FiPy - SMS sending.
Hello guys,
I need to send SMS from my FiPy, but cannot attach with lte, does anyone know how to do that?
thats what im trying
Hey, adding some code that should get you there and that includes a lot of useful debugging stuff. You'll need to change the apn / band .
import time import socket from network import LTE # Connect to Mobile def connect_mobile(settings): lte = LTE() connected = False display.set_mode("Trying: LTE") try: lte.init() print("LTE init success") except: print("LTE init failed") print(lte.ue_coverage()) # Check network coverage (True, is yes) print(lte.send_at_cmd('AT!="fsm"')) print(lte.send_at_cmd("AT")) print(lte.send_at_cmd("ATI1")) print(lte.send_at_cmd("AT+CSMINS?")) print(lte.send_at_cmd("AT+CFUN?")) print(lte.send_at_cmd('ATI+CIMI')) # Request IMSI print(lte.send_at_cmd('ATI+SQNCTM=?')) print("Add band, will be much faster") #lte.attach(band=None, apn="iot.1nce.net") #band : to scan for networks. If no band (or None) is specified, all bands will be scanned. The possible values for the band are: 3, 4, 5, 8, 12, 13, 20 and 28. lte.attach(band=20, apn="iot.1nce.net") # works print("attaching..",end='') while not lte.isattached(): time.sleep(0.25) print('.',end='') print(lte.send_at_cmd('AT!="fsm"')) # get the System FSM print("attached!") # once attached print(lte.send_at_cmd("AT+CSQ")) # Signal quality, returns <ssid> (), <ber> # SSID (received signal strength indication) ## 0: -113dBm or less ## 1: -111 dBm ## 2..30: -109..-53 dBm ## 31: -51 dBm or greater (best) ## 99: not known or not detectable # ber : channel bit error rate in percent ## 0..7: see table ## 9: not known or not detectable lte.connect() print("connecting [##",end='') while not lte.isconnected(): time.sleep(0.25) print('#',end='') print(lte.send_at_cmd('AT!="fsm"')) print("] connected!") print(socket.getaddrinfo('pybytes.pycom.io', 80)) lte.deinit() # Disables LTE modem completely return connected
