Upload issue due to 2-line code
  • I can't upload code to my Pycom Fipy anymore because this is the code that is running:
    from network import LTE
    print("ik ga slapen")
    machine.deepsleep(40*1000)
    when i try to upload code i get this reaction
    Safe booting device... (see settings for more info)
    Safe boot failed, uploading anyway.
    Uploading to /flash...
    Upload failed.: timeout Please reboot your device manually.
    but if i reset manually the device goes immediately in deepsleep as i coded...
    so how can i upload other code to my Pycom?
    kind regards,
  • @Elias-Tapia Assuming you have the LOPY4 attached to some kind of USB/Serial interface, like an expansion board, the Updater should always work. You can try to force the ESP32 into update mode by pulling P2 to GND an pushing Reset. You msut as well verify that you use the proper Serial port on your PC.
  • @robert-hh thanks a lot, it works on terminal,i'll implement gc.collect() then..
    One more thing I have a LOPY4 unable to be udpated by pycom firmware udpater but this error came out: The upgrade failed due to the following error:
    Failed to connect to Espressif device: No serial data received.For
    troubleshooting steps visit: https://docs.espressif.com/projects/
    esptool/en/latest/troubleshooting.html, but the link gives the error 404 page not found
  • @Elias-Tapia Using Ctrl-C from a serial terminal you should be able to interrupt your code and get a REPL prompt, unless your code disables keyboard interrupt. For that situation pulling up P12 and pushing reset helps. It skips execution of boot.py and main.py and gets you to a REPL prompt. Then, you can change or replace main.py & boot.py. All these low level operations are better done with a simple serial terminal and NOT IDE's like pymakr or Thonny.
    It is good practice to put your main application not into main.py, but in a file with e.g. the name my_app.py, and have main.py just be something like:
    time.sleep(3)
    import my_app
    That gives you a time slot of 3 seconds to interrupt the start process.
    I cannot tell you a lot about the disconnection problem. Things that happen only after days are hard to trace. Maybe it's a memory fragmentation problem. Then it might help to add gc.collect() to the main loop of your code.
    Note:
    Using P12 pull-up does NOT stop the hidden _boot.py and _main.py.
  • @robert-hh I am using atom, with the pymakr plugin
  • @Elias-Tapia I uinderstand that you have issues to update the Python code. Which tool do you use to update the Python code?
  • @robert-hh would this work with my pysense? I am using a pysense and a lopy4, the thing is that I have two issues when I upgrade my firmware: with the pycom firmware update v1.17.0.b4-development, I am able to upload my code this works, I'm receiving the data on chirpstack and influxdb. Now I want to update the new code but the first thing that appears is OSError: [Errno 17] EEXIST pycom then: Uploading project (main folder)...
    The safe booting device... (see settings for more info)
    So I have to upload again the firmware with the tool. That is my first issue.
    The second is that my node is only able to send over a day or two then it disconnects from my chirpstack and unless I disconnect the device and reconect tothe source again it would not send the data, this is the code of the pysense:
    code_text
    #!/usr/bin/env python
    # Copyright (c) 2019, Pycom Limited.
    # This software is licensed under the GNU GPL version 3 or any
    # later version, with permitted additional terms. For more information
    # see the Pycom Licence v1.0 document supplied with this file, or
    # available at https://www.pycom.io/opensource/licensing
        OTAA Node example  as per LoRaWAN AS923 regional specification
        - compatible with the LoPy Nano Gateway and all other LoraWAN gateways
        - tested works with a LoRaServer, shall works on TTN servers
    from network import LoRa
    import binascii
    import struct
    from CayenneLPP import CayenneLPP
    from pysense import Pysense
    from LIS2HH12 import LIS2HH12
    from SI7006A20 import SI7006A20
    from LTR329ALS01 import LTR329ALS01
    from MPL3115A2 import MPL3115A2, ALTITUDE, PRESSURE
    py = Pysense()
    si = SI7006A20(py)
    lt = LTR329ALS01(py)
    li = LIS2HH12(py)
    # Disable heartbeat LED
    pycom.heartbeat(False)
    LORA_CHANNEL = 1
    LORA_NODE_DR = 4
        utility function to setup the lora channels
    def prepare_channels(lora, channel, data_rate):
