NB-IoT to AWS?
Hey everyone, I'm working on a project that consists of having a gas sensor connected to the FiPy board which is connected to T-Mobile using NB-IoT. I want to have the collected data from the sensor transmit to Amazon Web Services (AWS).
From AWS I have the AWS_ROOT_CA, AWS_CLIENT_CERT, & AWS_PRIVATE_KEY downloaded onto my mac computer. The documentation says to place these files in a /flash/cert folder.
How do I perform this function if I'm using NB-IoT since the documentation uses WIFI?
Shown below is the config.py file
AWS general configuration
AWS_PORT = 8883
AWS_HOST = 'ABCDEFGHIJK.iot.us-west-2.amazonaws.com'
AWS_ROOT_CA = '/flash/cert/aws_root.ca'
AWS_CLIENT_CERT = '/flash/cert/aws_client.cert'
AWS_PRIVATE_KEY = '/flash/cert/aws_private.key'################## Subscribe / Publish client #################
CLIENT_ID = 'PycomPublishClient'
TOPIC = 'PublishTopic'
OFFLINE_QUEUE_SIZE = -1
DRAINING_FREQ = 2
CONN_DISCONN_TIMEOUT = 10
MQTT_OPER_TIMEOUT = 5
#LAST_WILL_TOPIC = 'PublishTopic'
#LAST_WILL_MSG = 'To All: Last will message'####################### Shadow updater ########################
#THING_NAME = "my thing name"
#CLIENT_ID = "ShadowUpdater"
#CONN_DISCONN_TIMEOUT = 10
#MQTT_OPER_TIMEOUT = 5####################### Delta Listener ########################
#CLIENT_ID = "DeltaListener"
#MQTT_OPER_TIMEOUT = 5####################### Shadow Echo ########################
THING_NAME = "Smart_Meter"
CLIENT_ID = "ShadowEcho"
Hi @riverj17,
Can you please share the new topic, where you moved?
Hi @riverj17,
I moved your topic to the correct section.
