    Tensorflow Lite MicroPython support - I cannot use Pycom modules?
    22 Posts 2 Posters 133 Views 2 Watching
      Adnan Sabovic 0 @robert-hh
      @robert-hh Aha okay I understand. Then I will focus more on the generic MicroPython implementation and try to find some solutions there. Thanks anyway!
        @robert-hh Do you maybe know how to fix issue with repl connection. I am not able to connect to repl when esp32 board is connected to my PC. I think that I tried everything that I found on web but it is not possible to connect it. Every time same message:
        Using buffer-size of 32
        Connecting to /dev/ttyUSB0 (buffer-size 32)...
        Trying to connect to REPL
        Do I need to connect some extra wires or what? It's a new board, I do not believe it's already damaged.
        Cheers! :)
          robert-hh @Adnan Sabovic 0
          @Adnan-Sabovic-0 Which software do you use for REPL?
          Simple tools like Putty or Teraterm should work.
            @robert-hh I want to connect using rshell as we talked in my previous post. I want to use rshell to upload files on esp32 and then run the example from repl, but it's not possible to connect it.
              @Adnan-Sabovic-0 So you use a Linux System with a generic USB/UART FT232 adapter. I'm asking because only the /dev/ttyUSBx is the right port. Which devices do you see with
              ls /dev/tty*
              rshell is sometimes difficult to use. I prefer mpremote, which is faster and newer.
                @robert-hh By typing ls /dev/tty* or dmesg | grep tty I can find my board:
                /dev/ttyUSB0
                And this is the output from mpremote (when I type mpremote in Ubuntu terminal):
                rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
                configsip: 0, SPIWP:0xee
                mode:DIO, clock div:2
                load:0x3fff0030,len:4604
                ho 0 tail 12 room 4
                load:0x40078000,len:13872
                load:0x40080400,len:3356
                entry 0x4008061c
                E (56) flash_parts: partition 3 invalid - offset 0x300000 size 0xc65d40 exceeds flash chip size 0x400000
                E (56) boot: Failed to verify partition table
                E (62) boot: load partition table error!
                ets Jun  8 2016 00:22:57
                Any idea how to solve this?
                  @Adnan-Sabovic-0 Like I answered in the Micropython forum: A reliable approach is performing a flash full erase using:
                  esptool.py --port /dev/ttyUSB0 --chip esp32 erase_flash
                  And the reinstall the firmware. That should fix the flash layout.
                    @robert-hh I did what you wrote here but again same issue. I performed a flash full erase and then installed again firmware and uploaded it on my board but again same error.
                      @Adnan-Sabovic-0 That's strange. After a full erase everything should come up straight again.
                        @robert-hh I really don't know. I tried everything but this is really hard to enable to work. Based on their suggestion on this link (https://github.com/mocleiri/tensorflow-micropython-examples/blob/main/examples/person_detection/README.md) the microlite-spiram-16m-esp32-firmware should be used with esp32. After error I thought it's quite heavy for my board and then tried a lighter version but again not possible to run anything on the board. For the lighter version of firmware I got this:
                        Rebooting...
                        ho 0 tail 12 room 4
                        entry 0x4008061c
                        E (847) psram: PSRAM ID read error: 0xffffffff
                        E (847) spiram: SPI RAM enabled but initialization failed. Bailing out.
                        E (10) spiram: SPI RAM not initialized
                          @Adnan-Sabovic-0 If 16m in the firmware name indicates 16MByte flash, then the firmware is wrong. FiPy has 8MB flash. So you need the matching firmware version.
                            @robert-hh I am not using FiPy right now. I ordered esp32-WROOM-32 to test as you suggested me to use pure MicroPython code (based on esp32). Because of that, I tried with 16MB firmware. With FiPy it works with "lighter" firmware but I want to test camera which is based on what I observed easier to do with esp32 board.
                              @Adnan-Sabovic-0 The WROOM-32 module has 4 MB Flash and no SPIRAM. So you have to use the MICROLITE version.
                                @robert-hh I just checked that, but are there any products with 8/16 MB Flash and SPIRAM as well. I also saw that they use esp32 cam. Is there classic esp32 cam with additional MB module and integrated camera is enough to support the proposed firmware (MICROLITE SPIRAM CAM)?
                                  @Adnan-Sabovic-0 The must be hundreds of different ESP32 modules available. You have to Search. The first which I found was a esp32-CAM module, with 4 MB flash and 4 MB SPIRAM + camera.
                                    @robert-hh Yes, indeed. Sit and search :)
                                    Thanks for help!
                                      @Adnan-Sabovic-0 I have a few links here, don'rt know if it helps:
                                      https://www.berrybase.de/dev.-boards/esp8266-esp32-d1-mini/boards/esp32-cam-development-board-inkl.-ov2640-kameramodul?sPartner=g_shopping&msclkid=ff9ff1f60f271b5e66f793976b4cf5eb
                                      https://de.banggood.com/ESP32-CAM-WiFi-+-bluetooth-Camera-Module-Development-Board-ESP32-With-Camera-Module-OV2640-Geekcreit-for-Arduino-products-that-work-with-official-Arduino-boards-p-1394679.html?gmcCountry=DE&currency=EUR&cur_warehouse=CZ&createTmp=1&utm_source=bing_pa&utm_medium=cpc_eu&utm_content=dcr&utm_campaign=dcr-co-bpla-deg-all-pc-0903&ad_id=&msclkid=35036f519f6318bf8aa30d30fb087491
                                        @robert-hh I decided to not use esp32 cam as it can only operate at voltage above 4V, which is not useful for my setup. I have a question related to ESP32-WROVER-IE(16MB) chip. On which expansion board I should attach it and flash? This chip offers 16MB Flash and 8MB SPIRAM, somehing that I need for my project, but still no available boards on which this chip is attached.