        AS923_FREQUENCIES = [
            { "chan": 1, "fq": "923200000" },
            #{ "chan": 2, "fq": "923400000" },
            #{ "chan": 3, "fq": "922200000" },
            #{ "chan": 4, "fq": "922400000" },
            #{ "chan": 5, "fq": "922600000" },
            #{ "chan": 6, "fq": "922800000" },
            #{ "chan": 7, "fq": "923000000" },
            #{ "chan": 8, "fq": "922000000" },
        if not channel in range(0, 9):
            raise RuntimeError("channels should be in 1-8 for AS923")
        if channel == 0:
            import  uos
            channel = (struct.unpack('B',uos.urandom(1))[0] % 7) + 1
        for i in range(0, 8):
            lora.remove_channel(i)
        upstream = (item for item in AS923_FREQUENCIES if item["chan"] == channel).__next__()
        # set default channels frequency
        lora.add_channel(int(upstream.get('chan')), frequency=int(upstream.get('fq')), dr_min=0, dr_max=data_rate)
        return lora
        call back for handling RX packets
    def lora_cb(lora):
        events = lora.events()
        if events & LoRa.RX_PACKET_EVENT:
            if lora_socket is not None:
                frame, port = lora_socket.recvfrom(512) # longuest frame is +-220
                print(port, frame)
        if events & LoRa.TX_PACKET_EVENT:
            print("tx_time_on_air: {} ms @dr {}", lora.stats().tx_time_on_air, lora.stats().sftx)
        Main operations: this is sample code for LoRaWAN on AS923
    lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AS923, device_class=LoRa.CLASS_A, adr=True)
    # create an OTA authentication params
    dev_eui = binascii.unhexlify('******')
    app_eui = binascii.unhexlify('********')
    #nwk_key = binascii.unhexlify('******')
    app_key = binascii.unhexlify('********')
    # join a network using OTAA
    lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0, dr=2) # AS923 always joins at DR2
    prepare_channels(lora, LORA_CHANNEL,  LORA_NODE_DR)
    print('Over the air network activation ... ', end='')
    while not lora.has_joined():
        time.sleep(2.5)
        print('.', end='')
    print('OTAA joined')
    # create a LoRa socket
    lora_socket = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
    # set the LoRaWAN data rate
    lora_socket.setsockopt(socket.SOL_LORA, socket.SO_DR, LORA_NODE_DR)
    # msg are confirmed at the FMS level
    lora_socket.setsockopt(socket.SOL_LORA, socket.SO_CONFIRMED, 0)
    # make the socket non blocking y default
    lora_socket.setblocking(False)
    lora.callback(trigger=( LoRa.RX_PACKET_EVENT |
                            LoRa.TX_PACKET_EVENT |
                            LoRa.TX_FAILED_EVENT  ), handler=lora_cb)
    time.sleep(4) # this timer is important and caused me some trouble ...
    for i in range(0, 100000000):
        #pkt = struct.pack('>H', i)
        #print('Sending:', pkt)
        #lora_socket.send(pkt)
        #time.sleep(300)
        pycom.rgbled(0x000014)
        lpp = CayenneLPP()
        print('\n\n** Humidity and Temperature Sensor (SI7006A20)')
        print('Humidity', si.humidity())
        print('Temperature', si.temperature())
        lpp.add_relative_humidity(1, si.humidity())
        lpp.add_temperature(1, si.temperature())
        mpPress = MPL3115A2(py,mode=PRESSURE)
        print('\n\n** Barometric Pressure Sensor with Altimeter (MPL3115A2)')
        print('Pressure (hPa)', mpPress.pressure()/100)
        lpp.add_barometric_pressure(1, mpPress.pressure()/100)
        print('\n\n**LoRa stats')
        SNR=lora.stats().snr
        RSSI=lora.stats().rssi
        print("SNR: {}u @RSSI: {}".format(SNR, RSSI))
        lpp.add_snr(1, SNR)
        lpp.add_rssi(1, RSSI)
        encoded_payload = lpp.get_buffer()
        print('Sending data (uplink)...')
        lora_socket.send(bytes(encoded_payload))
        #lora_socket.setblocking(False)
        data = lora_socket.recv(64)
        #Payload
        payload_size = len(encoded_payload)
        print("Payload size:", payload_size, "bytes")
        #Data
        print('Received data (downlink)', data)
        pycom.rgbled(0x001400)
        time.sleep(300)
    Any ideas?
  • This post is deleted!
  • @Elias-Tapia See the previous post:
    Pull P12 up (connect to 3.3V) and push reset. Then, boot.py and main.py will not be executed.
  • I have the same problem, but I'm not using deep sleep, I only am able to upload new code if I upload the firmware again, any ideas?
  • @frederik-Leys Pull P12 up (connect to 3.3V) and push reset. Then, boot.py and main.py will not be executed.
