pygate, wipy & TTN no data
  • Hello,
    I think I did everything ok, as on the manuals, but gateway is still disconected on TTN
    On my pygate I have:
    boot. py
    # boot.py -- run on boot-up
    from _pybytes import Pybytes
    from _pybytes_config import PybytesConfig
    # We want to save a little bit power
    # Disable Heartbeat LED
    pycom.heartbeat_on_boot(False)
    # Enable Pybytes
    pybytes_conf = PybytesConfig().read_config()
    pybytes = Pybytes(pybytes_conf)
    pybytes.start()
    # disable debug messages
    machine.pygate_debug_level(1)
    # Proceed with main.py
    machine.main('main.py')
    global_conf.json (downloaded from TTN);
      "SX1301_conf": {
        "lorawan_public": true,
        "clksrc": 1,
        "antenna_gain": 0,
        "radio_0": {
          "enable": true,
          "type": "SX1257",
          "freq": 867500000,
          "rssi_offset": -166,
          "tx_enable": true,
          "tx_freq_min": 863000000,
          "tx_freq_max": 870000000
        "radio_1": {
          "enable": true,
          "type": "SX1257",
          "freq": 868500000,
          "tx_enable": false
        "chan_multiSF_0": {
          "enable": true,
          "radio": 1,
          "if": -400000
        "chan_multiSF_1": {
          "enable": true,
          "radio": 1,
          "if": -200000
        "chan_multiSF_2": {
          "enable": true,
          "radio": 1,
          "if": 0
        "chan_multiSF_3": {
          "enable": true,
          "radio": 0,
          "if": -400000
        "chan_multiSF_4": {
          "enable": true,
          "radio": 0,
          "if": -200000
        "chan_multiSF_5": {
          "enable": true,
          "radio": 0,
          "if": 0
        "chan_multiSF_6": {
          "enable": true,
          "radio": 0,
          "if": 200000
        "chan_multiSF_7": {
          "enable": true,
          "radio": 0,
          "if": 400000
        "chan_Lora_std": {
          "enable": true,
          "radio": 1,
          "if": -200000,
          "bandwidth": 250000,
          "spread_factor": 7
        "chan_FSK": {
          "enable": true,
          "radio": 1,
          "if": 300000,
          "bandwidth": 125000,
          "datarate": 50000
        "tx_lut_0": {
          "pa_gain": 0,
          "mix_gain": 8,
          "rf_power": -6,
          "dig_gain": 0
        "tx_lut_1": {
          "pa_gain": 0,
          "mix_gain": 10,
          "rf_power": -3,
          "dig_gain": 0
        "tx_lut_2": {
          "pa_gain": 0,
          "mix_gain": 12,
          "rf_power": 0,
          "dig_gain": 0
        "tx_lut_3": {
          "pa_gain": 1,
          "mix_gain": 8,
          "rf_power": 3,
          "dig_gain": 0
        "tx_lut_4": {
          "pa_gain": 1,
          "mix_gain": 10,
          "rf_power": 6,
          "dig_gain": 0
        "tx_lut_5": {
          "pa_gain": 1,
          "mix_gain": 12,
          "rf_power": 10,
          "dig_gain": 0
        "tx_lut_6": {
          "pa_gain": 1,
          "mix_gain": 13,
          "rf_power": 11,
          "dig_gain": 0
        "tx_lut_7": {
          "pa_gain": 2,
          "mix_gain": 9,
          "rf_power": 12,
          "dig_gain": 0
        "tx_lut_8": {
          "pa_gain": 1,
          "mix_gain": 15,
          "rf_power": 13,
          "dig_gain": 0
        "tx_lut_9": {
          "pa_gain": 2,
          "mix_gain": 10,
          "rf_power": 14,
          "dig_gain": 0
        "tx_lut_10": {
          "pa_gain": 2,
          "mix_gain": 11,
          "rf_power": 16,
          "dig_gain": 0
        "tx_lut_11": {
          "pa_gain": 3,
          "mix_gain": 9,
          "rf_power": 20,
          "dig_gain": 0
        "tx_lut_12": {
          "pa_gain": 3,
          "mix_gain": 10,
