    Can connect in REPL but not with main.py
    17 Posts 2 Posters 260 Views 2 Watching
      SciWax
      Hello together,
      I can connect to the WiFi network and send data to my server while only using the REPL in VScode and the pymakr plugin. Connecting to the WiFi network is not possible for me when I try to do it in the main.py. I just can't connect to the WiFi network.
      I'm using an older version of VScode, because with newer versions pymakr doesn't work...
      VScode: 1.51.1
      Pymakr 1.1.18
      >>> os.uname(
      (sysname='WiPy', nodename='WiPy', release='1.20.2.r6', version='v1.11-c5a0a97 on 2021-10-28', machine='WiPy with ESP32', pybytes='1.7.1')
      The lines I put in the REPL line by line:
      import network
      import urequests # https://github.com/micropython/micropython-lib/blob/master/urequests/
      wlan.connect('networkname', auth = (wlan.WPA2, 'password'), timeout=5000)
      wlan.isconnected()
      print(wlan.ifconfig())
      dataRec = """{"Number1":11,"Number2":2021}"""
      print(dataRec)
      dataRec = eval(dataRec)
      res = urequests.post("https://website.com/test.php", json=dataRec)
      res.close()
      print(res.status_code)
      res.status_code - 200
      I looked at different examples on the official tutorial and here how to connect to the WiFi network, but the suggestions were not successful for me.
      import network
      # create WiFi station object
      try:
          print("[WiFi] network interface client object created")
      except:
          print("[WiFi] network interface client object (except). Reset board ...")
          machine.reset()
      try:
          wlan.connect('networkname', auth = (wlan.WPA2, 'password'))
          print('Connecting to: ' + 'networkname')
          while not wlan.isconnected():
              time.sleep_ms(100)
              print('#',end='')
      except:
          print('Could not connect to '+ 'networkname' +', resetting.')
          machine.reset()
      I just gets stuck in the while loop:
      See https://docs.pycom.io/smart for details
      Connecting to: networkname
      I want to use the WiPy because of the TLS1.2 which comes with it. I don't know what the issue is and if there is another micropython based microcontroller board being shipped with TLS1.2 I'm happy to switch.
      Do you have an idea, what the issue is rob? @robert-hh :)
      Kind regards
        SciWax
        It seems like putting more "sleeps" in the code helped:
        try:
            time.sleep(1)
        except:
            machine.reset()
        try:
            time.sleep(1)
                time.sleep_ms(200)
                print('#',end='')
        except:
            machine.reset()
        Still, it doesn't always work. When I reset the WiPy with the Reset-Button, sometimes there is an immediate connection and sometimes not.
          robert-hh
          That is strange. Your code is similar to what I use regularly.
          def do_connect():
              import network
              wlan = network.WLAN(mode=network.WLAN.STA) # create station interface
              if not wlan.isconnected():      # check if the station is connected to an AP
                  wlan.connect(ssid=WIFI_SSID, auth=(network.WLAN.WPA2, WIFI_PASSWD))
                  for _ in range(100):
                      if wlan.isconnected():      # check if the station is connected to an AP
                          break
                      print('.', end='')
                      time.sleep_ms(200)
                      print("Connect attempt timed out\n")
                      return
              print('\nnetwork config:', wlan.ifconfig())
          do_connect()
            robert-hh @SciWax
            @SciWax About Another board with TLS. The mainstream MicroPython supports ESP32 boards and TLS 1.2. The Generic ESP32 firmware with or without SPIRAM support should work on WiPy boards. Only the "Pxx" pin names are not supported.
              SciWax @robert-hh
              @robert-hh Thank you for the advise and fast answer. I really appreciate it. What I really liked about Pycom and their boards was the SSL/TLS support, so I could use it to talk with TLS secured websites out of the box.
              So if I would get one ESP32-S3 board and use micropython, I could immediately send a post request to a https website using TLS for web security reasons? I do not need to add a ssl certificate to an ESP32-S3 board myself, right? It will just work out of the box like for the pycom boards?
              Kind regards
                robert-hh @SciWax
                @SciWax There was some discussion in the MicroPython site that for TLS you might have to add your own certificates. Should be in the documentation. Different to Pycom, MicroPython.org does not run any web services.
                  SciWax @robert-hh
                  @robert-hh Yeah, I've looked in the forums and tried many examples from here. Also this one. I have to check, if "sleeps" also help here in your example code. I'm using the pycom expansion board and connect it to my notebook. I also tried two different WiPys and behaviour was the same.
                    robert-hh @SciWax
                    @SciWax About TLS: See https://docs.micropython.org/en/latest/library/ssl.html
                      SciWax @robert-hh
                      @robert-hh Thank you. Good to know. I can work around the issue I have with the WiPys, because I just use them as a board to easily send data to my server. I just connect them to my other microcontroller board.
                        robert-hh @SciWax
                        @SciWax That is still strange. What is the level of P12, the antenna selection pin? Did you change something with it? The default is MAN_ANT, which is the level you force P12 to be. See https://docs.pycom.io/firmwareapi/pycom/network/wlan/
                          SciWax @robert-hh
                          @robert-hh No, I didn't touch the Pin. I was thinking about it too, but all the tutorials talk about how you only need to touch this Pin, if you want to use an external antenna. Should I pull P12 low just in case? I'm using the internal Antenna.
                            robert-hh @SciWax
                            @SciWax You can either put it to a definitive state or use the antanna=WLAN.INT_ANT option in the WLAN constructor. You can as well call wlan.antenna() to see the actual value or call wlan.antenna(WLAN.INT_ANT) to set it to internal antenna.
                              robert-hh @SciWax
                              @SciWax If I have WiFi problems it usually also helps to reboot the Access Point.
                                SciWax @robert-hh
                                @robert-hh I've checked the value of the output of
                                wlan.antenna()
                                It was 2 without touching it
                                with
                                wlan.antenna(wlan.INT_ANT)
                                it becomes 0
                                >>> wlan.antenna()
                                0
                                If I upload the code with setting the wlan.antenna to internal nothing changes really:
                                The code only works every second time, when I reset the board. During the first time attempt, where I just power it (Connecting the expansion board with the usb port), it gets stuck in the while loop, second time when using the reset button the WiPy gets the Wifi connection immediately. When I continue using the reset button again, it is getting stuck again, using it again, it connects immediately. Hence every second time it works. It is a really weird behaviour.
                                I don't know, if not being aware of the board starting with wlan.antenna() being 2 did something funny with the hardware. Does 2 stand for selecting the external antenna? Maybe that broke the WiPy a little, because this behaviour is so strange. It can't be my code I think.
                                When I have access to my other expansion boards, I will try another one and a fresh WiPy with setting the wlan.antenna to internal. Then Ive checked everything on a hardware level.
                                  SciWax @robert-hh
                                  @robert-hh Unfortunately during my project, I have no access to the access point and can't reboot it.
                                    robert-hh @SciWax
                                    @SciWax said in Can connect in REPL but not with main.py:
                                    2 stands for MAN_ANT: taking the value from P12 to select the antenna mode.
                                      SciWax @robert-hh
                                      @robert-hh okay, makes sense regarding the documentation. thanks for the information
