 NARROWBANDS Last DL NB : Central Last UL NB : 3 AFC Frequency offset RF (Hz) : -470 Frequency offset BB (Hz) : 0 PBCH MIB received quantity : 435 MIB timeout quantity : 0 RLF RLF idle qty : 1 RLF connected qty : 0 OK Sent to modem: 'AT!="fsm"' SYSTEM FSM ========== +--------------------------+--------------------+ | FSM | STATE | +--------------------------+--------------------+ | RRC TOP FSM |CAMPED | | RRC SEARCH FSM |CAMPED | | RRC ACTIVE FSM |IDLE | | PMM PLMN FSM |NORM_CAMPED | | EMM MAIN FSM |NULL | | EMM AUTH FSM |NULL | | EMM CONN FSM |NULL | | EMM TAU FSM |NULL | | EMM TEST FSM |NULL | | ESM BEARER FSM |BEARER_NULL | | SMS MT FSM |IDLE | | SMS MO FSM |IDLE | | HP MAIN FSM |IDLE | | HP USIM FSM |READY | | HP SMS MO FSM |IDLE | | HP SMS MT FSM |IDLE | | HP CAT FSM |IDLE | +--------------------------+--------------------+ OK .Sent to modem: 'AT!="showphy"' DL SYNCHRO STATISTICS ===================== Synchro state : DRX_SLEEP PPU SIB1 ACQ watchdog : 0 Frequency Hypothesis RF (Hz) : 1000 RSRP (dBm) : -105.18 RSRQ (dB) : -11.20 Channel estimation state (Cell-spec.) : LOW CINR Channel estimation state (UE-spec.) : LOW CINR Channel estimation state (MBSFN) : LOW CINR Channel estimation CINR : 5.31 Channel length : SHORT AGC AGC RX gain (dB) : 59.74 RX PSD BO (dBFs) : -18.17 RX PSD (dBm) : -106.55 Noise level RS (dBm) : -108.10 Digital gain (dB) : 10.22 CINR RS (dB) : 2.92 NARROWBANDS Last DL NB : Central Last UL NB : 3 AFC Frequency offset RF (Hz) : -465 Frequency offset BB (Hz) : 0 PBCH MIB received quantity : 435 MIB timeout quantity : 0 RLF RLF idle qty : 1 RLF connected qty : 0 OK Sent to modem: 'AT!="fsm"' SYSTEM FSM ========== +--------------------------+--------------------+ | FSM | STATE | +--------------------------+--------------------+ | RRC TOP FSM |CAMPED | | RRC SEARCH FSM |CAMPED | | RRC ACTIVE FSM |IDLE | | PMM PLMN FSM |NORM_CAMPED | | EMM MAIN FSM |NULL | | EMM AUTH FSM |NULL | | EMM CONN FSM |NULL | | EMM TAU FSM |NULL | | EMM TEST FSM |NULL | | ESM BEARER FSM |BEARER_NULL | | SMS MT FSM |IDLE | | SMS MO FSM |IDLE | | HP MAIN FSM |IDLE | | HP USIM FSM |READY | | HP SMS MO FSM |IDLE | | HP SMS MT FSM |IDLE | | HP CAT FSM |IDLE | +--------------------------+--------------------+ OK .Sent to modem: 'AT!="showphy"'And it wont attach any time ( tried with different code)
The cell provider see the device offline so Im thinking its not even trying?
thanks!