          "rf_power": 23,
          "dig_gain": 0
        "tx_lut_13": {
          "pa_gain": 3,
          "mix_gain": 11,
          "rf_power": 25,
          "dig_gain": 0
        "tx_lut_14": {
          "pa_gain": 3,
          "mix_gain": 12,
          "rf_power": 26,
          "dig_gain": 0
        "tx_lut_15": {
          "pa_gain": 3,
          "mix_gain": 14,
          "rf_power": 27,
          "dig_gain": 0
      "gateway_conf": {
        "gateway_ID": "2462ABFFFEF4Dxxx",
        "server_address": "eu1.cloud.thethings.network",
        "serv_port_up": 1700,
        "serv_port_down": 1700,
        "servers": [
            "serv_enabled": true
    main. py
    from network import WLAN
    from machine import RTC
    print('\nStarting LoRaWAN concentrator')
    # Disable Hearbeat
    pycom.heartbeat(False)
    # Define callback function for Pygate events
    def machine_cb (arg):
        evt = machine.events()
        if (evt & machine.PYGATE_START_EVT):
            # Green
            pycom.rgbled(0x103300)
        elif (evt & machine.PYGATE_ERROR_EVT):
            # Red
            pycom.rgbled(0x331000)
        elif (evt & machine.PYGATE_STOP_EVT):
            # RGB off
            pycom.rgbled(0x000000)
    # register callback function
    machine.callback(trigger = (machine.PYGATE_START_EVT | machine.PYGATE_STOP_EVT | machine.PYGATE_ERROR_EVT), handler=machine_cb)
    print('Connecting to WiFi...',  end='')
    # Connect to a Wifi Network
    wlan = WLAN(mode=WLAN.STA)
    wlan.connect(ssid='<SSID>', auth=(WLAN.WPA2, "<PASSWORD>"))
    while not wlan.isconnected():
        print('.', end='')
        time.sleep(1)
    print(" OK")
    # Sync time via NTP server for GW timestamps on Events
    print('Syncing RTC via ntp...', end='')
    rtc = RTC()
    rtc.ntp_sync(server="pool.ntp.org")
    while not rtc.synced():
        print('.', end='')
        time.sleep(.5)
    print(" OK\n")
    # Read the GW config file from Filesystem
    with open('/flash/global_config.json','r') as fp:
        buf = fp.read()
    # Start the Pygate
    machine.pygate_init(buf)
    # disable degub messages
    # machine.pygate_debug_level(1)
    pybytes_config.json
    I folow manuals and create in TTN Aplication and gateway:
    and to mention, when I restart pygate I get this:
    >>> WMAC: 2462ABF4Dxxx
    Firmware: 1.20.2.r6
    Pybytes: 1.7.1
    WMAC: 2462ABF4Dxxx
    Firmware: 1.20.2.r6
    Pybytes: 1.7.1
    Initialized watchdog for WiFi and LTE connection with timeout 1260000 ms
    WiFi connection established
    Connected to MQTT mqtt.pybytes.pycom.io
    Pybytes connected successfully (using the built-in pybytes library)
      File "boot.py", line 16, in <module>
    AttributeError: 'module' object has no attribute 'pygate_debug_level'
      File "main.py", line 25, in <module>
    AttributeError: 'module' object has no attribute 'callback'
    Pycom MicroPython 1.20.2.r6 [v1.11-c5a0a97] on 2021-10-28; WiPy with ESP32
    Pybytes Version: 1.7.1
    What did I do wrong?
  • @jcaron
    wii that was it.
    I can’t tell you how happy I am that after many days of trying it finally works! : D
  • @Gregor-Leban it does look better now. You must be missing the global_config.json (not global_conf.json).
  • Now I did it again. But I'm still disconected on TTN gateway
    Connecting to COM3...
    WMAC: 2462ABF4Dxxx
    Firmware: 1.20.2.r6
    Pybytes: 1.7.1
    Pybytes configuration read from /flash/pybytes_config.json
    Connecting to WiFi... OK
    Syncing RTC via ntp...... OK
      File "main.py", line 48, in <module>
    OSError: [Errno 2] ENOENT
  • @Gregor-Leban did you flash the WiPy with the Pygate version of the firmware? Use the firmware upgrade tool and make sure you pick the right version.
3 out of 5
