      Peter Bankuti
      In the past few days they have finally included a link to the newest android app. Downloaded it, but it is just a waste of bandwidth. First it did not want to update the previous version. Ok, uninstalled the older one, then i installed the new one. Since my first day with the least connected devices i forgot my account password, so wanted to change that. I got a link via email just as one would normally expect, the link opens up a webpage you are supposed to enter a new password twice, but for some reason as you are typing, your input gets populated in both input fields... What is more of a problem, nothing happens when you click on the save button. No wonder the app does not accept the new password if the webpage does not replace that.
      Never seen anything like that in case of a released product. One would expect such to happen when an amateur who knows some PHP and HTML and has never done something like that is trying to come up with a solution for the very first time.
      I short version check reveals they linked Pylife app version 1.0.9 into the docs... well... i had previously 1.0.10 installed.
      Guys who is sitting behind the wheel? Do you care at all what the hell you are doing?
      • H Offline
        hjoe Pybytes Beta @Pete Allen 0
        @Pete-Allen-0 said in Getting started with PyGos and Pylife:
        make sure you are using the most recent version of the app.
        Which version number will this be? And where is the version number shown in the App?
        Pete it's tim to tell all of us the truth
          Stephen Glavin @hjoe
          Did you get any updates on this? Still waiting for a cradle here too.
          @hjoe
            Alberto Fassio
            I received my Pygo two days ago. It does not charge nor configure. Impossible to load new firmware even from cradle. Unusable
              robert-hh @Alberto Fassio
              @Alberto-Fassio When placed into the cradle, it may take an hour or more until it starts charging the fist time. The devices seem to arrive with a completely empty battery.
              You could check in the cradle & device, if the contacts are clean and correctly aligned.
                Timothy spann
                My screen never says hello. It seems to be charging with the bars going up and blue light on the charger
                  thinginnovations
                  I'm getting the same battery charging bars after charging the devices in my makeshift holder. They both show 100% via the app, I try to set the LoRa band but this cannot be set for some reason, even though the PyGo are showing as connected.
                  I try to wake the Pygo with a double tap but they either show nothing or just the battery charging indicator. I can get the REPL to show when USB uart adaptor is connected.
                  I was able to issue reset() and see the device restart and that's about it. No change to display. Is the current firmware still not working?
                  Regards
                  Andrew
                    robert-hh @thinginnovations
                    @thinginnovations If you have a USB terminal window open while trying someting in the APP, you'll see error messages about faults in RPC.
                    I never got the app to show the battery level.
                    So no, the devices are not useful for anything at the actual state. But maybe Pycom is working at bringing some functionality to the device. Maybe not.
                      thinginnovations @robert-hh
                      @robert-hh Good call, thanks.
                      I do get this now when trying to set LoRa frequency:
                      >>> Client connected
                        File "_ble_rpc.py", line 236, in feed
                        File "_ble_rpc.py", line 236, in <listcomp>
                        File "_ble_rpc.py", line 253, in resolve
                      AttributeError: 'RPCHandler' object has no attribute 'set_lora_freq'
                      Going to try a few more things.
                      Cheers
                      Andrew
                      W 1 Reply Last reply Reply Quote -1
                        thinginnovations
                        Also, while viewing the output I see the same error repeated :
                          File "_ble_rpc.py", line 245, in resolve
                        TypeError: 'int' object isn't iterable
                        Guessing there are some incompatibilities between the app and the firmware.
                        Cheers
                        Andrew
                        • W Offline
                          Whatamiseeing @thinginnovations
                          @thinginnovations Fuck it, why are you doing Pycom's job fixing this mess?
                            Alberto Fassio @robert-hh
                            @robert-hh I have charged the Pygo all the night. It does not work!!!
                              @Alberto-Fassio That's not good. So something is broken:
                              • the PyGo
                              • the cradle
                              • the cable to the cradle.
                              Do you see a com device for it when the the cradle is connected to the computer? The com device is created by the cradle itself.
                                @thinginnovations Every few days I have another short look at the PyGo & PyGo App. Yesterday I noticed that there is a new version of the App. SO I loaded it.
                                The only change I could notice was the change in the version number. No additional feature, not better interaction with the PyGo. The PyGo are still discovered, when being fully charged and close to the phone, unless they were set to "eco" mode. No setting of LoRa mode, no display of the charge state.
                                The only function that works reliably is: "Forget the PyGo"
                                T 1 Reply Last reply Reply Quote 4
                                • K Offline
                                  Keptenkurk
                                  The only function that works reliably is: "Forget the PyGo" 🤣 LMAO you really made my day!
                                  • E Offline
                                    exa @andreas58
                                    @andreas58 I'm interested, what did you use to connect to the pins?
                                    • E Offline
                                      exa
                                      I've realised that there's a Specsheet that contains quite a bit of information in the Getting Started page
                                      It shows the location of a sim car slot, but I can't see it on my device I'm wondering now if I got sent a PyGo1 in a PyGo2 box
                                      @Gustav-Hilding
                                        robert-hh @exa
                                        @Gaetan-Gueraud There is no SIM card slot at the final design. The SIM is built-in, it's said. I faintly recall, that was mentioned in one of the posts aiming at IP67 certification.
                                        Which SIM and which service level is unknown, but only matters when the device are working eventually.
                                        • E Offline
                                          exa @robert-hh
                                          @robert-hh Ok so then the app is also missing the Esim configuration then..
                                          Does it actually charge with the cradle? Can you do something with it?
                                          I didn't get a cradle because I assumed it came with some sort of charger and now I can only charge with QI which as I've read and found out doesn't actually charge.
                                          The location doesn't seems to update on the app.
                                          Overall the product doesn't seem to work and I'm considering asking a refund under the EU consumer rights.
                                            robert-hh @exa
                                            @Gaetan-Gueraud The device charges in the cradle. Using the cradle, you can connect via USB and get a REPL prompt abd use it like a generic esp32 device. You can as well update the firmware.
                                            When trying the APP, you will see at the serial console error messages, which demonstrate that App and PyGo firmware do not match.
                                            I could not tell whether the PyGo2 connects to LTE or LoRa or gets a GPS fix.
                                            At the moment, The PyGo seems pretty useless, and there is no communication from Pycom about fixing the firmware and making the devices work as promised.
                                            • 5
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 6 / 9
