Encoding and Decoding with Helium
  • Hi,
    I am wondering how i could decode the data i send with lorawan to Helium. I am not sure how to decode it with Helium but i have done it with TTN. I send the data like this (2 integers).
    # create a LoRa socket
    # set the LoRaWAN data rate
    # make the socket blocking
    s.setblocking(True)
    # send some data (2 integers)
    test = result.temperature
    s.send(bytes([test, int(t2)]))
    How could i integrate this with Helium?
  • I don't use Helium or TTN, but a quick look at their decoder library suggests you may be able to use a straight drop in replacement.
    Depends on whether you're using TTN V2 or V3. Helium decoder structure appears to be exactly the same as V2.
1 out of 2
