    Can't connect to my LoPy4 board
    33 Posts 2 Posters 31 Views 2 Watching
      Liudmila Dobriakova @robert-hh
      @robert-hh as a new user i can reply only every 10 min, sorry fot the delay... no lights on board
        robert-hh @Liudmila Dobriakova
        @Liudmila-Dobriakova The bridge is OK and the Putty setting is correct.
        Then there is trouble with the LoPy4 board. Which is strange, because they are quite robust usually. If you have a voltmeter, can to measure the levekl at the bridge TX output when nothing is connected?
          @Liudmila-Dobriakova Responding should now be faster. I gave you a few + flags.
            @robert-hh tanks for the flags, appreciate it! sorry, takes me a while to find a multimeter. if i'm right the red cable go to the tx pin and the black to gnd, i can see 3.3 - 3.4 V
              @Liudmila-Dobriakova OK. So that level is fine, when nothing is connected.
              So, it looks like the Lopy4 is bricked, and I cannot tell a reason. Are you sure that you never connected the 5V from the USB adapter to the 3.3V pin of the LoPy4? That would at least explain it.
              About getting hot: is is too hot to touch, especially at some places close to the LED?
                @robert-hh well, i can't tell for sure, but i think i never connect it to the 5V. i would say it is too hot to even touch in opposite side from the led.
                  @Liudmila-Dobriakova Most likely then the 3.3V regulator is broken. I guess that there is no 3.3V at the 3.3V pin.
                  L 2 Replies Last reply Reply Quote 0
                    @robert-hh how can i check it?
                      @Liudmila-Dobriakova Measure with the voltmeter between the 3.3V pin and GND.
                        @robert-hh I tried with a multimeter to touch the pins from the external side and unstable can see from time to time 4,5, could it mean anything?
                          @Liudmila-Dobriakova 4.5V at the 3.3V pin is a problem. Are you sure you are at the 3.3V? If yes, then you can consider the LoPy4 as broken.
                            @robert-hh i'm a bit confused. My connection is like on foto. should I measure between GND and 3V3WhatsApp Image 2022-07-26 at 15.42.29.jpeg or GND and VIN?
                              @Liudmila-Dobriakova Measure between GND and 3.3V, while the board is powered. Then, you should have 3.3V at the 3.3V pin, which is the output of the 3.3V regulator of the LoPy4.
                                @robert-hh sorry for my ignorance, i'm doing this way, andWhatsApp Image 2022-07-26 at 15.58.13.jpeg it shows me 2,15
                                  @robert-hh sorry, the image was made afterward, and the cables are switched in the opposite way.
                                    @Liudmila-Dobriakova you have to connect GND to the board. Otherwise it is not powered.
                                      @robert-hh the blue wire is a GND
                                        @Liudmila-Dobriakova Sorry. It looked open in the picture. 2.15 V is too low for the ESP32 to work. But if the regulator gets hot, then there is a lot of current drawn. So there must be some kind of short on the board.
                                        Not good.
                                          @robert-hh u right, the picture was not clear, I can imagine.. .so there is nothing to bring it to life again? :( any other suggestions, or tricks?
                                          If there is no way to recover it, I have a question then, since there are no LoPy4 boards available currently on the market I was wondering if I can use the FiPy board, but I have a script for reading the sensors data and the connection layout them and connection for LoRaWAN stack written for the LoPy4 board, would it work for FiPy board as well or I have to start from the scratch?
                                            @Liudmila-Dobriakova In principle you can use a Fipy as well. Only it has fewer available Pins than the FiPy, since some of the pins are connected to the LTE modem. So it depends on which pins you are actually using for your applications. Just changing the pin numbers is easy.
                                            But please use a proper mechanical set-up for the boards and the adapter.
                                            Be aware that all esp32 based development boards by Pycom are discontinued. Stuff that is out-of-stock at a shop will never be available again. Only at Pycom itself you might place an order until the end of this month and then you might get them until the end of the year.
